Nic card undetected..how do i unistall spyware
  • Anonymous May 11, 2009
    nic card doesn't seem to be working at all
    Novelist:
  • 202 Answers
For NIC card Go to Control Panel Sytem Properties Hardware Tab in that Device Manager see wheather driver is installed properly or not if it is not installed please install it
To remove u r Spyware go to control panel add remove programs there select spyware and remove it
Posted on Jul 31, 2008
Nic card not working? How to troubleshoot? Is there a plug and play nic card that can be installed onto this desktop PC?
Hello Sqis,
You can purchase any nic card which is compatible with WinXP or 7.
Insert the card in PC Slot of the motherboard.
Install the driver for the card and it will work.
May 05, 2011 | HP Compaq Presario SR1650NX...
Hi everyone, my dell 4500 wont connect to the internet. says it cannot find a network drive card. what should I check?
1. check and make sure your network cable is connected.
2. check to make sure the network card shows up in the device manager.
3. If it does not, remove and replace it and try again.
4. check and make sure that the drivers for the nic are installed.
5. Of course, always check for viruses/spyware etc.
good luck and let me know.
Aug 13, 2010 | Dell Dimension 4500 PC Desktop
I am using windows XP, when i insert a network connection on the NIC port, the right NIC light blinks yellow instead of Green, repeatedly a message says a new hardware is detected and fails to install. i...
The yellow light means that it's not connected with a compatible driver to the computer or it is not connecting to your network for some reason.
Green, means everything is, ok.
I've encountered this before on some off brand network adapters, and tried other ones, and that was the only way I could make it work...
in an unknown system.
However, since you say that yours worked before... that tells me that you think it should work, again. But, something could have changed in your network.
Are there any other components on your network, like a switch that could have gone bad, or bad wiring?
Jul 28, 2010 | Dell Ethernet Card Network Adapter
Installing NIC card to dell optiplex gx100
NICs usually come in PCI interfaces. motherboards have usually four PCI slots to hold many devices such as NIC. just slide the card and fit it into the PCI slot. It could take any of the slots where it fits. the OS will detect it and loads the necessary drivers.
Aug 28, 2009 | Dell Ethernet Card Network Adapter
My memory card on Nokia 5610 gets undetected every now and then. If I copy music or do anything with the memory card on the phone, it becomes undetected and it starts all over again !
insert the memory sitck into the phone and click on format option in u r mobile phone after completing download music to the card from computer. if u r card is not iserted properly see the phone socket is good or damaged
Aug 13, 2009 | Cell Phones
R300 2nd NIC card "No driver installed"
I saw this a couple of months ago...let's see if I can remember:
In our case we even added a third nic (pci) and it wouldn't work
First, it is possible that the new mainboard has a different chipset on the nic than the last one. Check the driver d/l site for alternate drivers or Contact Dell support to be sure the right driver is in place.
Regardless of how secure your systems may be, please scan with the following three free excellent products:
malwarebytes antimalware
superantispyware
asquared free
Also, does the nic work if you slow it down or on auto?
I think it was malware in my clients' case. Get back to me if still ng and I'll ask their sysadmin if she remembers.
Aug 11, 2009 | Dell PowerEdge R300 Server
Dell 4700 Computer Integrated NIC Problem
Check for the pins inside the integrated NIC to check if the pins are bent / disfigured. Does not look like the additional card is making any different, looks more like a moving NIC cable is makin the difference.
Lemme know if this helped!
Dec 13, 2008 | Dell Ethernet Card Network Adapter
Ibm netvista 2257-32u
First off I would troubleshoot the NIC onboard, but if it is not working then you should have an available PCI slot to install a new NIC. However you will also have to disable the onboard NIC in the BIOS.
If you are using windows
Click --Start --run-- type in cmd and hit <enter> (this will bring up the dos box)
then type ipconfig /all
It should come back and show:
Connetion-specific DNS Suffix : xxxxx.xxxx.com
Description: Brand and type of NIC
Physical Address : xx-xx-xx-xx-xx-xx
DHCP Enabled: yes or no
AutoConfiguration Enabled: yes or no
IP Address: xxx.xxx.xxx.xxx
Subnet mask: xxx.xxx.xxx.xxx
Lease Obtained: date when it connected
Lease Expires: date when connection expires
Default Gateway: xxx.xxx.xxx.xxx
DHCP Servers: xxx.xxx.xxx.xxx
DNS Servers: xxx.xxx.xxx.xxx
If all this is showing correct then try typing ping 127.0.0.1 this will be the NIC itself and it should reply back. If not then do the following.
If it does not show up then check device manager and see if the NIC is disabled.
if it is disabled try reenabling it.
if it is not unistall the device and then reboot the PC it should find the NIC and install it.
if all this fails then replace the NIC
Oct 30, 2008 | IBM Computers & Internet
Internet connect is not working
It could be a problem with the card or port itself, but it could also be a problem with the drivers. Check to see if the proper drivers are loaded for your network card - for example, if there was a recent network driver update download from Microsoft, uninstall it.
If this is not the case, try unistalling the drivers entirely, and then reinstall them from a fresh copy either from the original CD or downloaded from the vendors web site.
If that does not help, it could be a problem with Windows - I'm guess it's Windows XP? If something has messed up the TCP stack, Dial-A-Fix would be able to rebuild the stack for you.
If none of these help, then a physical failure is probably the problem. You could then replace the NIC (network interface card), or if onboard (that is, part of your motherboard and can not be removed), disable it in the BIOS, and add a PCI NIC card to the machine.
Jan 27, 2008 | Dell Dimension 2350 PC Desktop
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
