Car cd player is scratching my new discs - Audio Players & Recorders
Maybe its a dud cd player
go to the place u brought it n ask for your money back
good luck :P
Posted on Jul 30, 2008
Why doesn't CD play?
The CD player has failed and will have to be replaced
Feb 02, 2016 | 2002 Isuzu Rodeo
Tip
How to Fix a Scratched CD
Clean the disc. Even if a CD isn’t actually scratched or scuffed, dust, oil, and other surface contaminants can prevent it from playing properly. Thus cleaning the disc should always be your first move. Ads by Google
'; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+9503394424+5009222491+3607312525+8962074949+1162261192+0674921071+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad); Ads by Google
Fix It Scratch RemoverRepairs Scratches Like Magic! As Seen on TV. Guaranteed.
www.AsSeenOnTvAdvisor.com/FixIt
  • Run warm water over the damaged disc to remove dust.
  • If there is stubborn dirt or grease on the disc, gently rub it with your finger while you are washing it, and use a gentle detergent or liquid soap (with the water) or rubbing alcohol (in place of water). Any time you rub or wipe a CD, you should do so by starting at or near the center of the disc and rubbing straight outward toward the edge to prevent further scratching.
  • Shake the water off and let the disc air-dry (do not dry it with a towel or cloth, and don't sun-dry it either).
  • 2Try to play the disc. Many times a good cleaning is all that is needed. If, however, problems persist after cleaning, try to play the disc in a different CD player. Some players handle scratches better than others; computer CD drives and car stereos tend to be the best.
  • 3Burn a new disc. If you can get the CD to work in one CD player - especially your computer’s - but not in others, try burning a new disc. The CD burner on your computer may be able to read the CD well enough to produce a perfect copy. You may wish to try this even if the CD doesn’t play correctly on the computer.
  • 4Locate the scratch. Actually repairing the disc will be easier if you can figure out where the offending scratch is. Visually inspect the CD’s playing surface for scratches or scuffs. Scratches that run perpendicular to the CD’s spiral - that is, those that run generally from the center to the rim - may
  • on Mar 23, 2010 | Computers & Internet
    Thanks everyone. I should clarify that the cds that will not play in the right hand tray (originals) are as pre-recorded by a record company; for example, an ABBA cd which I used to be able to play, I...
    What does the lower surface look like? Does it have a lot of scratches or is it perfect? Many times the condition of the optical surface of the disc can affect the results you have. The disc is scratched can be polished. Burned disc only have about 70% of the output that a pressed disc has so sometimes you need to burn a new one.
    Dec 09, 2012 | Philips CDR775 2-Disc CD Recorder
    2005 pt cruiser cd player rejects cd and shows err
    Either it's a bad CD (format, or scratches), or you have a faulty CD Player. If the CD player is bad, it is likely much cheaper to just buy a new one, than to fix the factory one.
    Jun 07, 2012 | 2005 Chrysler PT Cruiser
    My dvd player was working fine this morning and now it's not reading discs. What can I do to fix this or do I need to buy a new dvd player? It is a Dual Deck DVD/VCR Player MVD4544 model
    Good day!
    This are the common and basic causes reading disc failure of DVD players.Try this D.I.Y procedure before you buy a new player.
    1. Check the CD itself.If the CD got many scratches,replace it.
    2. Clean the DVD lens using CD cleaner.
    3. Try to use other new CD or the one with no scratch.
    4. If the steps # 1 to 3 are not successful.The problem could be on DVD lens.
    5. If the DVD lens is defective you better to buy a new player.Because the lens is expensive and it is not easy to install on DVD player.
    I hope this information will be helpful.Thank you and good luck.
    Apr 25, 2011 | Memorex MVD4544 DVD Recorder/VCR
    The cd player on my 2002 gmc envoy reads 'player error'. How can it be fixed?
    purchase an optical disc cleaner disc and put it in your cd player and let it play through and then try a cd. make sure your cds are clean, smudge and not deep scratches. toothpaste makes a good cd cleaner for scratched discs. make sure to use soft cloth
    Jul 14, 2010 | 2002 GMC Envoy
    Cd player flashes ''error'' when you put a cd in. It waa playing fine. Just stopped playing ejected cd.
    try another cd wont play if too scratched or dirty. handle disc by edge, dont touch the surface of disc no matter how lightly you hold it, you will leave contaminants that cloud the surface. if none ever work try them in a house cd player still no joy, then discs aare no good, if they work in home player then car cd died, time for new one. heck who uses cd any more? its a hassle to change them (only 16 songs!), hassle to replace lost daamaged or stolen(borrowed by friends), skip or scratches, get a radio with usb reader/player or SD card reader, can be had for under $60 , an 8gb SD card for $25 (4,000 songs<do you even KNOW the names of that many songs?) PLus, without a cd slot the thieves should leave your radio alone, thinking its just a normal am/fm radio. goto www.dealextreme.com for great deals and FREE SHIPPING.
    Jun 21, 2010 | 2001 Chevrolet Silverado 1500
    Trouble Reading Discs
    There are two possibilities either there is dirt on the CD lens that needs to be cleaned off. Or the lens has a scratch on it and will need to be replaced.
    Apr 15, 2017 | Durabrand CD/MP3 Player, CD-968 Personal...
    Cd player
    You need a new laser in it. Lasers for most philips and sonys are about $40 if you fit them yourself.
    Jul 28, 2007 | KLH CDR2000 2-Disc CD Recorder
     Grubhead
    Grubhead
