Question about Compaq Armada E500 Notebook
My laptop wont boot
Everytime i try to boot it after the compaq logo it goes to a screen that says "GNU GRUB version 0.94" so what do i do to get my laptop to boot.
  • 4 Answers
How long does the screen display that quote? Sometimes Linux will lock up completely at boot, but usually it will give a message such as "kernal panic" if it does; in your case, if the GRUB boot-loader is failing to find a kernal to boot, you may not have a valid boot-loader configuration file or installed operating system. Or, you may just need patience.
I suggest you try booting from a Live distro disc, such as Ubuntu (DVD), SuSE (DVD), or Damn Small Linux (this is probably the fastest, at only 50 MB) or DSL's Not Damn Small Linux (CD) which still has pretty minimal hardware requirements but includes more tools. Even DSL should let you view the files on your laptop's hard-disk drive and edit configuration files if there are issues.
Posted on Aug 01, 2008
How do i get to recovery mode for ubuntu?
  1. Switch on your computer.
  2. Wait until the BIOS has finished loading, or has almost finished. (During this time you will probably see a logo of your computer manufacturer.)
  3. Quickly press and hold the Shift key, which will bring up the GNU GRUB menu. (If you see the Ubuntu logo, you've missed the point where you can enter the GRUB menu.)
  4. Select the line which starts with "Advanced options".
  5. Select the line ending with "(recovery mode)", probably the second line, something like: Ubuntu GNU/Linux, with Linux 3.8.0-26-generic (recovery mode)
  6. Press Return and your machine will begin the boot process.
  7. After a few moments, your workstation should display a menu with a number of options. One of the options (you may need to scroll down to the bottom of the list) will be "Drop to root shell prompt". Press Return with this option highlighted.
  8. The root partition is mounted read-only. To mount it read/write, enter the command
    mount -o remount,rw /
  9. If you have /home, /boot, /tmp, or any other mount point on a separate partition, you can mount them with the command
    mount --all (This must be done following step 8 so that /etc/mtab is writable.) Alternatively, you could try selecting "Enable networking" in step 7, though this has been found to cause the system to hang (see https://bugs.launchpad.net/ubuntu/+source/friendly-recovery/+bug/981792).
NOTE 1: If you have Ubuntu Quantal (12.10) or earlier, omit step 4 (the recovery mode menu items are displayed on the top-level menu).
NOTE 2: If you reboot, there is no need to hold the Shift key in step 3. The GNU GRUB menu will continue to be displayed automatically on each boot until a normal startup of Ubuntu completes. To configure GRUB so the menu is always displayed, even after a normal startup, see https://help.ubuntu.com/community/Grub2/Setup.
Oct 16, 2013 | Compaq Computers & Internet
What is GNU grub?
The Grand Unified Bootloader (GRUB for short) is a program developed by the GNU software foundation. This program allows your Windows machine to load a number of different operating systems by presenting the user with a choice when the machine boots. This allows you, for example, to have both Linux and Windows XP installed on the same machine. If you find that you need to restore your XP system to a previous state and want to remove GRUB from your Windows XP, the process can be done in just a few minutes.
Ensure that your computer can boot from the CD/DVD drive. Start your computer and watch the startup screen. It will flash the key combination you need to press to enter BIOS. Enter this key combination and go into the system BIOS. Look under "Boot Options" or "Boot Order". Select "Boot from CD/DVD Drive" and make sure that it is listed as the first in the boot order. Save your changes before you exit the BIOS. Open the CD/DVD drive and insert your Windows XP install DVD. Reboot your system. Press "R" for "Recovery Console" when the "Welcome to Setup" screen appears. Enter the administrator password. At the prompt, type the following command: fixmbr Allow the XP system to recover the boot sector. When finished, it will return you to the command prompt. Type:exit Reboot your XP system. Hope this helps.
Dec 30, 2012 | Computers & Internet
Compaq laptop not full booting up
Is there a compaq logo coming up on the screen? "very important"
Apr 23, 2012 | Compaq Computers & Internet
Hi i have a compaq presario laptop and after it stars up the screen just goes blank
do you still see the compaq logo and does it show you the windows boot up screen before it goes blank?
OR
do you see anything on the screen at all after pressing the power button?
Check if the laptop is receiving power. If it has power and you can't see anything on the screen it could mean that the LCD assembly or the Video card of your laptop is bad.
If it goes to the compaq screen and then to windows logo before going out, try booting into safe mode and once there uninstall the video driver from the device manager because that means the resolution was set to something higher than the display could handle.
If it restarts after showing the compaq screen try reseating the memory, hard drive and wireless card of your computer put them one by one and try turning the compter on after each part you put back to check which component is point of failure.
Otherwise you have a bad motherboard and it may have to be replaced.
Hope this helps!
Jul 27, 2011 | Compaq Presario 700 470024-192 Notebook
Pc linux OS reboot loop
It might be cause by The MBR was messed up by a bad grub install. You can try to fix the grub.
If you want to try reinstalling grub, boot from the live CD, log in as root, open a Konsole window, and at the prompt, ([root@localhost ~]#) type;
[root@localhost ~]# grub <Enter>
GNU GRUB version 0.97 (640K lower / 3072K upper memory) <-- This is the output from grub after <Enter>
[ Minimal BASH-like line editing is supported. For the first word, TAB
lists possible command completions. Anywhere else TAB lists the possible
completions of a device/filename. ]
grub> <-- The grub prompt.
From the grub prompt type;
grub> find /boot/grub/stage2 <Enter>
(hd0,0)
(hd0,4)
(hd0,5)
(hd0,9)
(hd0,11) <-- You'll only have one, use it
(hd1,0)
(hd1,2)
(hd1,4)
grub> root (hd0,5) <Enter> <-- Use what showed up above for yours
Filesystem type is ext2fs, partition type 0x83 <-- Grub reports both ext2 and ext3 as ext2. Don't worry about it.
grub> setup (hd0) <Enter> <-- That is a zero (hd0), not a letter
Checking if "/boot/grub/stage1" exists... yes
Checking if "/boot/grub/stage2" exists... yes
Checking if "/boot/grub/e2fs_stage1_5" exists... yes
Running "embed /boot/grub/e2fs_stage1_5 (hd0)"... 15 sectors are embedded.
succeeded
Running "install /boot/grub/stage1 (hd0) (hd0)1+15 p (hd0,5)/boot/grub/stage2 /boot/grub/menu.lst"... succeeded
Done.
grub> quit <Enter>
Your done; grub is reinstalled
P.S.: If this information was helpful, please rate this solution.
Dec 06, 2008 | fedora Linux Operating System
Compaq armada e500 boot up
Try tapping the F5 or F8 key (could be either one) right after you power up. This should take you to a short text message with a couple of choices to continue; you'll find the Safe Mode option there which will prevent the continuation of the unsuccessful boot routine. If you can reach the Safe Mode, run Restore and go back to an earlier point in time, you may have to go back several times because if you have picked up some kind of malware, it may have been backed up with everything else.  Unless it is a really smart bug, you might be able to circumvent it.
Aug 22, 2008 | Compaq Armada E500 Notebook
Dale
u can try to reinstall grub loader, with a linux cd .... (there is the danger of losing all u're data) To avoid that u can try booting with a linux "Live CD" version, to try and save u're work , and also try to diagnostic the drive ....
Jan 19, 2008 | Computers & Internet
Compaq Armada E500 Notebook Logo
119 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
