Case resetart evry tim - Computers & Internet
No map on tomtom blind
Posted on Mar 23, 2009
    Novelist:
  • 202 Answers
Then problem with u r RAM because its a Hardware problem remove the CPU cabinet cover remove Memory Module and just reinsert it and just check if it works properly if it is not working then replace the same type of Memory Module i.e, RAM with a New one
Posted on Jul 31, 2008
Need help with timming on camshaft timming on a artic cat prowler utv
There should be dot marks on the gears which line up with marks on the case,or you can Google your request,and a video will show you how it's done.
Sep 28, 2016 | ATVs
120cc stomp brand new engine backfires evry kick help
this sounds like a timing problem reset your timming if this still happens you inlet manifold may be letting in air it could also be the carby letting air in ,check these by running the bike and use some aero start around the fittings while running if it revs up abit then you have found it but ,take extreme care doing this as could result in fire ,you could take the manifold off and redo and carby but first try tighting all of it ,if you try the aero start it only needs small amounts but being a new motor i would go for tighting and undoing and retrying. hope this helps
Dec 22, 2013 | Motorcycles
2001 ford excursion 4x4 troubleshooting
the transfer case shifter linkage may be loose or binding. Check the shift fork for signs of cracks or wear.
Damaged internal gears or viscous coupler prevent the transfer case from shifting into "4-low" or "4-high" drives.
and in evry 15000 miles need to change oil.
Jan 28, 2012 | 2001 Ford Excursion
Hotfix for nokia 5230
Thank you for asking us a direct question, but our specialty is headsets, not phones, so we cannot help you with your problem.
Good luck from Headsets Direct!
Dec 23, 2011 | Nokia 5230 Cell Phone
I have connection problem,,the connection go evry 10 minutes,,i change the router and the same problem,,the light of internet shut down evry 8..10..15 minutes
You can try reset the router if you are using one by pressing the reset button on the back or bottom of the router which might be in a little hole in which case you will need a pen or paper clip or something. If the issue persists, restart your modem, get a solid state and restart your router, get a solid status and restart your computer is necessary. You can check the settings of your router and see whether it is using DHCP, make sure your computer is not running a DHCP server kind of application. You might also need to contact your ISP and make sure your account and their connections are fine. Sometimes it may happen for high volume of users or some firmware installation on your modem.
Oct 24, 2010 | Toshiba Satellite A100-S8111TD Notebook
I have a 2002 dodge stratus..the timming chain was
Something is obviously not proper in the timing case.
Pick up a Chilton's manual,which should give you all the info needed,to rectify your situation. Good luck.
Apr 01, 2010 | 2002 Dodge Stratus
Hey i was using my sidekick id today as i notice i can not go on the internet so i try every way to turn the internet back i called t-mobile n everyone with a sidekick is having this problem so im trying...
T-mobile did have a global network outage the other day. The data plan was pretty worthless to eveyone off and on all day. Nothing much you can to do solve the issue except resetart your device and see if it reconnects.
Oct 03, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Cant find where to plug in crank sencor plug I unpluged it during timing belt replacement cant locate it anywhere
it should run up on the timming case cover unless its been tucked in behind the timming cover
Apr 07, 2009 | 1994 Toyota Camry
Trouble opening pc desktop
Its seems like a virus activity. I think your pen drive was infected by any virus and that virus crashed your system. Try to scan your system by any anti virus and see the results.
Thanks
Iqbal
Mar 24, 2008 | Computers & Internet
Connection problem
You can do one of two things. First you can change the settings of the router, using whatever computer you intalled the software on. Or you can change the settings on your computer, so that it will allow this behavior.
Hope this helped!
Jan 16, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
175 people viewed this question
David Payne
David Payne
