Question about Epson Stylus Photo R220 InkJet Printer
Its not printing
I have been overseas and haven't used the printer in a year. I reloaded the CD and it shows that I have about 1/2 cartridge left for each color...but BLACK INK doesn't print. the colors for "WINDOWS" printed, but that was all. Red prints Let me know!
    Guru:
  • 859 Answers
If you suspect your ink is dried out it has.
When you get your new cartridge pack, Office Depot has them or Staples. Run the print head alignment adjustments and more importantly the head cleaning process.
In fact, you could try running the head cleaning now if you care to. It shouldn't make any difference in your case, but give it a go anyway. You do need to clean the heads anyway, just don't do it by hand, you will warp these nanometer holes and you could end up with a leak as well.
If you have any other questions, just ask me. I'm here to help.
BTW, if you need to reinstall the software again too for some reason, disconnect the USB cable first and then only connect it when prompted or the installation has finished. Then when you connect the printer and windows wants to add it as new hardware just press escape until you back out of this routine.
If this answers your questions, please rate this as 'Fixed', otherwise if you have further questions ask away.
Regards,
Worldvet
Posted on Jul 31, 2008
Unsupported ink cartridge after power outage
(1) Open the printer and wait for the carriage to slide over. If for some reason it does not follow these instructions:
(a) Unplug the printer
(b) Manually slide the carriage over until you can get the ink cartridges out.
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water or a mix of hot water and isopropyl alcohol to thoroughly clean the print head.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Canon Printer Support
Mar 18, 2014 | Canon PIXMA Office Equipment & Supplies
Printer prints off the side of the page
Hp2600n Colour Printer Colou Problms
Feb 14, 2014 | Lexmark E332n Laser Printer
I would be calling Lexmark about this because this is not a user serviceable issue. If you are down to measuring the size of boxes that it prints out and they are not right, I would want to see what the issue is and how to fix it.
Mar 06, 2017 | Lexmark E332n Laser Printer
Hello I have a Lexmark X4650 printer. I was printing earlier this morning and then suddenly, the printer stopped working and gave the error message that left cartridge is incorrect (I haven't...
Good job in re-seating the cartridges into the printer. Try to insert a different known working cartridge to determine if your other cartridge has gone bad.
Jul 24, 2011 | Lexmark X4650 InkJet Printer
Hey, I have the X7170 printer and haven't used it for about a year. Now, the fax, and scan works fine, but when I print a paper, it comes out blank even if the ink catridge is full. Seems that there is...
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
Jun 24, 2011 | Lexmark X7170 All-In-One InkJet Printer
My hp deskjet 6940 inkjet printer doesn't show me level of ink in cartridge
Print a diagnostic page If the steps above have not helped, print and evaluate a diagnostic page to see if the cartridges or the printer is causing the problem.
  1. Make sure the printer is on and loaded with unused, plain, white paper.
  2. Press and hold the Power button and then press the Cancel button. Release both buttons. The diagnostic page prints. Figure 1: Power and Cancel buttonsc00584735.gif 1 - Cancel button 2 - Power button
Step 4: Note which cartridges printed which areas of the diagnostic page You must identify which cartridge printed which part of the diagnostic page, so that if you find defects on the page, you will know which cartridge is the problem. However, you can install different combinations of print cartridges in your printer, and different cartridge combinations print different diagnostic page patterns. Your diagnostic page may not look exactly like the picture below, but the right and left cartridges will print in the same areas of the page no matter which cartridges are installed. Figure 2: Diagnostic page layout (the patterns in each area may look slightly different on your page)c00584715.gif 1 - Printed by the right cartridge 2 - Printed by the left cartridge NOTE: If you are printing in reserve mode (one cartridge is missing), the missing cartridge's area of the diagnostic page will be blank. Step 5: Check ink levels NOTE: If you have installed a refilled or remanufactured ink cartridge, or a cartridge that has been used in another product, the ink level indicator is inaccurate or unavailable. Look in the middle of the diagnostic page. The bars with "E" (for "empty") and "F" (for "full") at each end show the ink levels in the cartridges. As ink is used, the solid color changes to a faded color. Figure 3: Left (tri-color) cartridge almost full - right cartridge emptyc00235259.gif Figure 4: Both left and right cartridges almost fullc00235260.gif
Feb 22, 2011 | HP Deskjet 6940 InkJet Printer
Printing with double lines and blurry on left side of the page
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 19, 2009 | HP DeskJet 1220c InkJet Printer
Not printing
do these steps..
  • Shut down printer and restart it.
  • Check printer cartridge
  • If all else fails, reload printer driver from CD that came with printer.
Feb 02, 2009 | Epson Stylus C60 InkJet Printer
Ink has run out message
Ink not made for your printer has risks. 20 years as Canon rep taught me this. Yields: are affected by resolution, type of paper, condition of print head, condition of ink jets, all ink jets and lasers are mfg'd under lisence to Canon. You have the best! Anytime supplies are cheaper, something is left out. used cartridges usualy leak air and drip ink ck for stains under print head. cartridge has used blotter also drips. Cheaper cartridges contain less ink, no free lunch. Fill it yourself 1 or 2 times and do it right. Put the printer in your shower for twenty minutes if you see excess leaked ink. Allow to air dry for a few days then install new cartridges. Run all the Nozzle checks and print head utilities. Touch nothing else on the inside. This will fix it or f@#%k it up for good
Jan 04, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My printer deskjet f2100 is showing a paper jam (red light showing on control panel) how do i fix it?
folow the steps below 1. Check for and remove any paper stuck in the paper in tray
2. clear the paper jam from the back of the printer
a. unplug the AIO
b. Press in the tab on the left side of the rear door to release the door. remove the door by pulling it away from the AIO
c. gently pull the paper out fo the rollers
d. clean the rollers with a lint free cloth that is moist with distilled water
3. Lift the front cover and slowly remove any jammed paper
a. unplug the power cable
b. if necessary pull the input tray down to open it. then lower the print cartridge door
c. gently pull the paper out of the rollers
d. close the print cartridge door
e. plug the power cable
4. Verify that the print cartridge carriage can move freely
b. check to see if the print cartridge carriage can move freely from one side to the other.
c. remove the print cartridges
d. gently move the print cartridge to tyhe far right of the printer
e. remove the paper from the paper in tray, but do not remove the drawer
f. remove the rear acces door
g. with your fingers rotate the rollers "up" three full rotations
h. close the rear access door
i. replace the print cartridges
j. plug the power cable
k. turn the power on
5. reload and test the printer
hope this helps
Nov 14, 2008 | HP Office Equipment & Supplies
Epson Stylus Photo R220 InkJet Printer Logo
29 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
