Question about HP LaserJet 3050 All-In-One Printer
50.2 fuser error - HP LaserJet 3050 All-In-One Printer
  • 2 more comments
  • Brian Reitz
    Brian Reitz Aug 05, 2008
    keep getting an error message 50.2 Fuser error. Says it is a Fuser warm up service issue. Turned off for 20 min. still same error.
  • tony piacun Sep 29, 2008
    I have the same message, turn off and on, try to print same message 50.2 fuser error
  • alfredobs Nov 13, 2008
    Users in remote site reported me several laptop AC adapters burnt and the Brother printer not working anymore after big electricity fluctuation. The MFC-7820N is showing the "Fuser error" message on display. Thanks for advise
  • carlt487 Feb 02, 2009
    50 fuser error
Hello Sir,
I have a printer HP Laserjet 3050. this shows a problem "50 FUser Problem". Please turn off and start again.
please give me detail solutions about this problem.
Thank you.
Regards
Vikash Verma
LDC Engineering College Allahabad
Posted on Nov 26, 2008
Lexmark X5150 All-in-One Error: 50
"When the printer fuser fails it prompts many HP laser printers to display an ERROR CODE 50 service code" same could be said about the lexmark fuser malfunction
replacining a fuser can be expensive might be better to get another printer unless you have a special bond like me i find it hard to just throw away things that have gone bad
Feb 01, 2010 | Lexmark X5150 All-In-One InkJet Printer
Hp 4m shows service error 50
The service 50 error indicates a bad fuser assembly. You can get one on Ebay for less than $50. To replace the fuser just open the door on the back of the printer, inside you will see the fuser, unscrew the 2 screws and pull the old one out. Insert the new fuser and screw it down, power on the printer and you should be good to go.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 13, 2009 | HP : HP4 Laserjet Printer
HP Laserjet 5m, appear error code 50...please help.
Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
May 20, 2009 | HP LaserJet 4m plus Printer
Error code- 50 service
Hi Sheila,
The following page gives the reason http://www.all-laser.com/cgi-bin/webc.cgi/error50.html
Seems the printer needs something called a fuser. There is a link to maintenance packs including the fuser or just the fuser alone.
Apr 27, 2009 | HP Office Equipment & Supplies
Fuser 50.1 error on HP 3500 printer
From HP Website:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
Mar 23, 2009 | HP Color LaserJet 3500 Printer
HPLaserjet4P - printer service 50 -
A 50 Service error is a fuser error. Turn the printer off for 5 to 10 minutes, then turn it back on. If the error is still there, I think your going to need to make a service call you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
Good Luck the HP Laserjet 4p is a great printer.
Jan 28, 2009 | HP LaserJet 4 plus Printer
50 service flashing on display screen
If the display panel reads 50 FUSER ERROR, CYCLE POWER, turn the printer off for 15 minutes. This allows the capacitor that is responsible for signaling this error to discharge. If you don't wait 15 minutes you will continue to get this error even if you have replaced the fuser. If it continues to show the error, then you need to replace the fuser. It is easy to replace.
The fuser maintenance kit is about $119. on the web.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 17, 2008 | HP LaserJet 4 plus Printer
Hello
A 50 Service error is a fuser error. Turn the printer off for at least 10 minutes, then turn it back on. If the error is still there, you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
If you still have the 50 Service error after reseating the fuser, you might need a new fuser.
You can access the fuser by opening the rear door. It's located directly above the paper tray. There are two screws that hold it in place. Remove those two screws, and the fuser slides outs.
Hope this helps.
Mar 20, 2008 | HP LaserJet 4 plus Printer
Error 50
Error 50 is a fuser unit fault code. You can take apart the fuser unit and see if the fuser lamp is functional. Also check some of the other thermal parts on the fuser. If everything checks out, you will probably have to replace the thermistor. You will need to see if it will be cost effective to replace the necessary parts (Brother parts are not cheap), or to buy a new printer. Hope this helps. Good luck.
Jun 19, 2007 | Brother HL 1430 Laser Printer
HP LaserJet 3050 All-In-One Printer Logo
748 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
