Question about iLO 3200 32 in. LCD Television
Will not change channels or vol
Tv is on one channel and it can not be changed with tv controls or remote and also the vol
  • 7 more comments
  • nnygard12 Aug 01, 2008
    Same problem...stuck on one channel...can't change a thing.....
  • Anonymous Aug 04, 2008
    Only the power button works on the remote control. I can't change channel or volume either on the remote or the TV itself.
  • dsid Aug 05, 2008
    26" ILO LCD TV has perfect picture, but cannot change channels or volume
  • kvernon Aug 06, 2008
    Same problem. "This is an encrypted channel" message.
  • Anonymous Aug 10, 2008
    Same thing does anyone have any ideas
  • jadkins Aug 18, 2008
    will not change channels or vol, after TV gets hot. have to power down and let cool down, then power up and it will work.
  • Bridget43 Aug 18, 2008
    I also bought the ILo brand 32HD television, had it about a year before it went out. All I can do is turn it on and off, it is stuck on one channel. I wish now I would have done my homework. The ILo support people at 18002165156 are no help at all. If your reading this and thinking about buying one...don't do it. Bridgette
  • dlakin7101 Aug 26, 2008
    The volume on the remote is not working & when we go to turn it off it takes about 3 times to shut the power off. I have new batteries in,but that didn't do anything also, unplugged it for a few minutes, still same problem. This TV has to work threw a VCR.
  • Anonymous Aug 27, 2008
    My ilo 32 inch flat only displays a blue screen. It does not identify what setting it is on nor channel or volume level. Just a blue screen! My solution for this issue is rediculous. I leave the tv on for about 15-20 minutes, shut it down then turn it back on. After that the tv works perfectly fine, nevertheless this is a inadequate solution.
You have to send it in for repair. Your main board is fried and they will upgrade your board. This has been going since walmart first sold this brand.
Posted on Aug 12, 2008
Does anyone know who the manufacturer is or who "owns" ILO?
Posted on Jul 31, 2008
My TV says Channel Fix how do I get RCA Universal remote to change channels
There are manual controls for the channel change on the TV just look.
Sep 29, 2016 | RCA Televison & Video
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
[ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
Jun 29, 2015 | Durabrand DWT1304 13" TV
Dont have the remote control cant turn to channel 3 or 4 dont have a menu button
Isn't there a channel Up/Dn button at the front panel of this TV. It should be there. Only Menu button is not. There is Ch up ' Ch Dn and Vol Up ' Vol Dn buttons, beside a power button. Even pressing the channel Up ' Dn button, the channels cannot be changed, check the micro switches inside the TV. Replace them all at one time. You ave to open the TV to access these components.
Aug 02, 2012 | Sylvania 6719DF 19" TV/VCR/DVD
Cannot change channel to a 2 digit channel eg.
some remotes used to have a key to switch between single or double digits marked ( -/--)
Oct 27, 2009 | Samsung TV Remote Control
I have a remote control TV. It is an old unit.
Hold in vol.up and vol. down at the same time. OR Channel up and channel down at the same time for 5 seconds. If you still have the same problem.Go into the menu and goto cc or close caption or text and turn it off. One of them should do it.
Sep 25, 2009 | RCA Televison & Video
Change input without remote
Go to menu on front of tv, scroll down to source/input heading.Use the volume or channel select buttons to change the source
Sep 14, 2009 | Sanyo DS20930 20" TV
Phillips 19 inch TV/VCR combo --no remote--can't change channels
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
Jul 13, 2017 | Philips CCC193AT 19 in. TV/VCR Combo
RCA TV VCR/VCR combo
(1). Go to dollar store buy 4in1 remote control has all codes for all tvs cost $5.00 also you can enter menu on front of tv press menu button on front of tv when menu comes up use your channel up and channel down for up&down menu -- use vol- & vol+ to change settings
Jan 27, 2008 | RCA B27TF680 27 in. TV/VCR/DVD Combo
iLO 3200 32 in. LCD Television Logo
100 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
