Question about Dryers
Propane adaptor kit for a Samsung dryer
I bought a Samsung gas dryer Lowes at a great price. The number is DV203AGW and it's a 7.0 cubic ft capacity. The salesman said that all I had to do was call Lowes to get the propane conversion kit and then have a
professional to install it. Sounded simple until I called the Lowes number and was told that they don't handle Samsung parts and that I would have to deal with Samsung directly. When I called them, I was told that they don't make a propane conversion kit. The best I could do was call Matag because they had "heard" that Matag part MAL 9000 AXX could be used with my dryer. The only problem was was that I, as an individual consumer, could not order it. It had to be ordered by a licensed installer. I called an appliance repairman and he said that he has been unable to find this part. I worry that even if he does, it might not work. I can't believe that Samsung would make a gas dryer and not have the proper adapter available for those of us who do not have access to natural gas. Do you know anything about this and how I might be able to get this dryer up and running? I'm ready to take it back to Lowes.
  • Anonymous Jan 16, 2009
    I am having the exact same problem with a Samsung gas dryer that I just purchased!!!!
  • 254 Answers
MAL9000AXX is a part that can be ordered there are a couple companies that stock it , Marcone Appliance parts, Reliable Parts, and Appliance parts depot too name a few it retails for about $22.00 try calling a local parts distributor if these names don't sound familiar, Maytag was making dryers for Samsung for quite awhile and that is the most common conversion kit, so I think you'll be fine if you get that kit, good luck.
Posted on Jul 30, 2008
I just purchased a Sumsung gas dryer and I had them get me a propane kit before I would sign the paperwork and it is labeled as Sumsung LPKIT--3/XAA conversion kit nat. gas to L.P. gas with bar code 3672558976 6 153-5971
Posted on Aug 17, 2010
I just order vthat same part through lowes 1800 476-8160. i bought a samsung dryer model number DV328AGW and recently moved to Puerto Rico and need the conversion kit called sears which was where I purchased it they claim not to carry anything. Called Samsung they said Lowe's carries the part but that they did not then I called Lowe's at the number above and they are going to send it to me
Posted on Sep 26, 2009
I actually have the LP conversion kit and I am converting back to natural gas so I need your two orafice's in a swap.
If your interested just post back to me and I will give you my number to call and we can exchange info.
Thanks
Frank
Posted on Jan 15, 2009
  • 4 Answers
Hon I had the same problem but go to this site and see if this is what you need www.homeappliancecenter.com
Hope this helps it did me
Posted on Jul 15, 2010
I am trying to find out how many cu ft my Kenmore Elite HE 4 dryer is. It is no longer made & is not searchable on any sites. The model # is 85089400
7 cubic ft. capacity.
Measure the diameter of the tub using a measuring tape
  1. Divide the diameter by two to get the radius
  2. Measure the height of the tub in feet
  3. Multiply the square of the radius with the height of tub and pi (3.14). (square of radius x height x pi)
The result would be the capacity of dryer in cubic feet.
Jun 14, 2016 | Kenmore Dryers
Gas converion
Since no model number was given, gas dryer conversion kits usually come with instructions. The usually require you to replace the burner orifice, and make an adjustment to the regulator already included with the dryer. In some cases speacial tools are required to perform the conversion. Pleazer Appliance...
Apr 08, 2014 | Samsung 7.3 Cu. Ft. 7-Cycle Gas Dryer -...
Whirlpool dryer model #LG7681XSW2 what is the cubic ft of this dryer? 22000 BTU...serial # MAO143334
Hello, about 7 cubic feet or roughtly 1.918 feet X1.918 feetX1.918 feet equal 7.048 cu/ft. I hope this help you. GB....stewbison
Sep 22, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
MAYTAG FREEZER CAPACITY
I cannot find a MQU8057AEW in the Maytag library. I did find a MQU2056AEW that is 20 cu ft.
May 05, 2010 | Maytag 20 cu. ft. Upright Freezer MQU2056B
Need to change from LP to propane. How do I get access
Gas to Propane requires a Propane Certified technician. These technicians are provided by the company that provides Propane that they will be using.
You may need to get a Propane conversion kit, for technician from the Propane company to install.
You can certainly double check on this...Hope this helps.
May 01, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Washer and dryer capacities
4 cubic ft washer
7 cubic ft dryer
Feb 17, 2010 | Frigidaire FDE546RE Dryer
Dryer has been converted to propane using conversion kit #131776600 and I need the info needed to get it back to run on NG The dryer is a Fidgaire Gallery series model #FDGC648GHS0 any help greatly a
Hello there. If the parts were saved, they can be reused. If not, contact your propane provider and tell them that you plan to convert back to natural gas. They will be able to get you the kit you need, and will possibly have a technician come out and install it for a fee.
May 27, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Samsung dryer is not drying and its new
It ended up being a easy fix. Our old dryer was working fine and had been ran an hour before I hooked up the new Samsung dryer. Therefore I assumed when the new dryer did not work there had to be something wrong with it. There ended up being nothing wrong with it and it was my dryer vent. It was barley plugged which caused it to not heat up properly. I was told that the new dryers have a lot more sensors on them and its very sensitive about needing a clean vent to vent out the heat. My vent was not very dirty, but it had just enough build up of lent in it, it caused the dryer to not vent properly and it would keep shutting the flame off. Blew it out with my leaf blower and now it heats up and dry quick. I hope this helps
Aug 03, 2008 | Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity...
Dryers Logo
3,214 people viewed this question
Top Dryers Experts
