Question about Gateway CX2610 Notebook
Stopped turning on
I had my CX2610 on & plugged in to charge and it seemed to be working great. I came home a couple hours later and it was completely off and wouldn't turn back on. The battery charging light doesn't come on when I have it plugged in. Any ideas?
I had the same problem so I played around with the plug by rotating the plug on the jack, so if you remove it and plug it in with a different position it works for me. But the battery does not charge well anymore...
Posted on Aug 30, 2008
I just had new brakes, rotors and calibers put on my camry and was doing great and now it seems after i drive a mile or two and a few stops with the brakes they seem to look up, was going 5 mph at...
Hi, being new breaks they probably arnt worn in yet. Heat from friction is causing the parts to expand. When your breaks are put on whether you did them yourself or a shop did them. You have to leave room for a whole tire turn while offf ground while break is disengaged if not you will recieve similar problems as what your experiencing. If I was you I would (assuming you took it to a dealer) take it back and demad they fix it right. Or find someone mechanically inclined you know as a friend to change / adjust them and as your wear the pads they should work alot better. Good luck :D
Sep 25, 2011 | 1997 Toyota Camry
I can't get my Sansa MP3 player to charge
Hi, 48 hours later , the player has sucked in enough electricity ! Thank you , Linda
Jun 05, 2010 | SanDisk Sansa Fuze MP3 Player
Borrowed a flip video to tape daughters
camcorders don't generally charge from pc's as the voltage is much higher.they won't switch on when the battery is low or i should below a certain voltage..try charging it using its charger it will probably be fine .good luck farr64[colin]
Dec 29, 2009 | Pure Digital Flip Video Ultra Camcorder
Not turning on
My unit was totally dead. I just kept it plugged into my computer for about 12 hours. I downloaded the newest software from Garmin. When I unplugged it from my computer, the battery seemed to drain quick, but once I plugged it into the card adapter in the car... everything seems to be running great now.
Oct 09, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
The blue light on my base unit is on but the headset does not app
Unplug the unit -- Then grab the ear peice, and slide off the battery, wipe off the metal prongs ...leave apart for a couple minutes, then put back together. Make sure you plug the unit back in. It will take a couple hours for the battery to charge. But this should solve your issue.
Aug 29, 2009 | GN Netcom GN 9350 Wireless Headset
Stopped turning on, charge light appears when plugged in...
try removing the battery and plug in AC power only and power up, sounds like you may have shorted the battery
Nov 24, 2008 | Gateway CX2610 Notebook
Toshiba m300 charging trouble, stops charging when notebook is started.
sounds like the battery is showing that there is not much may need to do a couple of deep discharge cycles..
Oct 13, 2008 | Computers & Internet
Phone stopped working
Try to blow dry and then power up.
Sep 02, 2007 | Motorola Mobility RAZR V3
Gateway CX2610 Notebook Logo
75 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
