My Canon video player rejects the tape when it is inserted...help.
  • 2 more comments
  • tasdent Jul 31, 2008
    The model is a canon Mv 800i and the cassette used is a tdk mini dv 60. When inserted it takes 5 seconds and ejects it. With no tape inserted the mechanism loads and operates correctly. It is plugged into the power supply so it has full power, as displayed on the screen, so that is not the problem. We have tried different tapes and this made no difference. The screen displays "remove the cassette".
    We tried this last night, but it made no difference. Have you another solution?
    Tried removing the tape and leaving it open and on for longer than an hour, but this did nothing.
  • tasdent Aug 01, 2008
    That would be great to try. The camcorder is longer in warranty.
    Thanks
    Brigadier General:
  • 6,966 Answers
To my understanding of your concern, three possibilities:
  • the tapes themselves;
  • loading belt/drive/motor;
  • other mechanical issue.
Related probable corrective actions:
  • Depending on the weather condition in your region/area (rainy, humid, cold, hot), the tapes have a tendency to stick together to the point that the Canon MV800 might not be able to unstuck them and load the single layer of tape across the video head. The machine will sense a fault and therefore request the eject. Suggestions: Keep the machine and tapes in the same room for them to be at same ambient temperature; Before using, power the MV800 a couple of minutes (say 5~10) to warm it up (for possible condensation; Use a cassette rewinder/forwarder to exercise the tapes; and pls verify that the tapes are not dusty, moldy or for the presence of foreign materials such as bits of paper and others.
  • There might be a problem with the loading belt, drive or motor; this of course would require the services of a qualified and competent repair person. However, it is possible to check by visually inspecting the visible mechanism to look for signs of damage/fault;
  • Other mechanical issues could include tape inside/down sensor, spreader arms, capstan motor, pinch roller and the other mechanical. Again, this would necessitate the intervention of a skilled technician.
  • In some instances, it is possible to have foreign objects/materials inside the unit, to try and clean without opening the MV800, a can of compressed air might help. Of course extreme care in using/pointing the nozzle as some components are fragile such as the video head.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 01, 2008
  • Louie  Role
    Louie Role Aug 01, 2008
    Thanks, Ekse.
  • 13,433 Answers
Please provide
-brand
-model
-type of tape
Posted on Jul 31, 2008
  • 2 more comments
  • Ekse Jul 31, 2008
    it has been reported that this error would be fixable by removeing the tape for around a hour, see this page
    http://xanli.blogspot.com/2008/02/canon-...
    its not actually your model but a close one still, give that a try.
  • Ekse Jul 31, 2008
    Sorry for delayed response, We can try a firmware update incase its a software problem, if that has no effect you may have to send it in for repair.
  • Ekse Aug 01, 2008
    is the camcorder still under warranty?
  • Ekse Aug 01, 2008
    Good solution beni.
Why am I having difficulty rewinding and playing tapes?
Is the Canon UC9 a HI8 camera?? If not it wont play HI*.
Aug 21, 2015 | Canon UC9 Camcorder
Sony CCD FX500E ejects tapes
Mechanical fault. Contact any service technician; or the authorized service centre for Sony. Electro help
Nov 29, 2014 | Sony Video Cameras
My canon dvc keeps telling me to reject my tape. It retracts just fine. But it won't let me record or play back. please help!!
I have the same problem. The only solution I've found is to manually wind the tape forward about 15 seconds and it works fine again. The problem only occurs if I let the tape wind all the way to the beginning.
Aug 03, 2010 | Canon ZR100 Mini DV Digital Camcorder
Will not accept the tape -
I have Canon MVX220i.with problem load tape. After put in cashe,I see on screen comunicate TAPE REJECT,Where it's problem.
All other function worked perfect,.I have MV400i,500i and have identical problem
HELP.I not like go to Canon authorised service,Only expency!!!
Jan 03, 2010 | Canon MVX250I Mini DV Digital Camcorder
My canon zr850 is rejecting mini dv tapes what do i do?
Sometimes this is caused by the tape itself, or more specifically, the tape case. If the tapes are labeled, there is a chance that the flap which lifts to expose the tape is stuck closed. Check this by locating just bellow the flap on the tape a recessed button. Press and hold it while opening the flap. If it's sticky, or stuck and is difficult to open, this is your problem. Make sure the flap opens unrestricted by removing the labels from the case which would hinder this motion. Hope this helps.
May 04, 2009 | Canon ZR850 Mini DV Digital Camcorder
My canon camcorder drive for tapes rejects tapes when i push down and it says remove the cartridge
I had the same problem. Checked the site and found a solution of dropping the camera onto a carpeted floor from about 1/2m to 1m. Thought that it was bullsh1t but was desperate and so tried it. worked a treat!!!
Hope this helps.
Apr 01, 2009 | Canon DV-MV830i Mini DV Digital Camcorder
Cannon zr100
CASSETTE ,DUE TO DEW & MOISTURE , HUMIDITY DAMAGE IN TAPE CAN CAUSE THIS PROBLEM.
Oct 09, 2007 | Canon ZR100 Mini DV Digital Camcorder
Camera cassette errors
Often in this situation there are two issues that can casue the problem you are having. 1. The tape is casuing the camera to "reject" it. In other words, it thinks there is something wrong with the tape so it is warning you with the error message. Perhaps the cassette has been damaged slightly. This error can also happen when the tape has been used often or taped over a few times. Solution: Try using a new tape. 2. The camera may need to be cleaned. The recording heads may be dirty and it doesn't matter what tape is placed in there. Purchase a cleaning tape from a consumer electronics store. Make sure you read the directions very carefully. These are cheap fixes. If it works, great. Otherwise it may need to be serviced by your local technician. Let me know how it goes.
Jun 27, 2007 | Canon ZR45MC Mini DV Digital Camcorder
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
