Question about HP PSC 2410 All-In-One InkJet Printer
HP Director won't work
I installed the software on my new hard drive and there's an icon for the Director on my desktop but it won't work. The message on the printer, when I hit scan, says "Scan options are not set. Install or run device software on computer." So I try to reinstall the software and it says it's already installed. Help!!
What I did to "fix" it was to completely uninstall the printer and reinstall it as if for the first time. Then I had to download new drivers for it. I found that out by checking for updates. The Director icon on my desktop till doesn't seem to do anything but I can now scan by hitting the scan button on the printer. It doesn't work like it used to but I'm just adjusting to the new paths I have to take.
Posted on Jul 31, 2008
I accidentally deleted my hp director icon from my computer i dont know how to restore my hp director
If you have just deleted the icon from desktop and not uninstalled then we can put a shortcut back on desktop
Click on START button
click on MY Computer
OR
Open MY Computer icon from Desktop
Open Local Disk C:\
Open Program Files
Open HP Folder
Open Bin Folder
You will find a file by name HPDIREC
Right click on the file name and Click create shortcut on desktop ( this icon will not look exactly like the HP Director icon you deleted )
Close the window and you will find the HP Direct icon on desktop
If not, you can uninstall the software from Add/remove programs under control panel and install the latest software for your printer. Click on the download button below to open HP website to download the software by selecting your operating system
Download
*Note : HP Director is not longer designed by HP. IT is replaced with a new Software called HP Solution Center
Oct 21, 2010 | HP PSC 2210 All-In-One InkJet Printer
Hi There! I am having problem opening my hp director program
  1. Open HP Director using one of the following methods:
    • From the desktop : On your computer's desktop, look for the HP Director icon (c01425509.gif), and then double-click it.
    • From the Windows taskbar : Click Start , click All Programs , click the HP orHewlett-Packard folder, and then click HP Director .
    Although HP Director does not appear to be open , it is open and loaded into the computer's memory, but it does not open in a new window as usual.
  2. Without navigating to another open window, press Alt and Space bar at the same time. The Shortcut menu displays near the top-left corner of the computer. Figure 1: Shortcut menuc00833293.gif If the Shortcut menu does not open, repeat steps 1 and 2 until it does.
  3. Select Minimize from the Shortcut menu.HP Director displays (minimizes) as an item on the taskbar (the row of open software programs that appears at the bottom of the desktop screen). If HP Director does not minimize, click Minimize again until it does.
  4. Click the HP Director icon on the taskbar . The software opens and functions normally.
Dec 08, 2009 | Microsoft Windows XP Home Edition
Hp director does not open when i click on the icon
After installing (MS IE 7 or MS IE 8) browser on the computer that is connected to the HP product,This issue occurs on some HP products. The MS IE 7 or 8 browsers might be incompatible with HP Director
Follow these steps to use a workaround to open HP Director each time you use the software. These steps must be repeated each time you use HP Director.
1-Open HP Director using one of the following methods:
From the desktop : On your computer's desktop, look for the HP Director icon ( ), and then double-click it.
From the Windows taskbar : Click Start , click All Programs , click the HP or Hewlett-Packard folder, and then click HP Director .
2-Without navigating to another open window, press Alt and Space bar at the same time.
3-Select Minimize from the Shortcut menu.
4-Click the HP Director icon on the taskbar ( ). The software opens and functions normally. NOTE: The HP Director window and icons might appear larger than normal, but the software is functional.
5-Repeat Steps 1 through 4 every time you use HP Directo
Thanks,
Nov 30, 2009 | Computers & Internet
HP 1315 - no director
The Software of HP Director comes up with the Installation CD of the printer and not available from the Online download.
Your printer will work with any application with the driver installed from online download.
Let me know if you are getting problem in running any application (viz Scanning, fax, copying etc.)
For more info you can visit this link:
http://www.fixya.com/support/r1133275-drivers_installation_problem
Regards,
Ellin
Oct 18, 2008 | HP PSC 1315 All-in-One Printer
HP Director won't open. I am on XP and IE7
HP Director has a flaw and is not compatible with IE7
I have a psc 1100 and I had to update my software from HP
CHECK THIS OUT
Go to HP, this link, type in your printer model #.
It still may fail to show...if it does not show HP recommends this
work around.
Workaround: Open HP Director each time you use it If the update to HP Director is not available, or if you have installed the update and the HP Director window still fails to open, try this workaround.
  1. From desktop, double-click the HP Director icon to load the program into the memory. HP Director will not open at this step. Do not click anything else on the screen until Step 2 is completed.
  2. Press the Alt key and the Space bar together, and then select Minimize from the menu that appears at the upper left corner of the window. If necessary, click it again until HP Director minimizes. HP Director software displays as an item on the task bar (the row of open software programs that appears at the bottom of the desktop screen).
  3. Click HP Director on the task bar. The software opens and displays normally.
  4. Repeat Steps 1 through 3 every time you use HP Director.
    NOTE: The HP Director window might appear larger than normal, but the software is functional.
Cause In October 2006, Microsoft released Internet Explorer 7. The HP Director software that shipped with some HP products introduced between 2002 and 2004 may not be compatible with Internet Explorer 7. The HP Solution Center software, which replaced HP Director software on products introduced after 2004, is compatible with Internet Explorer 7 and does not exhibit this issue.
Apr 30, 2008 | Computers & Internet
WHERE COULD I DOWNLOAD THE HP DIRECTOR SOFTWARE
you cannot download that software as such. delete everything and try installing from the software package once more. Then u will get hp director
Mar 18, 2008 | HP Officejet 4215 All-in-One Color Photo...
HP PSC 1315
If the patch or the updates did not work on the link I sent you try this Workaround: Open HP Director each time you use it If the update to HP Director is not available, or if you have installed the update and the HP Director window still fails to open, try this workaround.
Mar 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP Director
Try to open the HP director from
Start >> All programmes or programmes >> HP >> HP director
Else reinstall the printer software.
Mar 14, 2008 | HP PSC 1315 All-In-One InkJet Printer
Scanner/Director problems since installing new ink cartridge
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=45391&lc=en&cc=us&dlc=&product=90764
Dec 28, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
90 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
