-   The shaft on the motor broke can it be replaced?-   Guest
Aug 16, 2008
-   I have the same problem....Plastic U Joint broken...can't find any part to repair. Oh dear....may try to improvise with some plastic tubing cut to length maybe. Anybody out there know where to get this parrt without buying the whole armature shaft? The Dremel parts list doesn't show this plastic part as being available separately.-   Beechtree
I use heat shrink and found one that was larger and cut it down to less than an inch. I heated it with a lighter enough to fit the same size over it. and then heated that one enough to slip inside. I did one more so I ended up with 3 of the same heat shrink tubing (pink) and covered over both of the shafts and heated the whole thing so they all sealed and made a connecting shaft. In a pinch it worked well and never had a problem. there is a picture attached.
I had the same problem. It looked like the original part was surgical tubing. I used a 1 inch long piece of 1/4 inch ID TYGON tube 1/16 wall. Works great so far..
My Dremel is about twenty years old (model 285-3) and the plastic connecting piece crumbled with age. I called the Dremel company and gave them the part number from my parts list. The part is called a flex chuck, however I do not have the new part number. The person answering the phone knew what I needed and for about a dollar plus $2.00 shipping, I should be able to repair the Dremel like new.
pc crash during wm6.1 flash..
my 6700 appears to be in real trouble. it has a black screen with...
(More)
PC CRASH DURING WM6.1 FLASH..
My 6700 appears to be in real trouble. It has a black screen with faint latters saying "serial v1.00" and it will not respond to either a soft or a hard reset. I also removed and re installed battery,still no luck.. Windows xp does detect the phone,but activesync does not. the phone cannot be powered on,other than seeing the black screen that say serial v.1.00.. So i desperately need help QUICKLY..Please help me..Thank you
I am having a problem with calls breaking up for the last one month with my Blackberry 8820 cell...
(More)
I am having a problem with calls breaking up for the last one month with my Blackberry 8820 cell phone. All of a sudden in the middle of the call there is a lot of weird sounds in my phone and I cannot hear the person that I am talking to nor can they hear me.
