Question about Jenn-Air 34 in. Expressions CVGX2423 Gas Cooktop
Replacement Vale/ignition Switch for Jenn-Air CVGX2324
Saw your soluton on Jun-26 for the ignition switch CVG2324. Where can I get a replacement switch?
Thanks!
  • jdiet Aug 03, 2008
    House took a lightning strike. I am finding all kinds of appliances involved. Just learned that my ignitor doesn't work on my Jenn-air cooktop. Won't click or anything. Only steps taken is to research the net.
  • 59 Answers
The best place that I think has the best prices and customer service is:
http://www.vvapplianceparts.com/
1-800-743-3682
Call them and they will help you!!
Hope this help!
Eddie Rentas
Tupper Lake
Posted on Aug 02, 2008
  • Eduardo Rentas
    Eduardo Rentas Aug 02, 2008
    1-800-743-3682
    Hope this help!
    Eddie Rentas
    Tupper Lake
I have a Jenn-Air downdraft cooktop. My blower fan will not shut off. When I press down on the metal part the knob goes on, it will shut off. Can anyone help?
It appears you simply have a bad switch. Try contacting Jenn-Air or looking them up on the web to find out if they have replacement parts available
Apr 29, 2011 | Jenn-Air JED8430 Electric Cooktop
I saw an answer relating to a problem that has just developed on it's own on my Jenn Air Gas Cooktop regarding a clicking noise. My burner is trying to ignite all by itself and I'm in my bedroom. It's 10...
If you can disconnect the power to the cook-top then do so..this will give you a little peace of mind...it seems like the switch for that burner is defective(eg: stuck in on position)..the switch is an integral part of the control that turns on the gas for the burner..you may need to replace the control assembly..these are available from appliance parts stores and on-line
Jan 22, 2011 | Jenn-Air Cooktops
I have a Jenn-Air cve3400 cooktop. The dual radiant burner doesn't work properly. The inside portion of the burner doesn't work by itself or in tandem with the outside portion of the burner. Is it the...
I just went thru this problem. There are TWO possible switch replacement parts. one is 12002422 and was my correct replacement number.
12002125 was the WRONG part..would not work no matter how you wired it. the failed switch being replaced was part number 7403p406-60. 7403p851-60 will NOT work.
my serial # was 12284711qz
call Jen air customer support and give your serial # and switch part # to get the correct part and diagram... Jenn air changed parts and wiring in the middle of a run.
Aug 14, 2010 | Cooktops
Jenn-air cm200 fan switch replacement part number?
Here is the part number for the switch 74009254
May 08, 2010 | Jenn-Air JED8430 Electric Cooktop
Blown accessory fuse? jenn air cooktop jed8430adb
the unit doesnt have any internal fuses. you have a house fuse blown or circuit breaker that tripped. the fan switch can be found online or from your local parts house and make sure you get the clips to hold it to the mounting tabs.
next time you get ready to work on it, just make sure and turn off the power first as you will touch the metal terminals to the frame again.
Dec 27, 2008 | Jenn-Air JED8430 Electric Cooktop
Jen-Air Gas range Igniter keeps clicking but not starting fire
01/26/09 My wife decided to give our Jenn-Air a good cleaning. With lot's of soapy warm water she pulled the knobs off and washed under each of them not realizing excess water was now running down the inside of each control knob shaft. The igniter immediately began clicking away as it was being shorted by the conductance of the water now inside of the switch. I had to remove the cover (2-screws) to access the control switches but that is all I needed to do do in order to have clear access. Using her hair dryer it took about 5 minutes of warm air blowing down each of the shafts until the water evaporated and the clicking stopped. Wahla. The old Jenn-Air is back to working order again.
Sep 22, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Hob ignition switch keeps on clicking.
Hi
Glad to Help you!!
Take the knob off, them remove the cover that housed the switches, OK, Now, Look at the switch that is continiusly clicking and it will have two wires goin onto it, remove these wires and just lift the sending unit, and inspect it for water, grease etc ect....clean and dry and put back on and try again it should work, if it does not work, then just get a replacement one, they are not expensive, I just replaced two on my Jenn-Air myself and it cost me $25.00.
Hope this will help!!
Eddie Rentas
Tupper Lake NY
Jun 26, 2008 | Cooktops
Cooktop fan switch replacement
1. Turn off the power at the breaker box.
2. lift off the air grill.
3. remove the two screws at the front of the control switch panel (escutcheon)..
4. slide the control panel forward until it disengages, then lift up to expose the switch assembly and wiring.
Jun 14, 2008 | Jenn-Air JED8230 Electric Cooktop
Problem with double burner Jenn-Air JED8430 Electric Cooktop
It's an ignition switch. don't change the burner cartridge.
May 10, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air 34 in. Expressions CVGX2423 Gas Cooktop Logo
299 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
