Question about Refrigerators
Small hole in freezer shroud. ist it patchable.
  • adajmoore Aug 06, 2008
    Think you. I had't thought of that>
    Problem Solver:
  • 5 Answers
Epoxy works well
Posted on Jul 30, 2008
Remove ignition barrel in vt commodore
you need to have the key in the ignition take the shrouds off there is a small hole underneath the barrell you have to push something small into the hole then pull out the barrell
Apr 09, 2013 | 1998 Holden VT Commodore
Need to rpl ignition lock 98 GMC K1500 PU
Most ignitions you will need to remove the plastic shroud around the steering colum. Have a good look at the complete barel & mount & you should find a small hole. When the key is in a certain position (usualy accessories) there is a little pin in that hole. You push the pin in with small allenkey, jewler screwdriver etc... & the barel will just slide out.
Jul 01, 2012 | GMC Sierra 1500 Cars & Trucks
What size case fan for HP Compaq dc7600?
What size case fan? Dunno.
1) How to measure the fan? Across the fan's shroud. (Surrounding Cage) Fan stood up, measure the Height, and Width.
2) Look at the label on the fan's center hub. Write the number down.
Now which of these CHASSIS fan numbers match?,Business-Desktop-dc7100-dc7600-dc7700,Computer,Fans.aspx
A) 3777791-001
Chassis Fan - 70mm x 70mm x 15mm.
70mm x 70mm is the height and width of the fan's shroud. (Surrounding cage) [ Chassis fan stood up ]
15mm is the Thickness of the fan shroud.
Nope, not that one.
B) 451144-001 Chassis Fan - 92mm x 25mm
Could be.
C) 455310-001 Chassis Fan - 92mm x 25mm.
Could be.
Jun 11, 2012 | HP Compaq dc7600 Small Form Factor PC...
My frost free freezer is building frost on the top part of the freezer between the door and the small divider, the seals appears ok with no gaps and it never shuts off 2006 model
there are two vent holes in the bottom of the door that need to be seal closed there has been air leaking in from these holes also the rear air diffuser should be solid and the vent holes in it coverd as well.then you nee to take one or two small washers and remove the front panel inside the freezer and put the washer between the panel so there is a small gap between the top of the freezer and the divider
Sep 26, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Ice on bottom of freezer and small leak on right coner
There have to be a hole to drain the water down .You might need to take the cover off tof get to drain
May 17, 2017 | GE Profile PDS22SCRL Stainless Steel...
There is a small hole in my g.e. chest freezer.
that is the drainage hole where water can pass out from .
Feb 18, 2010 | GE 7 cu. ft. Chest Freezer FCM7DR
The fan is making too much noise
Hi. You didn't state which fan you are having issues with, so i will address both areas.
The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it. This fan has a shroud, and if the fan blade becomes warped, it will rub against the shroud, causing noise. This fan blade is whole,and it can be removed and replaced if this is the case. Ok, the next problem spot will be the evaporator fan.
The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. Check the fan for warped blades. If the blades are warped or mis-aligned, replace it. This fan also is protected by a shroud as well, and it will make noise if the fan blade is damaged.
NOTE_ If the fan blades are not warped, and rubbing against the shrouds, this will indicate that the motor that rotate the affected fan is damaged. It must be replaced, in this case.
Dec 14, 2009 | Samsung RS2630SH Side by Side Refrigerator
We are getting a small pool of water in the refrigerator, beneath the crispers. It pools toward the front, and we can't tell where it's coming from. Any suggestions?
The water is probably running down the back wall , due to a defrost drain clog . To stop this leak , you will need to remove the food and the ice maker from the freezer ( if equipped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Then re-assemble the freezer section .
Nov 24, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Problems with a replacement radiator.
check that shroud difference is not a fan to core 'clearance' issue.
1. drill new holes in shroud ?
2.fabricate a bracket out of strap steel to bolt them together ? 3. go back to advanced auto for heavy duty ready shroud ?
Oct 10, 2009 | 1991 Ford F150
Ignition lock cylindre
Remove instument panel lower panel to be able to remove lower steering column shroud.then remove upper column shroud.Turn ignition to on then isert a thin blade screwdriver or something simular into small hole in cylinder housing push inward to release detent and pull out cylinder with key still in cylinder. Need any other help on this just ask.
Jul 05, 2009 | 2003 Ford Focus
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
