Question about Haier HDN655E Dehumidifier
The unit will not turn on. Haier 65-Pint Dehumidifer
  • 3 more comments
  • cintronjc Jan 11, 2009
    gutch509, did you by chance find the fuse? I need one as well but can't find the fuse.
  • ALESAN Feb 17, 2009
    WILL NOT TURN ON..NOT LIGHTS...HDN655E MODEL....I CHANGED THE SOCKERS,ETC...IT'S EMPTY..NO WATER...ETC..
    THANKS
    ALEJANDRA
    lecasanchez@gmail.com
  • sunshinetige Mar 03, 2009
    I have a one year old Haier HDN655 and it will not turn on and we tried to plug it into sockets.
  • alcohen May 17, 2009
    My unit has been working perfectly. I had just moved it and turned it on, then decided to switch from High speed to Low. Right after I pressed Low it turned off and will not come on again no matter what. Is this probably a fuse??
  • Richard Raynor May 11, 2010
    When you plug the machine into the supply, do any lights come on?
    If no, check the fuse and try the plug in a different socket.
    If yes, make sure the bucket is empty and any dials and buttons are set correctly.
    And then come back and tell me what you found and I will try to help you further. Cheers, D.
  • 11 Answers
Unplug it. Just open the back up carefully. Don't touch those cute little capacitors, diodes, etc., because they can hold a charge. Look for a glass fuse. Use a fuse puller or grab it with your fingers. Look to see if that little thin wire inside is broken.
If yes, then go to Radio Shack or auto parts store and have them match it by size and amps. Reinstall and plug the DH in to see if that was the problem.
If it blows again, you have other elect problems.
Posted on May 29, 2009
I read some of the other solutions and found the blown fuse, but I am having a hard time finding the 125v-12amp fuse.
Posted on Aug 01, 2008
How many watts is a DE45EJ-L dehumidifier?
There is a review website that claims the unit draws 590 watts. The refrigerant this one uses is R-134a.
Haier 45 Pint Dehumidifier Review
A slightly larger unit is also available from Haier, the DE65EJ that uses R-410a, which is a more efficient refrigerant and allows the unit to be perhaps 20% more efficient. That larger unit is rated for 65 pints a day, and uses 710 watts. It is a bit heavier than the DE45EJ also.
Jul 01, 2014 | Haier Dehumidifiers
Whirlpool Basement Dehumidifer is freezing up about l/3 from the bottom. Compressor will not turn off. Coils were cleaned and cleaned fan is running freely. Sitting in well ventilated area and temp...
IIt may very well be that the the air intake filter needs to be removed and cleaned. But, before doing this, turn the unit OFF & unplug it. Allow the unit to completely thaw, before removing the filter.Never operate the unit without the filter in place, As this could damage the unit.
Hope this helps you & thanks for choosing FixYa.
Sep 11, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
I would like to know the average monthly cost of using a 65 pint dehumidifier if it runs continuously for 24 hours for about 300 days a year
To find the Annual Energy Cost, look in the Owner's Manual or other paper work that came with the unit. The Energy Star rating paper work will have that information. However, that cost does not include routine maintenance cost or any repairs that may arise from running the unit constantly for 360 days. Sounds like you'll be running it in a damp basement.
Hope this helped you and thanks for choosing FixYa.
Aug 06, 2011 | Haier 65-Pint Dehumidifier
I have a Haier 65 pint dehumidifier. When I press the control button to lower the humidity setting, the word On comes up and I do not see numbers lowering.
Let's start from the beginning. Turn the Master ON/OFF Switch to OFF. Unplug the unit for 5 minutes. Then plug the unit back end, and turn the Master ON/OFF Switch to ON. Now, lower the the humidity extraction level to 40%, by using the Arrow Down Button. You will need to lower it by pushing the button for each % setting. DO NOT push and hold the Arrow Down Button.
Doing the above should solve the problem.
Jul 12, 2011 | Haier HDN655E 65 Pint Dehumidifier...
Dehumidifer is on but does not collect water. pail stays dry
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 18, 2010 | Haier 45-Pint Dehumidifier
Unit won't start
its field with water, empty
Apr 07, 2010 | Haier 65-Pint Dehumidifier
Burning smell from dehumidifer
Well is your filter clean!!!! is it over working it 30 pint 400sqft 50 pint 1000sqft 65 pint 1300 sqft. hope this helps.
Jul 19, 2009 | Whirlpool AD25BSR Dehumidifier
Dehumidifier won't shut off
Well your dehumidifer runs constantly. My guess seeing how you bought a 30 pint per 24 hrs. Your house better be 400sqft. It is under sized and humidity need to be 30/50 percent to stop mold growth. It cant keep up its two small 50 pint are for 1000sqft 65 pint is 1300sqft. Upgrade now!!!!!
Dec 29, 2008 | LG DH30 GoldStar Dehumidifier
I just purchased a new Haier 65 pint dehumidifier and inside on the bottom of the unit, it is covered in oil. Of course the unit is not functioning (it runs but is not removing any water).
This sounds to me like a leak in the compressor housing which has allowed the oil and refrigerant to escape. I would take it straight back to the seller and request a replacement unit.
Hope this helps. D.
Jul 16, 2008 | Haier HDN655E Dehumidifier
Haier dehumidifer HD656E
What you think it means is exactly what it does mean. When a running unit is shut off it should not be restarted until the system pressures have had time to balance out so the compressor can restart without difficulty.
Jun 18, 2008 | Haier 65-Pint Dehumidifier
Haier HDN655E Dehumidifier Logo
468 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
