Question about La Crosse Radio Controlled Watch
Replacing battery How do I release the clip which holds the battery in place. wt-961(b)
    Problem Solver:
  • 5 Answers
Go to this site below and print out the manual. It gives their recommended way of doing it. If that doesn't work, it even gives a phone number to call and email address to write to..
http://www.lacrossetechnology.com/967s/manual.pdf
Posted on Mar 09, 2009
How does one replace the battery used to power timex rush T44361
Hi Debra, yours might be similar to my IronMan watch...... 4 small Philips head screws to remove then back comes away to reveal a sticker that has 2 clips either side, use a safety pin point to release the clips and the battery comes off with the sticker! The battery is placed with the total flat side upwards! Hope this helps!
Nov 01, 2014 | Timex Indiglo Watches
How to change battery watche
Remove the back cover of the watch. You probably do not need a special tool to do this. The battery is likely right on top, held by a metal clip. Note the "polarity" and orientation of the battery, i.e., which end is up (take a picture, if necessary). Carefully remove the battery by gently prying up the clip that holds it in place. The battery type is engraved on it, and you will need to get a replacement of the same type or an exact equivalent. You could purchase one on-line or from Radio Shack.
With the replacement battery in hand, insert it back into its cutout within the watch mechanism, again gently prying up the clip. Make sure it's oriented the same as the original battery. Replace the watch back -- you may need to press down to make it click into place.
Sep 10, 2014 | Casio Watches
How to replace a vestal zr3 watch battery
How did you open the back? Does it pop off or twist off?
Jul 07, 2013 | Vestal ZR3 Silver/Tinted Crystal...
How to set a La Crosse radio controlled watch Model # WT-961(S) 12-24
Go to http://www.lacrossetechnology.com/support/setup.php and choose your watch from the drop down menu.
Unfortunately they do not have any instructions but there is a contact address there where you can get help.
May 09, 2010 | La Crosse Radio Controlled Watch
I want to replace the sr920 battery on my Invicta 4243 watch. I unscrewed the case, to expose the battery, but it is held in place by a plastic tab, a tiny metal clip as well as a lip along the rim...3...
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yourself.
Mar 04, 2010 | Invicta Multi Function Stainless Steel...
How do you unlatch the battery of a timex ironman watch. I have the back open now
You will need to look for any screws holding down a plate over the battery. Sometimes these only need to be loosened and sometimes they have to be removed. Sometimes the plate can be lifter slightly and the battery slide out from underneath. I hope this helps you. Best luck
Nov 19, 2009 | Timex 50-Lap Ironman Triathlon 59221 Wrist...
Garmin Forerunner 50 Battery Replacement
Thanks MarcS_Ca - I've supplemented what you offer with some photographs at
http://gnjmch.com/public/tips/GarminF50.Battery.html
Aug 30, 2008 | Garmin Forerunner 50
Chabging the batterys on the prg 40
If you look very closely you will see that one side of the clip goes nearly under the battery. the plastic there has what looks like a small hole near the metal. It is in fact a slot. use a straight pin inserting it in the slot and gently moving the clip away from the battery. There is bend tension on the clip and it should raise slightly when released. Then use a tweezer grab the battery.
use your tweezer to hook the clip back over th plastic after you insert 4 new batteries.
Jul 01, 2008 | Casio PRG-40T-7 Pathfinder
How do I set a LaCrosse WT-961 (B) watch?
This watch automatically sets itself. I you live in the eastern time zone, you just have to wait for the watch to receive the signal then it will set itself to the correct time & date. The signal is strongest at night between the hours of 10:00 pm & 2:00 am so it normally takes over night to set. Sometimes the weather interferes with the signal so I tell people to give them a couple of days to pick up. Also if you are having trouble receiving the signal try placing the watch by a window. If you do not live in the eastern time zone try these instructions:
Hold down the button for 2 seconds until the time zone abbreviation & zone flash the keep pressing the button until your correct time zone is displayed. Then wait about 8 seconds for the watch to return to normal display. Then you just have to wait until it picks up the signal & sets itself. I hope this helps.
Mar 07, 2008 | La Crosse Radio Controlled Watch
Casio illuminator
Hi, release the small screw and turn left or right remove old battery and replace new one .
Feb 03, 2008 | Casio Databank DB35H1AV Wrist Watch
La Crosse Radio Controlled Watch Logo
306 people viewed this question
Top La Crosse Watches Experts
Starnley Johnwells
Starnley Johnwells
Thomas Perkins
Thomas Perkins
Are you a La Crosse Watch Expert? Answer questions, earn points and help others
