Apple AirPort Extreme Base Station Logo
Posted on Jun 20, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can get my base station to make a wireless network, it shows green, devices can see it, but it does not allow internet access. i even have my pc directly connected via ethernet to the router and i cannot access internet. i had this problem when i first purchased it and when i called apple for support, during my explaination of the issue to the technician, it magically starting working. im afraid its a problem with the router. not sure what to do.
Farokh Merek
Level 3:
Master:
  • Apple Master 247 Answers
  • Posted on Jun 20, 2017
Farokh Merek
Apple Master
Level 3:
Master:
Answers
247
Questions
0
Helped
59662
Points
1077
Dial 1-800-204-4427 US Toll-free Number & Get the best assistance for Trusted Apple Technical support. We proffer an online Apple Technical Support assistance to the customers and fix their glitches in a professional manner. Read More... Apple Customer Support Number 1 800 204 4427
2 Related Answers
Anonymous
  • 17 Answers
  • Posted on Feb 15, 2009
SOURCE: New Apple Airport Express Base station blinking amber light
Using the Airport utility on your macbook (located in your Utilities folder) will tell you what the conflict is.....most likely you have DHCP issue or the network is at the incorrect setting.
The wizard in the utility will tell you what you should fix.
Anonymous
  • 9 Answers
  • Posted on Jun 07, 2009
SOURCE: Apple® - AirPort Express Wireless-N Base Station
No. The airport express just has a shorter range. You can use both a regular base and express to extend the range further. Also, the express can be used at your home stereo. You can play your Itunes library directly to your stereo with an adapter to the express. Anyway, the express is just a less powerful wireless, with some special features. We print through it and use it exclusively. May add base station later. Good luck.
2answers
Wireless router configuration
If you don't already have a wireless network, you can use an AirPort base station to create one. To configure an AirPort base station, you connect the Ethernet connection to the WAN port on the base station. In turn, the base station creates a Wi-Fi (wireless) connection to the Internet. Consult the documentation for your AirPort base station for more information on how to set up your wireless connection. Once you have a Wi-Fi network available, use these steps to tell your Mac to join it:
  1. Click the Wi-Fi menu icon airport_symbol.png and select your Wi-Fi network from the list of available networks.
  2. If prompted, enter the password for your Wi-Fi network.
  3. Check "Remember this network" to have your Mac automatically join your home network.
I cannot connect to my belkin connect n150 router after enabling it as an access point. Green light shows up on router and wireless network shows up but no connection when clicked. I cant connect via
Pretty sure you have to have at least one router in gateway mode to connect to the internet. An AP allows wireless devices to connect to a wired segment. The same as a router in gateway mode. AP mode has the benefit of extending a networks wireless range. If this is your only device leave it in gateway mode.
Why does my wireless internet only work when the network is not locked? does this mean my internet is not secure?
By not "locked" I assume you mean with security enabled. All clients connecting to your wireless access device must use the same credentials for security as your access device. Otherwise your clients will pick up and connect to any network that is unsecure.
4answers
Apple extreme bridged to apple extreme (Windows network)
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
I cannot connect wirelessy to internet on my compaq pressario v6000. The orange wireless light is on and the internet connectivity icons in the task bar have a red cross on them. I have tried all options...
Part 1: Before You Start loadTOCNode(2, 'summary'); You need the following: • A broadband connection to the Internet and the appropriate hardware. For example, cable-based Internet access that uses a cable modem that is provided by your ISP. • The Microsoft Broadband Networking Setup CD-ROM. • The Microsoft MN-500 Wireless Base Station. • The Ethernet cable that came with your base station. • The AC power supply. • The blank floppy disk.Check the following: • On computers that are running Microsoft Windows 2000 or Microsoft Windows XP, you must be a member of the Administrators group to set up a network. If you cannot run Setup, click Log Off on the Start menu, press CTRL+ALT+DELETE, and then log on with as an administrator. • Turn off any firewall or Internet connection sharing software on your computers. Your base station replaces these functions. The Setup Wizard cannot continue if they are enabled. • Do you have a Point-to-Point Protocol over Ethernet (PPPoE) Internet connection or a static Internet Protocol (IP) address? The Setup Wizard prompts you to type your user name, password, and service name for a PPPoE connection. For a static IP address, you must have the IP, subnet, and ISP gateway addresses. If you have one of these types of connections, gather this information from your ISP.
Part 2: Install the Software and Connect the Hardware loadTOCNode(2, 'summary'); 1. Insert the wireless base station Setup CD-ROM into the CD-ROM drive. If the Setup Wizard does not start automatically, click Start, click My Computer, double-click the CD-ROM icon, and then double-click Setup or Setup.exe. 2. Follow the on-screen instructions to install the software. 3. In the second part of the installation, select the option to set up the wireless base station, and then continue through the rest of the Setup Wizard. 4. When the Setup Wizard instructs you to connect your wireless base station, position the wireless base station close to your modem and computer, and near the center of your intended network area. If you want to set up the wireless base station vertically, attach the included stand. 5. On the back of your computer, unplug the Ethernet cable that connects your computer to your broadband modem. Leave the other end of the cable plugged in to the modem. 6. Plug the cable in to the "To Modem" port on the back of the base station. The base station is now connected to your modem. 7. Plug one end of the blue Ethernet cable that came with your base station in to the Ethernet port that is labeled 1 on the back of the base station. Plug the other end into the Ethernet port on the back of your computer. This is the same port from which you just disconnected the modem cable.
Important The modem must use its original Ethernet cable or one of the same type to connect to the base station. 8. Plug one end of the power supply that came with your base station into the power jack on the back of the base station. Plug the other end into an electrical outlet. The power indicator light on the front of the base station should turn on. 9. Return to the Setup Wizard, click Next, and then go to Part 3 of this article.
Part 3: Configure the Base Station and Network Settings loadTOCNode(2, 'summary'); Continue to follow the instructions on the screen to configure your wireless network settings: 1. Setup prompts you to enable wireless security (WEP). Microsoft recommends that you enable WEP. 2. Setup prompts you to save your network settings to a floppy disk for use in later installations. A blank floppy disk is provided for this purpose. If you do not save to a disk, you receive a list of network settings to print or write down. 3. Click Finish to exit Setup, and then remove the Setup CD-ROM from the CD-ROM drive and the floppy disk from the floppy disk drive. You can use the same CD-ROM and floppy disk to set up additional computers on your network.
Part 4: Test Your Network loadTOCNode(2, 'summary'); 1. View the status of your network in the Broadband Network Utility (BNU). Make sure that you can see your base station and the computer that is connected to it in the BNU status screen: a. Click Start, point to All Programs, and then double-click Microsoft Broadband Network Utility. b. View the information on the Network Status screen. 2. If your broadband Internet connection is being shared through your wireless network, start your Web browser program, and then try to visit a Web site. If your network is working properly, you have access to the Internet from the computer you just set up.
1helpful
I have a laptop run Vesta trying to set wireless connection to HP Potosmart C4385 print using ad hoc network setup. When selecting Ad Hoc connection in the printer setup it saids it can not find it or...
For this specific issue about installing the printer to a wireless connection. You need to install the software first as a usb connection. After the successful installation of the usb connection then you can add a device and it should work.
Step one: Gather the necessary hardware and information Follow the procedure below before obtaining your wireless network:
  1. Obtain your network SSID and WEP. To simplify this process, press the Wireless button on the all-in-one, and select Restore Network Defaults . This turns wireless off and sets the all-in-one's SSID to hpsetup .
  2. Press the Wireless button to turn wireless back on. Look for hpsetup when you select your network.
  3. Make sure that wireless is enabled on the all-in-one.
  4. Make sure that the computer that will be using the all-in-one has access to the router/access point.
You will need the following to set up the product on a wireless network:
  • A wireless 802.11 network that includes a wireless access point.
  • A desktop computer or laptop with wireless networking support or a network interface card (NIC).
  • Broadband Internet access is required for some features of the HP software to function. Cable Internet or DSL are examples of Broadband Internet access. NOTE: If you connect the unit on a wireless network that has Internet access, HP recommends that you use a wireless router (access point or base station) that uses Dynamic Host Configuration Protocol (DHCP).
  • The network name, or Service Set Identifier (SSID). NOTE: The SSID is obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with the access point for more information.
  • The Wired Equivalent Privacy (WEP) key or Wi-Fi Protected Access (WPA) passphrase, if needed. CAUTION: To prevent other users from accessing your wireless network, HP strongly recommends using a password or passphrase and a unique SSID to your access point. Your access point might have been shipped with a default SSID, which can be accessed by other users using the same default SSID. For more information on how to change the SSID, see the documentation that came with your access point. NOTE: The WEP key and WPA passphrase are obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with the access point for more information.Some access points provide more than one WEP key. Use the first WEP key (index 1) when setting up the wireless network.
  • If the network is set up with an Apple AirPort base station and you are using a password instead of WEP HEX or WEP ASCII to access this network, you need to get the equivalent WEP key. See the documentation that came with the Apple AirPort base station for more information.
  • If IP address filtering is set up, verify that the unit address is listed.
  • If MAC address filtering is set up, verify that the unit address is listed. NOTE: HP cannot set up or change the SSID, WEP key or WPA passphrase. This information is required before connecting the HP All-in-One to the wireless network.
Step two: Connect to an integrated wireless WLAN 802.11 network Follow the procedure to connect the unit to the wireless infrastructure network:
  1. Insert the software CD.
  2. Click Install .
  3. Click Next on the Please Allow All HP Install Wizard Processes screen.
  4. Select Easy Install on the Choose Easy Install or Advanced Install screen.
  5. Select Through the Network on the Connection Type screen. Figure 2: Connection Type screen c01160788.jpg
  6. When it doesn’t find your device, click Next . Figure 3: Using Network Setup c01164746.jpg
  7. Plug in your device via USB (it will tell you when to disconnect later). Figure 4: Making a connection to your all-in-one c01160790.jpg
  8. Select your network from the list, and click Next . Figure 5: Wireless Network Setup c01160791.jpg
  9. Enter your WEP key (if applicable). Figure 6: Specifying your network security settings c01160792.jpg
  10. Once it has completed connecting to the network, click Next . Figure 7: Network connecting completed c01160793.jpg
  11. Disconnect the USB cable from the computer and the All-in-One . Figure 8: Disconnecting the USB cable c01160794.jpg
  12. Click Finish to complete the software installation process. Figure 9: Software installation complete c01160795.jpg
Sph200d not getting ip address from router
I had the same problem. I set up a static address instead and it works very well. I just copied the details form my laptop, diabled the laptop and set up the phone with the same details as I had on my laptop. Once I start the laptop again, it will get another address. --Jonas
Networking a Printer on a wireless network
Deanna, if the mfc is not that old, take it back to the dealer and ask for changing it to a wireless printer (extension: CW). Do you really need the fax function? If not, try this printer: DCP 750CW. If yes, get the MFC 845 CW. The CN printer have to be connected directly to router or pc/laptop.
Connectivity/activesync and network issues
When using wireless lan with PPC, there are some experience shere with you. 1. You must do an "Reset" after the first time of installing wireless driver into your DELL AXIM. Otherwise, the driver would not work. 2. Microsoft Pocket PC 2002 only can allow one source to access the internet. It can't access internet via the USB and wireless at the same time. Thus, it is more batter way to leave your AXIM alone instead of insert on cradle when you try to access internet via wireless lan. 3. Some of the wireless's CE driver are based on StrongArm, 206MHz, not PXA250, 400MHz. It will got problem when the wireless try to initiate the link between base station and PPC. Try the following step: (i) Make sure you have been install the wireless driver. (ii) Remove your wireless from CF slot. (iii) start->setting->power->processor select "PowerSave" mode and apply it. (iv) Plug wireless into CF slot (v) If you can get an dynamic IP or access internet, you can repet step 3, but select "Auto" mode. Hoping these information can solve your problem.
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
