Question about Nokia 2630 Cell Phone (Unlocked) - Black
Problem with my 2630
The battery was drain and then i charged it in the morning.., when i was opening it, it twll sim card registratio failed andthen it hangs and then the signal was lost ans no service at all.., it was bought last month.., i've been using it for 4 weeks..,
    Brigadier General:
  • 7,752 Answers
Take the phone back to the carrier and get a new one...sounds like a manufacturer fault on the mainboard
Posted on Oct 15, 2008
2630 insert sim
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Jan 15, 2013 | Nokia 2630 Cellular Phone
Nokia 2630 sim card registration failed
that could basically be the problem of your network provider
once try the sim card in another phone for confirmation
Jul 30, 2012 | Nokia 2630 Cell Phone (Unlocked) - Black
Having a restriction code when open it..
i cant get your question clear. you need the restriction code or you need the instructions to enter the restriction to enter the code? if you need the restriction code you can get it here. Onlinegsmunlock.com as soon as you get the codes you can enter it. here are the instructions to enter the restriction code.
1 - Switch on your Nokia 2630 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 2630.
3 - Compose #pw+CODE+1#.
4 - The Nokia 2630 would then display the message "SIM Restriction Off" and will be unlocked!
For Nokia 2630 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 2630
Jul 26, 2011 | Nokia 2630 Cell Phone (Unlocked) - Black
My cellphone, cannot to open because need the PIN NO. THE MODEL IS NOKIA 2630.PLS.HELP ME. HOW TO OPEN.
the following codes are provided by the network operator:
-pin code
-puk code
both of these codes are provided when you purchase a sim card and are usually written on the sim holder or on the provided booklet.
if u have the puk code, then u can enter a wrong pin multiple time and then the sim card will ask you for the puk code which then u can use to unlock the sim.
if u lost both the pin and puk, then the only way is to contact the network operator to give you a new sim card.
hope this helps
Mar 04, 2011 | Nokia 2630 Cell Phone (Unlocked) - Black
Changing sim in iphone cause overheating and rapid battery drain
it is the sim card brother not the charging jack k you must upgrade your iphone version to use the simcard again and prevent rapid battery drain k. or you can change sim either. k
Aug 28, 2009 | Apple iPhone Smartphone
Battery Icon with red line through it? Durring a back up, my Storm turned off and when I turned it back on this battery icon is all I get. I have a fully charged new battery in it now and it still shows...
This usually means the bb and battery got a little wet or has other issues. Try these solutions in order. They go from easisest to hardest. NOTE: If you have an insurance policy on the bb probably best just to take it in.
1. Remove the back cover. Remove the battery and the SIM card. Wait 30 seconds. Replace SIM, battery and back cover. Reboot. Plug in the bb and charge fully.
2. If that doesn't work, allow the bb to remain unplugged but ON for about 24 hours to drain the battery. Remove back cover and battery. Allow battery and opened bb to sit in a dry environment for 24 - 36 hours. Relace battery and cover. Reboot. Plug in the bb and charge fully.
3. If that fails retry step 2 but allow battery to FULLY drain then dry out again.
4. Take in.
Jul 18, 2009 | RIM BlackBerry Storm 9530 Smartphone
Unlock code for my girlfriends Nokia 2630
Ask in the forums in moneysavingexpert.co. There are a few techies there who will give you the details. You will need to tell them your make model and IMEI number. They will tell you if it cannot be unlocked this way-they do not charge-I had my nokias unlocked via them!
Jun 12, 2009 | Nokia 2630 Cell Phone (Unlocked) - Black
My Blackberry curve 8320 won't turn on it just has a battery icon with a red line through it on screen. A new battery was tried and the problem still exists.
3. If that fails, retry step 2 but allow battery to FULLY drain then dry out again.
4. Take in to cell store.
Jun 08, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Blackberry 8310
3. If that fails, try another battery (a friends or one from your cellstore) to see if tat's the problem. If so, (a) retry step 2 but allow battery to FULLY drain then dry out again, (b) buy a new battery for $60 retail or (c) buy a new battery on ebay for a lot less.
4. Take in.
Aug 09, 2008 | AT&T BlackBerry Curve 8310 Cell Phone -...
Unlock nokia 2630
Sorry my unlock code calculator doesn't support your model.
www.mobile2mobile.net
Try there..
May 13, 2008 | Nokia 2600
Nokia 2630 Cell Phone (Unlocked) - Black Logo
63 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
