I have an error code E6 on my Bosch Front Loader Maxx Washing Machine, can you please advise what this error is and how to fix??
  • 3,051 Answers
Hello there
Normally this is a drainage problem code
Unplug the machine and wait for 30 min
During this time Remove the cover on the front bottom right corner or the front cover at the bottom , use the small hose that is attached to the pump to drain the water, from the pump then unscrew the large drain cover and remove the blockage from the drain pump. and any additional hoses then reattach the hoses and then plug in after the 30 minutes is up then press the cancel button and test ...Test by pouring 1L water into section II in the top and setting the machine to 'drain'. it should beging to drain
Posted on Mar 07, 2011
Is it worth fixing a six yr old bosch front loader washing machine with E6 problem. Not going from rinse to spin
way late reply!!! sorry but go here and see what you come up with.
great site
https://www.repairclinic.com/RepairHelp/FaultCodeLinks
Jan 02, 2018 | Bosch Washing Machines
What is error E:00 in Bosch maxx 6 washing machine?
error E:00 in Bosch Caroline, Could not find anything pertaining to this Bosch code. You may be can contact Bosch at last link posted or download manual.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Identify Bosch Washing Machine Error Codes
How to Identify an Error Code on Bosch Washing Machine
Washing Machine Error Codes Front Load and Top Load Washers
Download instruction manuals
Apr 02, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
What are WFL 2060 fault codes
Bosch WFF washing machine error codes:
E1
- The door is not closed and cannot therefore lock.
E2 - Washer will not fill with water.
E3 - Washing machine not heating.
E4 - Washing machine won't empty.
E5 - Fault in the motor drive circuit.
E6 - Unexpected heating.
E7 - NTC thermistor open or short circuit.
Please note that the codes for the WFF range of Bosch machines differs from other ranges.
Sep 04, 2014 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Maxx Classic front loader makes a loud banging noise before starting up spin cycle, and lately has displayed the E6 error message. Not sure what is causing this.
an addition.. pulled one apart, pulled drum apart and guess what I found.. the so called "spider"(the thing that attaches spindle that goes into bearing, and other side connects to the steel drum) is made if alloy and TOTALLY corroded by detergent.. Bosch didn't know that detergent is a corrosive substance???? I guess German engineers are .. put your own word.. ;)
Jan 13, 2011 | Washing Machines
Front Loader Washer Door Hinge broken
There are a couple of sites you can try.
WWW.ESPARES.CO.UK/BOSCH
WWW.4BOSCH.CO.UK/SPARES
Please rate my solution.
Thankyou
Feb 06, 2010 | Bosch Washing Machines
I have a bosch maxx Wlf1600 front loader washing machine
This will require a replacement door lock,easy replacement & part very cheap
Jun 08, 2009 | Audiovox Bosch 718 World Cellular Phone
EO4 POPS UP ON MY bOSH FRONT LOADER WFMC33O1UC
I had error code E06 come up on my Bosch Washing machine and since cleaning out the pipe as suggested, turning the machine back on to run a wash, error code E04 has now popped up...please advise asap what's the best thing for me to do...many thanks :)
Dec 05, 2008 | Washing Machines
Bosch washer error code e3 what does it mean?
Error "E3" on a Bosch front loader means there is a problem with the door. Either it is not closed properly (user error or a blockage) or the locking mechanism has a fault. Check to see that there is no object shoved in the latch hole (our 2yo just did that) preventing the door from closing properly. If it is not that, a technician is advised. I tried to get into the machine to fix out issue but could not get to where the issue is.
Aug 02, 2008 | Bosch Washing Machines
Washing Machines Logo
11,211 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
