Question about HP iPAQ H3835 Pocket PC
3835 charge light
The light on my 3835 won't change to green even though the new battery is fully charged.
  • HP Master
  • 13,433 Answers
Does the pda work fine otherwise just no light when the battery is supposed to be full?
Posted on Jul 31, 2008
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
Swissgear rechargable lantern won't light up, even though the green led light indicates it is fully charged
There are several different models of the Swiss Gear rechargeable lantern. On most though, you can remove the top portion of the lantern and check the lighting element inside. In most cases the elements can be removed and replaced. I have a dual filament lantern and from experience I know that every so often you may have to go buy a replacement light piece. If the lantern has been bumped or even just strapped to the outside of the pack while walking, it's possible for those elements to become loose and need repositioning or replacement so do check that. I'm sure that it should be unlikely your charger is malfunctioning unless you left it plugged in for some very extended period of time, in which case I would say the light would be more likely to burn out. But definitely try that and if that doesn't work the battery pack on the lantern itself may have an issue in which case you can always get a replacement.
Aug 29, 2012 | Camping, Backpacking & Hiking
Battery light won't change colors, drops to 0% once unplugged
Let the battery completely discharge all they way and let it sit for a day or so. Some times when a battery is new most user do not let it fully charge and then completely drain this causes problems for long use batteries. Then give it a try. It also sounds like your plug your cord that connects to the battery may be faulty. Did you by a different cord with the battery? Or use the one from your old one? If you did. This is a "No No" always buy the cord that come for those battery since they are rated for the particular battery.
Feb 25, 2012 | Fujitsu LifeBook A1110 Notebook
My Samsung ES63 camera won't turn on even though it's fully charged. It makes a weird bleep instead.
did the camera sustain any drops or water damage?
if not then i would recommend to take it back to the manufacturer and request a refound for the defective equipment.
Jan 31, 2012 | Samsung DigiMax Cameras
When I plug in the adapter to the charge the consol the orange light lit. The light does not turn off even after 13 hours of charge. After 13 hours when I want to use it, the red light comes on not the...
Hello there. You may need to replace your battery pack, as leaving it charged for over 4 hours can lead to "overcharging" a condition which can dramatically shorten your battery packs lifespan and charge retention.
Also, be sure to charge your console while the device is turned off. Although you may charge it while it is powered on, it will take longer.
As stated, be sure not to leave the system on charge for more than 5-6 hours, as this can damage the battery and is liable to cause battery leakage, burning, or overheating.
Battery life is largely dependent on the game being played - some games can give you up to 10 hours of battery life, though the real-world estimate is really more like 5-7 hours of constant use before you'll need to recharge.
I hope this helps you. -
May 11, 2011 | Nintendo DS Lite Console
Green battery light on the archos 5 but when i disconnect it from dock or usb no green lights abd completely dead - won't switch on either in dock or out???
Power green LED light should come on, CHG green LED light should also come on showing the battery is being charged. Leave your unit in Suspend mode while charging it, DO NOT turn it completely off as "Shutting Down.." because it will not charge your battery.
I just purchased an almost new Archos 5 on eBay recently, and the first day I had it, happened to me that I left the unit off and charging on the Mini Dock with external AC power supply, after 13-14 hours the CHG light still wasn't blinking. Then I though maybe I have to leave the unit in Suspend mode rather than completely off, which I did, and in a matter of 3 hours it fully charged the battery.
Again, do not shut down completely the unit, leave it on Suspended mode, or even on, and connected it to your mini dock, after a while the screen will go blank the unit will go into Suspended mode by itself, and after 3 hours on external power supply or 8 hours via USB on PC should be completely charged and your CHG light should be blinking, indicating the battery is charged.
I hope this helped.
Mar 10, 2010 | Archos Internet Media Tablet MP3 Player
Bettary problem or adaptor problem?
ac/dc convertor board inside laptop faulty.
May 31, 2009 | Dell Inspiron 1300 Notebook
My son's nintendo ds won't come on even though it is fully charged. The light turns green then it just turns off.
This situation is most likely battery related.When a rechargeable battery is used, each charge, the capacity is slightly decreased. I would strongly recommend getting a new battery.
Feb 18, 2009 | Nintendo DS Console
Microtek Inverter not fully charging the batteries
xenion pure shinewave inverter not charging fully
Jan 17, 2009 | Computers & Internet
Battery not holding charge
I had the exact problem as the other two above but resolved the situation as follows: I connected the battery to the charger and switched the power on. The charge light on the battery glowed 'red' as it should and some time later, not as long as it should have been, the light changed to 'green' indicating it was fully charged. At this point I removed the charge lead from the battery and then replacedit. The charge light reverted to 'red' again. When it eventually changed to 'green' I repeated the above step and did so for the next 18 hours. I then connected the battery to the player and played a dvd 1hr 55min film. It worked fine. I hope the solution works for yuo!!
Nov 24, 2007 | Mustek MP72 Portable DVD Player
HP iPAQ H3835 Pocket PC Logo
200 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
