Question about RCA D52W19 52" Rear Projection Television
RCA 52W19 NOT POWERING ON
My original problem was the set was not powering on the greenlight was flashing 3 times and then going off. I have replaced the cp150 capacitor and the flyback. It worked after the replacement for 1 day. Now the green power light comes on for about 10 sec and it just goes off, the screen or sound never comes on. I have checked all of the other caps and none are bad. if anyone knows what I need to replace next or any helpful info please let me know.
Thanks,
Travis
  • 3 more comments
  • mritravis Aug 01, 2008
    No I have not replaced it. Where is it located on the board and I will order and replace it. I appreciate your help.
    Travis
  • mritravis Aug 02, 2008
    Thank you for you help I will order the part today and let you know if that fixes it.
  • mritravis Aug 11, 2008
    I replaced the HOT transistor today and it did not fix my problem. The set came on like it was fixed and when I turned it off it will not come back on. The power light will come on once after it is plugged in but it just goes off after about 10 sec still. The power light will only come on once then you have to unplug for it to come on again.
    All suggestions are appreciated. I don't want to let it beat me..
    Thanks,
    Travis
  • Anonymous Aug 14, 2008
    I have a RCA D56W 56 in. Rear projection Television. I'm having the same problems as describes by Travis. I've been told that the solution to this problem is the replacement of the High Voltage board, but upon reading Travis's account it seams that it is only part of a bigger problem. Is this so? i1100ran@yahoo.com please e-mail me.
  • mritravis Aug 18, 2008
    Well today I unplugged like you said and I resoldered a couple of connections just in case and I then reseated all cables. and it came on for about 5 minutes and when i turned it off it would not come back on. It just gave the power light for about 10 secs and that is it. I took the board out again and rechecked it again and it did the same thing. Do you think there could be another bad cap somewhere. No others look bulged or leaking. I am willing to try anything. I just don't want to give up. I did press on the board like you said and it would not come on.
    Thanks,
    Travis
  • RCA Master
  • 8,617 Answers
Did you replace the HOT 2SC5588 ?
Posted on Jul 31, 2008
  • Sonny Berry
    Sonny Berry Aug 01, 2008
    It is located in front of the flyback to the left its on a large aluminum heat sink with fins on it. Its a 2SC5588 transistor
  • Sonny Berry
    Sonny Berry Aug 11, 2008
    It almost has to be solder related or the ribbon cables not seating correctly. Heres how you can tell. Unplug the set then press in the middle of the board where the flyback is in a couple of spots especially near the flyback then plug it in and try to power it up.
Why would a red light be flashing instead of powering on?
The power supply keeps trying to start but can't.
Jun 22, 2014 | RCA Televison & Video
RCA r52wh77 not powering on
common issues include bad connections at and around the flyback
bad flyback is not unknown and or shorted parts on same board.
High Voltage Splitter with can include charred part near Flyback.
set has the 3 strikes rule---it will attempt to power up three times and if fails shuts down.
Not easy sets to work on as most parts are RCA only.
May 20, 2012 | RCA HD52W59 HDTV Projection Television
RCA 50 floor model....goes off after about 10
Your TV is Projection if it is a 52W19 Not LCD,# capacitors on deflection Board 3 of them cp150 114,120
cp150 2200uf 16v 220uf 35v if cp150 is puffed up on top it is Bad Mats Parts 1-800-628-1118 for caps , UED 1-800-648-6657 to replace whole board.
Dec 03, 2009 | RCA D52W19 52" Rear Projection Television
Do you think that yesterdays digtal signal could have damaged my tv. when I came from work my TV did not want to turn on.
No the switch over wouldnt affect your set from powering on. Its more likely that the flyback and CP150 and CP114 need replacement if the led will flash 3 times then go out when the power is pressed.
Jun 13, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca D52W19
I would try replacing CP150 , CP114 and also CP120 as those three capacitors have been known too fail which will prevent the set from powering up.
Jan 28, 2009 | RCA D52W19 52" Rear Projection Television
Powers on then 8 secs later powers off
Bad capacitor 2200uf 16 volt and two 220uf 35 volts .Green and Gold writing on capacitors.these are on the Deflection board that has the Flyback transfomer on it.
Sep 05, 2008 | RCA D52W19 52" Rear Projection Television
It turns on for 8 secs then powers off no noise
Bad capacitors! 3 of them 220uf 16v/ 220uf 35voltsx2
Tv turns off all the sudden
Time for a service visit. Your power supply voltage(s) are not correct for whatever reason...accordianman
Feb 27, 2008 | Televison & Video
RCA 52" second time in the shop in less than one year, won't stay on, green light flashes 3 times then goes out
try changing the cap 150 on the same board as flyback transformer this should help with the tv not staying on.
Jan 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Dec 30, 2007 | RCA HD61LPW175 61" Rear Projection HDTV
RCA D52W19 52" Rear Projection Television Logo
151 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
