Question about Dishwashers
GE GSD2300N10BB Dishwasher. Washes fine, but will not dry the dishes. Even after overnight, the dishes are still wet. Not certain, but it appears that the heating element doesn't heat up. Thanks for the advice!
5 Suggested Answers
SOURCE: Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Posted on Apr 19, 2008
  • 84 Answers
SOURCE: KITCHENAID DISHWASHER WONT REPEATEDLY WONT RINSE DETERGENT OFF
Fist what detergent are you useing is it dishwasher detergent and second the dishes wet and stemy how long do you wait after the machine has completed the cycle before opening it
Posted on Jan 21, 2009
  • 10865 Answers
SOURCE: kenmore elite dishwasher does not dry
one of the buttons on the door will give u heat, just push that button
Posted on Apr 19, 2009
gary1121
  • 332 Answers
SOURCE: IDL40 only washes in cold water now.
YES IT SOUNDS LIKE IT'S THE ELEMENT OR MAYBE A WIRE HAS COME OFF THE ELEMENT FROM VIBRATION,
Posted on May 29, 2009
  • 132 Answers
SOURCE: Wont heat or dry dishes
USUALLY THER IS A SENSOR ELEMENT FOR HEATING TEMPERATURE MAY BE FUALTY ..
TRY IT ..
THANK YOU
Posted on Jun 14, 2009
Dishwasher washes dishes but does not dry even though that display shows dry icon
First ,Check for a water puddle on the bottom of the dishwasher .If you have water there, you more than likely have a plugged drain or drain hose, or bad drain pump (less likely) If no water is there see if the dishes are hot after a cycle. If they are not you could have a bad heater (that circular thing on the bottom of the dishwasher) other problems could be the timer or computer Depending on the model brand and age of the dishwasher .One last thing there is a vent to let moisture escape that could be bad but then you would have hot wet dishes
Aug 07, 2014 | Blomberg Dishwashers
Kenmore 17033 dishwasher will not clen dishes
USE JET DRY and clean the system every once in awhile by running it through a cycle with no dishes and use washer cleaner for that model.
Jan 07, 2010 | Kenmore 24 in. 17033 Built-in Dishwasher
Kenmore Quiet Guard
You dont really need it, when the washer gets done Open the door for a minute and let the steam out and shut the door dishes will then dry. the reason there still wet is because of the steam from the Hot water
Sep 16, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Washes fine, NEVER dries the dishes, no matter what is selected.
have you got rinse conditioner in the dispenser- most important
Sep 13, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishes are still damp after cycle is complete. This causes a bad odor in the dishwasher.
Bad odor is caused by something besides wet dishes.
When the water finishes it's part and is exhausted, does a fan come on and run for a long time? If not, the drying fan is bad, usually mounted on the side and runs after all the water is removed. Also, after the water stops, are the dishes and inside HOT? You have to have HOT water to make a dishwasher function properly, will also take care of some of that odor. When a dishwasher cycles, it washes and then heats the inside of the washer, then it runs a fan to remove the water and dry the dishes.
Make sure your dishwasher is hooked to the HOT water line and also check to be sure it can heat it's own water, put it on pot's and pans and it should heat the water quite hot, even if it has hot water coming in, it will heat it up some more.
Sep 08, 2009 | Bosch Integra® 500 SHX55M05UC Built-in...
Rinse cycle on top drawer keeps turning on
You have a leak due to the Lid seal leak.
1- Unplug the power, then pull out top draw half way and
2-Touch the bottom top housing ( not bottom top draw) you will feel it wet. Try to dry it by stick in a towel.
3- Repeat the same for the bottom drawer.
After drying out, wait for at least 1 day so the sensor can be dried out then plug in the Power, you will be fine.
4- Contact me for the next step.
Jul 01, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Kenmore elite dishwasher does not dry
Apr 19, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Nov 12, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Dishwashers Logo
305 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
