Question about GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Water running out
This morning I found quite a large pool of water on our kitchen floor from the fridge. I dried it up and in no time flat, there was more. Finally in the afternoon, I cut the water to the fridge not try and figure out the issue. I'm not a "handyman", but sure would appreciate any help. Also...it's probably time to change out the water filter...where can I get one for this model and how do I change it out? Thanks.
Doug Carter
dougcarter@letu.edu
    Scholar:
  • 67 Answers
I have the same model is made by Whirlpool just sold under different names. There's a deal on Amazon for the water filter they only last 6 months so I am getting two for a year.
Link below will give you and idea of what to buy. The filter is sold at Sears also for $39 each well in my area. Online seems cheaper.
http://www.amazon.com/exec/obidos/tg/detail/-/B0009793KC/ref=ord_cart_shr?_encoding=UTF8&m=A2TNNK9ZQOOLGL&v=glance
But you should also check where the water goes in the lower right side of the rear. I say right if you standing in the rear. There should be either a plastic or copper tube for the cold water to go in for the ice maker and drinking water. Kits for these are cheap for the plastic than for the copper. Plastic should run $10 to $20 bucks depends on where you go.
The only items you have to worry about is for the water pressure stem to be inserted through the tightening nut (copper) which the plastic of copper tubing goes through. That's it. Make sure there is not leaks their. Also check the tapping valve which connects to your cold side where you had turned it off for leaks. If that looks good then the water filter is leaking.
To remove (---) that just turn counter clock wise. (left) ( | )
The picture below is what it looks like after you turn it up and pull it out. Note there is a slide out knob that you remove and place on the new one. Insert like you see in the picture link | then to the right (----)
http://ecx.images-amazon.com/images/I/51yWGxqPeAL._SL500_AA280_.jpg
That's it.. Again it's not hard to do once you get the hang of it.
Posted on Jul 30, 2008
Gd5sha water under the freezer
This normally occurs when you have a large buildup of ice in the freezer, when it does a defrost there is just too much water for the hat on the compressor to handle. Make sure the door to the freezer & fridge is closing properly & the seal is in good condition & not falling off, moisture in the air causes frost in a freezer. So too many door openings can cause the same problem.
Nov 20, 2013 | Whirlpool Refrigerators
Woke up this morning and there was water all over the kitchen floor from the right side of the fridge. I pulled the fridge out and the water line was dry and had no leaks from the connection. I turned off...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 19, 2011 | LG Refrigerators
Large pool of water on floor,in front of refrigerator
The water can be a leak or an overflow from the defrosted tank of your fridge.In such a case your observation is most important as the point of leak can be noted only if you look beneath with a good flashlight.
Once this is found the fault can be a leak from the water line to the fridge - if there is an ice maker , or a leak from the evaporator collection tray while defrosting or the defrosted water tank overflowing which can be emptied.
Feb 15, 2011 | Refrigerators
Kenmore fridge, 7 yrs old, freezer on top. Water sprays periodically from somewhere at top inside of refrigerator, apparently from downward pointing chute or holes on either side. This seems to be part of...
Removed inside rear and floor panels of freezer (ice machine also) as ably advised by your tech. Found ice damming he suspected underneath floor panel. Thawed overnight with pot of hot water in freezer. could see that small rear drain tube was iced shut; why all water going into fridge below. Avoided floor mess from thawing water flow to evaporation pan on floor by tilting unit forward on blocks and laying several old towels inside freezer door to catch water that would run out. Also placed some in front at base of unit on kitchen floor. Continuing to thaw pipe to unclog, it is iced some way down, again as tech said it might. Will reassemble and be careful with freezer setting, in case it may have been too cold. Also, some food crumbs had found their way behind panel near this drain tube and may have fallen in to block it. Will clean out any remaining.
Jan 05, 2010 | Kenmore Refrigerators
Water on floor under front of fridge
CHECK AT THE BACK OF YOUR FRIDGE IF THE DRAIN PIPE IS STILL ON THE COMPRESSOR. ON TOP OF THE COMPRESSOR THERE IS A BUCKET WHERE THE WATER FROM THE DRAIN PIPE RUNS IN. THE HEAT OF THE COMPRESSOR CAUSES THE WATER TO EVAPORATE.
Sep 07, 2009 | Refrigerators
Water collecting below veggie compartments water inside
Take you bastor and find the drain hole and blow air into the line to open it up. The drain from inside to the pan is clogged.
Jun 11, 2009 | Whirlpool ET1FTKXK Top Freezer...
Water pools on floor
Check for a blocked defrost drain. Take the panel off at the back of the freezer section and find the small hole at the very bottom center below the cooling coils. Use hot (but not boiling) water and a turkey baster to flush it out until water runs through it. (it will go into the defrost drain pan, where it will evaporate)
May 24, 2009 | GE Refrigerators
Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Sep 06, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaking onto floor from refrigerator/freezer
The defrost drain is stopped up. Without taking anything apart, the easiest way to clear the drain is to blow compressed air through the drain tube which is at the back of the Fridge. You'll see it..... it drains water into the drip pan. Hope this helps !
Oct 09, 2017 | Refrigerators
I have a Crosley CT17A2, 16.8 cufu fridge with top freezer. I do not have any water hooked to the fridge. However, quite frequently water runs from the top back surface of the fridge and pools up under...
therer should be a tube leading from the interior drain hole into a catch basin under the unit where it is evaporated using heat generated y the condenser unit. check to see if it has dislodged.
Apr 05, 2008 | Refrigerators
GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
119 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
