Question about Intel Motherboard
Emachine once more
So i did as you said... now the computer is beeping at me???
  • taylorap Jul 30, 2008
    i tried the power cord to no avail and the video and sound are onboard
  • 781 Answers
You have a motherboard fault try changing memory video card for a different one
or try unplugging power cord from back of computer and leaving out for 10 or 15 minutes reconnect and try again
Posted on Jul 30, 2008
  • David
    David Jul 30, 2008
    check motherboard settings for your cpu front side bus speeds and clock speed
    you could try removing the motherboard battery and leaving out for at least 1 hour sometimes it takes longer
    or try resetting bios this time when in reset boot computer and turn off straight away then set to jumper default and reboot
    this is no excuse but when you overclocked cpu it got damaged and cannot be fixed all I am trying is to try to recover your system
Emachines won't send signal to screen, when turned on it makes one long continuous beep
The beep signifies an error. But different bioses have different beeps. You can check with the emachine site to tell you what 1 beep on the machine signifies and you can be guided accordingly. Could be bad power supply, connection, peripheral, etc
Sep 01, 2017 | E-Machines eMachines Desktop PC
T6520 emachine won't turn on, lights and fan work. Beep code
Hi, you are having a problem with your add on cards, try to pull out everything that you have add on to you PC, then try to put 1 by 1 and try to turn on. If it beep once its OK, but if it's continue then the add on cards are the defective.
Oct 08, 2012 | E-Machines eMachines Desktop PC
I have a 5 year old Emachines computer, a few weeks ago I bumped my foot on the desk that was holding the computer and the screen turned off and the tower started beeping. It was long continuous beeps. I...
Usually when you hear long beeps coming from your computer it telling you that there is hardware loose . You may have knocked something loose. Check cd roms , ports and cards , memory to make sure they are fitted in correctly . good luck
Aug 03, 2017 | Computers & Internet
My computer comes on run then beeps once. and dnt do any thing else no picture
Try reseating the RAM.
If it still does not boot up, remove the RAM modules and take them to your friendly computer repair shop and get them to test the RAM for you.
Mar 12, 2012 | eMachines Computers & Internet
I have a Emachines El 1200 and I think The memory stop working.
you can get up to 4 GB of DDR2 667/800 MHz SDRAM (dual-channel support on two DIMMs)
see the specs on this
http://support.gateway.com/emachines/emac/EL1200/EL1200sp2.shtml
Feb 17, 2010 | eMachines EL1200-05w PC Desktop
Emachines wont boot
Bad capacitor(s) on the motherboard can cause this problem, corrupted BIOS maybe... try flashing BIOS.
Probably the CPU if your not getting any error code beeps on startup.. NO Processor for the BIOS instructions thus no Beeps !
Nov 27, 2007 | E-Machines eMachines Desktop PC
Emachine t5026, 3 beeps
try a cheep video card from your local used computer parts store they're every where, you'll ask for a pci video card.
Mar 28, 2007 | E-Machines Emachine T5026 power supply **...
My computer (emachines T5212) beeps at me
These are called beep codes and there should be a pattern of long and/or short beeps which will repeat. Once you identify the pattern we can help figure this out for you.
Jan 11, 2007 | E-Machines eMachines Desktop PC
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
