Question about Acer Computers & Internet
Acer aspire one running linpus lite is missing HAL and audio/ usb drivers. Also the keyboard doesn't work
  • 1 more comment
  • maharajaMD Jul 31, 2008
    well my audio devices start up as dead and don't work untill half an hour later. The keyboard is totally whack. Capital M does work but not common M. I have a live cd with the aspire and it has not done much for the situation
    Being a UMPC it has no drives for cd's I am trying to find something big enough to store a copy of the livecd but if I send it in... the change in operating system would most likely void the waranty. I think that it is software based or keyboard cable based because it was working until I installed the updater update , but the provided cd seems to have crippled the preloaded linpus (it was only after
    a software install to undo the update that HAL could not initialize) .
    That being said it went back to the orriginal set of non working keys (I had someone who is good at computers open it up and check the keyboard cable). They said there was nothing wrong with the cable (maybe it is defective)?
    Well I have no idea if it's software based or if it's a loose cable for the keyboard. It could be a loose cable because the keys affected changes and for a period it did work like normal (it was just a bit laggy then i.e. when i typed M it was slower in appearing on the screen then say q).
    It could be software because well the acer technical support department said that they were having issues with the aspire one and some of the live updates pertaining to keyboards but he mentioned the language select feature that is working fine on mine . Also I had someone technically capable of fixing computer innards and they said the cable was fine (at least they claimed to have fixed it). It worked for about 2 hours untill I installed an update for the updater (wow that is a tongue twister) it stopped working again. Now there solution was a software restore which actually damaged my OS because after I restored it said HAL could not initialize.
    That being said if i plug in a USB keyboard there are no problems. I'm gonna send it in to Acer.
  • 981 Answers
Wow, sounds like you should get in there and config it.  Boot up a liveCD that loves your Aspire One (not Generic All Acer PC Desktops, thanks,) like Linpus Install or Knoppix, and have a look at /var/log/messages to see what it's problem is; then put it back to working order from whatever changed.
What makes you think HAL and audio/USB drivers are missing?  Are they not compiled into the kernel?  Versions and context, please....
Posted on Jul 30, 2008
  • Steve Nordquist
    Steve Nordquist Jul 31, 2008
    Suppose you try to get into the BIOS; is there anything distinct, or is that Linpus just the same?  I suppose if it were distinct, at least being able to use the keyboard in that would let you boot other LiveCDs (which would permit typing properly if the hardware were working.)  That M alone works is confounded, especially if nobody sat on the thing (destroying the keyboard membrane.)  Maybe you have a particularly heavy pet cat....
    The audio situation sounds like the common situation where some daemon takes up all the CPU and when kernel-cpukilled, the backup audio daemon works fine.
       So I suppose one thing to try would be getting another keyboard on there so you can work, and/or testing which ports (having opened up the thing) actually work.
Aspire one AOA110 keyboard problem with Fn keys
Hook external keyboard to your laptop, if okay! the internal keyboard on your computer will need to be replaced to fix this problem.
Mar 31, 2012 | Acer Aspire Computers & Internet
Trouble downloading drivers to run epson stylus sx405. I have a linpus linux lite v1.0.13.e. I have tried various sites to download drivers to run epson stlylus sx405 printer but they either dont work or...
go to the epson site europe http://esupport.epson-europe.com/ProductHome.aspx?lng=nl-NL&data=0ccCGROWIYN+1EDmLfiRnFqrivpAKZGzLmve3Fq2b00U003D&tc=6
adnd you see drivers and also other software for the printer the first section have the scanner driver and also printer driver the other are Creativiteitssoftware and the last section have epson web to page and icc software figure out in the first way you need the first part of drivers thad are you need
Dec 13, 2009 | Acer Aspire One AOA110 Linpus Lins Lite...
Acer Aspire 5100-USB, Touchpad, keyboard all quit working.
Bad motherboard or a failed attempt at a bios upgrade/flash
Jul 21, 2009 | Acer Aspire 5100 Notebook
Cant get into the network center on my acer aspire 1 ,
If this is an aspire One with linpus lite linux,
The network center disappearing is an issue with the linux update server that seems to corrupt the OS.
The solution unfortunately is to reload the OS from the recovery disk.
The aspire ONE does not come with an ODD so you will need to use the disk on a unit that has an ODD to make the recovery USB flash drive.
You will need a USB flash drive that has at least 2GB of storage, a computer with an ODD, and the linpus recovery disk that came ywith your unit.
1. Boot to the linpus disk, one of the options should be to make a recovery USB drive, make sure that no important data is on this USB drive as it WILL be formatted and erased.
2. Follow the on-screen instructions and then insert the recovery flash drive in to the USB slot of the Aspire ONE.
3. Re-start the Aspire ONE and press F2 to go in to setup.
4. Change the boot order to boot from "USB HDD" and press F10 to save and exit.
5. Unit will reboot and recovery will start.
Jun 26, 2009 | Acer Aspire One PC Notebook
Working msn on acer one- Linux linpus lite
hi there,
try instant messaging program called Pidgin,
its easy and good and have certain features
you can use msn, icq, aol etc.
i hope it will work for you.
Mar 23, 2009 | Acer Aspire One Netbook 8.9" Notebook
Linpus for Aspire One
you probably won't want linpus
i don't think there is one specifically for the aspire one
and if you download a different one it won't work any faster then the xp
Jan 28, 2009 | Acer Aspire One PC Notebook
My acer one aspire
I use linux on my Aspire one but not Linpus Lite There is a known problem with the acer one switch. so you may want to try blacklisting the acer_wmi module and you mey have to change your wireless driver. try running NetworkManager in shell and see if it will give you any errors. My wifes Netbook has a similar problem She has the same linux i do. As far as getting NetworkManager to start automatically i'm not sure you may have to add it to startup applications but again i'm not sure about linpus and how it looks.
Jan 23, 2009 | Pacific Digital (U30274) DVD±RW...
Aspire One runs too slow for Win program
Honestly, you may want to not run Windows.
Linux has all the necessary programs and utilities to run Windows programs. You just have to find them. Goto: www.download.com and click on the tab for Linux Search there.
OR
Just wipe the entire harddrive with a Windows Disc Master install. This option will begin when you place the windows disc in the CD Drive and do a boot up from the CD drive. It will ask you if you want to format harddrive and say yes to that. After windows is properly installed, reboot again, see if all the ports, keyboard, mouse usb's jacks work properly, speakers, etc. If not goto the Aspire website and goto support and download all the drivers for your model.
Thanks,
Mark
Dec 31, 2008 | Acer Aspire One AOA150-1570 Notebook PC
Install Sierra Wireless 595U on Acer Aspire One Linux
I did get my 595u to connect but need to solve some more problems.
First setup the right click menu as described in http://www.reghardware.co.uk/2008/09/05/ten_aspire_one_tips/
Then update software with software updater.
I installed an update to hal-info that may be needed. Search for hal-info and fc8and download the latest (or later than 200803) rpm. Usually select the title in rpmfind to download the rpm. Save it to Documents. Next open a terminal with the right click menu.
Change to the Documents directory 'cd Documents' ( hint type "cd Do<TAB><ENTER>')
List files - 'ls'
Should see the hal-info....rpm file
change to root
su<ENTER>
-- enter setup password --
Install the rpm with
'rpm -Uvh hal*rpm'
Should see success.
Next Right click -> System -> Add/Remove Software
Enter password
Check Development ->Development Tools
May need to uninstall gettext (to replace lw version with fc8 version) with
rpm -e gettext
Then go to http://www.sierrawireless.com/faq/ShowFAQ.aspx?ID=1235 and download and download source code. Here is where I had trouble . Linpus did not include headers or module Make files. Another kernel fc8 tree was available. I booted into the fc kernel by editing /boot/grub/grub.conf and setting default=0. This break file manager. I will try to obtain linpus kernel build info and try again.
Nov 08, 2008 | Computers & Internet
Fix high definition audio decice acer 5610
i need the Intel 82801G (ICH7 Family) High Definition Audio Controller (rev 02) driver for my acer 5610z notebook please
Apr 25, 2008 | Acer Aspire 5610 Notebook
Computers & Internet Logo
564 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
