Question about HP Office Equipment & Supplies
Printer leaves black marks on reverse of printed page, how do I clean the printer
Printer too old, bought new one, thanks
Posted on Jul 31, 2008
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
HP 6050 leaving black marks of the back of prints
you need to print clean page two or three times to clean printer path for toner , then check the last page you if there other black market , tell me , what black market looks like , hope that helped you
Mohamed Hejazi
Afaqnama Libya
ipg@hplibya.com
Feb 25, 2013 | Office Equipment & Supplies
When we attempt to print it leaves black streak marks. At first it printed all black and when we went to setup under maintainence we chose alignment and clean cartridges. This worked however we still see...
If an inkjet printer gives white streaks where it should be black, it means the ink is very low, or there is dirt under the nozzles preventing it from printing properly, or, in the case of non original cartridges, ink might be leaking which prevents the bubbles of ink to squirt onto the page.
If the streaks are black where it should be white, is sounds like some dust or fluff below the cartridge leaves ink smears on the page.
Aug 23, 2011 | Lexmark X4650 InkJet Printer
Replaced black ink, printer skips and leaves marks.
This issues looking printer head problem. check the following Steps for cleaning printer head :
Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
Feb 24, 2011 | Office Equipment & Supplies
Black marks on the printing
You could have a build up of ink on your rollers, and as the paper is pushed through it is leaving marks. It could also be causing your ghosting effect or double lines. By having your printer cleaned by a certified technician it should reslove your issue.
Jun 09, 2010 | Epson Stylus Photo 1290 InkJet Printer
My printer leaves black marks down the right side of my documents on every page. I have changed the toner but that does not help. Can I clean the drum?
It may need general cleaning OR have toner stuck to the fuser roller.
Be very careful of the ionizing wires... they are fragile in laser printers.
Sep 23, 2009 | Brother HL 5250DN Laser Printer
I'm getting black smudge marks on copies. After
I also had this issue, waste tone was comming from the transfer belt, had a good clean out been good for months now.
Aug 11, 2009 | Samsung CLP 300 Laser Printer
Black streaks through pages
There can be some reasons:
1. The Fuser is too cold, so toner was not fixed
2. Image Transfer Belt is defect or dirty
Greetings from Germany
Mar 13, 2009 | Samsung CLP 300 Laser Printer
Black ink line on back of paper
Hi , look some used injection cyrene to suck up the used ink , take cover suck up all ink by reversing injection put in clean jar .after all ink finished cover it try to print from first time some print some black mark after tthree or four times maybe no more.
Jan 08, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Printer is leaving black ink marks all over paper. Only happens from one tray. What can be done? I ran a cleaning page through and tried to clean the rollers.
Is there any way you can post an image of a page. If you can't I'll need to have a vivie description of these marks: -Where they are located. - general shape - location - any pattern - are they getting lighter the more you print. Once we get this information we can start troubleshooting.
Jan 22, 2007 | HP LaserJet 8000 Printer
282 people viewed this question
Seeker5211
Seeker5211
