32MF605W used the television two nights ago, now it wont turn on, checked power supply and that is ok, the green light will not come on. I also tryed using the remote, but that does not work either
According to Phillips support you should disconnect power, press and hold the power switch on the front, plug in device and continue holding the power switch for 10 seconds.  This failed for me, but it is reported by their support as the reset method.
Posted on Sep 07, 2008
Mitsubishi wd65737 wont turn on
if you can check the power supply board look for a bulging capacitor which cause of voltage drop not to turn on the relay.
Sep 06, 2012 | Mitsubishi WD-65737 Home Theater
RCA D52W20 HDTV TRIES TO TURN ON 3 TIMES BUT WONT POWER UP
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then ckeck.it should work.
reply.
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I turned off the tv a couple of nights ago and now it doesn't seem to have power? The outlet is okay as other electronics work when plugged in to the same place. I have unplugged. The light that used...
Firstly I would still try a different outlet, you can also try to wiggle the cord at the base of were it comes out of the back of the TV and watch the light for action. If this does not work I would call the manufacture as you dont want to take your tv apart on your own and most likely if the light wont come on at all you are going to need a new power supply or the connection to the board could be lose.
Jul 18, 2011 | Protron PLTV-32 Television
Tv light flashed and cut off . turned back on and green light turned red and blinked 6 times pause then 6 blinks etc... tv will not power on. checked lamp seems to be ok. checked power supply board and...
Your power supply board is not yet dead, u know basic electronics' and soldering? You have to open the back cover of the television check for dry soldering on the printed circuit board , if found resolder but if not Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem...
Nov 29, 2010 | Televison & Video
My Philips 42 inch flat screen tv keeps cutting out and the green power LED flashes on and off. Also TV wont power on if left off all night.
There seem to be a problem with the power panel of the television that is why it does not power on if you leave it over the night without trying to turn it on.
Flashing the green power LED light simply means there is a problem in the unit that is why it keeps cutting.
Run a check on the power panel of the television to see if there is a burnt capacitor in the unit, then replace if you find any, also, a cold joint can be a cause for the problem whereby, you have the lead on a capacitor or component melted off and bridging two wrong ends together. That can be corrected with the use of a soldering iron.
If you are not familiar with technical activities, i would strongly advice you have a repairman run a check and fix it for you. It should not cost you much and if it is still under the warranty period, then you can take it back to the dealer that supplied it to you.
Take care
Oct 11, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
MAGNAVOX 32MF605W/17
Hi my name is Eric,
I hope I can help you with your issue ,
 You main a bad mainboard, a repairman will charge about $450 to replace it , use google to try and locate one yourself
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
Sep 26, 2009 | Philips 32MF605W Television
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
WONT TURN ON
CHECK POWER SU.IF IS FUNCTIONAL BP SHORTIN PINS GREEN AN BRACK .IF ITS OK,THE FAN WILL ROTATE SHOWN THAT THE P.SUPPLY IS OK
Aug 08, 2008 | Computers & Internet
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
Electro Med Services...
