Uniden Cordless Phone Logo
Posted on Mar 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I change the outgoing message. I Have Omega 2080
Anonymous
Level 2:
New Friend:
  • Expert 47 Answers
  • Posted on Mar 07, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
47
Questions
0
Helped
12737
Points
152
P.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Arial; color: #1a1a18} p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 9.0px Arial; color: #1a1a18} span.Apple-tab-span {white-space:pre}
1) On the phone base, press and hold "greet"
2) The phone will say "record greeting"
3) WHen you finish recording your greeting, press "greet" again or the Play/Stop button (A triangle and a square)
The phone should now play back your greeting.
You can download the entire product manual here: http://www.uniden.com/pdf/DECT2080-2om.pdf
Fax information is incoming but no outgoing,
if its doing this with only certain senders it is possible the sender is scrambling their fax number. If so look in setup menu or tools and patiently study the settings.
Change outgoing message
Usually, the voicemail message is stored in the voicemail system, which is handset-independent. Call in to your voicemail (usually hold down the 1 key or look for the key with the envelope and hold it down - it will dial your voicemail account) and follow the prompts to set up your mailbox, and "change your greeting."
1helpful
Uniden omega 2000 & 200 (my model : OMEGA 2080)
http://uniden.com/index/manuals_results.cfm
1helpful
http://uniden.com/pdf/EXAI4248om.pdf
Nseed to reset message on answering machine
There are two models - The TRU8885 and the TRU8885-2 -
For the TRU8885 the manual PDF form >>>Click Here<<<
The solution is on page 24 + 57 It starts on Pg 24 as...
Record Greeting allows you to record a personal outgoing message (greeting) which
the answering system automatically plays when you receive a call.
1) Enter the Answring Setup menu, and then the
Record Greeting sub-menu (see "Entering the
Menu" on page 16). To record greeting press
[STA RT] appears.
2) Press the START soft key. You will hear “Record Greeting.“ The message counter
displays 30 and then begins to count down.
3) Position yourself near the base microphone and record your greeting.
4) When you are finished recording, press the STOP soft key. Your greeting will
playback for confirmation.
Selecting Your Greeting (Base only)
Select Greeting allows you to choose between the two outgoing messages, a prerecorded
message or your own greeting.
1) Enter the Answ. Setup menu, and then the
Select Greeting submenu (see "Entering the
Menu” on page 16). P lay back greetin g
appears, and the current outgoing message is
played. LCD is an example if you recorded your greeting.
2) Once you have recorded a personal greeting, press the CHANGE soft key to
choose the greeting. The selected outgoing message is played. Each time you
press the CHANGE soft key, the phone switches the outgoing message between
the prerecorded and the personal outgoing message.
There is more on the PDF - Just ask if you need more
For the TRU8885-2 is essentially the same. The manual PDF form >>>Click Here<<<
If we need to dig further, just ask! :) We are just a mouse click away!
Thanks
Len
Omega 2000
If you mean you want to have someone on each of your extensions listening to the same conversation, it can not happen. The reason for this is the first phone to pick up makes a connection with the base. The other phone will not be able to make that same connection as long as the first one is still on.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
