Question about Car Audio & Video
Help!!!! i have a crunch v3400 and when i hook it up the power light comes on and then its switches 2 proctect.is the amp bad or whats the deal?
  • 631 Answers
It's likely that the amplifier has shorted output transistors. To eliminate other possible problems that can cause an amp to go into protect, read through the following page.
Amp In Protect - Troubleshooting
Posted on Jul 31, 2008
Crunch 2000.4 car amp, need help tuneing
re-check the speaker connections are correct and use a matching ohm test speaker on the other connections for a sound check. Sounds like hi frequency output into the sub amp. Sub-woofers are a mono signal!!
Jul 17, 2017 | Crunch Car Audio & Video
Green light (protection mode) on, NO red light (ready)
double check your wires aren't shorting out or power or remote wires aren't grounding. check if speakers are blown with nine volt battery
Sep 05, 2009 | Kenwood Car Audio & Video
My Crunch Amp In My Blazer Has Stopped Working! Please Help!
NO if your amp is good any battery will turn it on. changing batterys does not require a reprogram?. id say amp is damaged from being wet. test to see if power is going in and out if nothing out bad amp..
Jun 01, 2009 | Crunch GP1100.2 GroundPounder 1100W 1/2...
Changed speakers and now red protect light stays on? why?
the sub might have a short or is blown or the ohms are different
Mar 30, 2009 | Crunch PZi1000.1 Car Audio Amplifier
Crunch amplifier
there is a bad ground or some other wiring issue in your car you will have to re wire all new to find it unfortunately
Dec 12, 2008 | Kicker KX600.1 Car Audio Amplifier
Sony explode amp for my car
Try disconnecting everything but the power connections. If the protection light still comes on, then there's a problem in the amp. If it goes out, then there's a problem elsewhere. In that case, hook up one speaker cable at a time and power on. If the protection light comes on, then either that speaker is bad, or you've got too many speakers connected to that one amp output. Too many speakers connected together can cause an overload and trigger the protection circuitry, or worse, blow out something out.
Hope this helps, and please rate my advice.
Thank you, and good luck!!
Feb 04, 2008 | Car Audio & Video
Red LED "Protection Light is on" What is the problem
The red light means the amp is in protection mode. A few things can cause protection mode..... First disconnect the subs completely from the amp, and turn it on, if it powers up you have blown subs. Also try checking the main power wire at the battery...sometimes the current your meter is seeing is backfeeding from the remote wire, so your main power line could be blown at the fuse under the hood. hope this helps
Jul 17, 2007 | Crunch BlackMaxx BMX2250 2 Ch 1000W Amp...
Amlifier not working
connect your remote turn on and your problem will be solved
Sep 23, 2006 | Crunch BlackMaxx BLX2000D Car Audio...
Car Audio & Video Logo
78 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
