Question about Refrigerators
MIELE FRIDGE FREEZER MODEL KF 6445 SN-6
I HAVE THIS FRIDGE FREEZER AT WORK (I WAS GOING TO BRING IT HOME UNTIL I DISCOVERED A PROBLEM) THE FREEZER IS WORKING PERFECTLY (TEMP SAYS -18 TO -20 ALL THE TIME)THE FRIDGE HOWEVER IS LETTING THE TEMPERATURE GET TOO HIGH BEFORE COMING BACK ON (+15 SOMETIMES) ALTHOUGH WHEN IT DOES COME ON IT RUNS UNTIL THE RIGHT TEMPERATURE IS REACHED (+4 TO +6) IS THERE A THERMISTOR/SENSOR ON THIS MODEL? I KNOW THAT CERTAIN HOTPOINT FRIDGE FREEZERS (THE MISTRAL RANGE FOR EXAMPLE) HAVE THERMISTORS/SENSORS FOR THE FRIDGE + FREEZER THAT PLUG INTO THE MAIN CIRCUIT/CONTROL BOARD AT THE TOP (THEY ARE ALSO A COMMON FAULT) I HAVE SEARCHED THE NET LOOKING FOR INFO ON THIS MODEL BUT CANT SEEM TO FIND ANYTHING TO GIVE ME ANY CLUES ALSO IF THEY DO HAVE A THERMISTOR/SENSOR ANY IDEAS WHERE I MIGHT GET ONE I AM A DOMESTIC APPLIANCE ENGINEER SO I COULD FIT IT MYSELF I JUST DONT REALLY WORK ON REFRIGERATION VERY OFTEN! ANY HELP WOULD BE GREATLY APPRECIATED AS THIS FRIDGE FREEZER IS WAY TOO GOOD TO SCRAP AS YOU WILL KNOW MIELE MAKE PROBABLY THE BEST QUALITY APPLIANCES AVAILABLE
5 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: I have a 10 year
thanks for the question yes it very well could i would pull fridge away from the wall and clean the condenser if dirty makes all the difference especially in that heat thanks the appliance doc
Posted on Sep 24, 2008
peyton32034
  • 410 Answers
SOURCE: Freezer switching off on Hotpoint Iced Diamond Fridge Freezer
home refrigerators are not dsigned to work in areas where the temps will drop below about 45 f to my knowledge there is no way to help wiht this problem. Thx peyton
Posted on Jan 29, 2009
  • 531 Answers
SOURCE: refrig/freezer thermistor temp/resistance chart needed
by model# you can get it not all carry the same (temp)
Posted on Apr 07, 2009
SOURCE: Samsung Quattro-Cooling RM255LABP Freezer at +20F
orrixcreek i have the same problem. how do you go into the samsung diagnostic? i pressed different buttons at the same time and they're giving me gibberish i dont understand. which specific buttons to press and what exactly do the codes mean? i called samsung and they told me the fridge was probably in "demo mode" that is used on the sales floor and they had me pressed the two left buttons for 6 seconds and a bleep occurred and the LCD went dim. it really didnt fix the problem.
Posted on Jul 20, 2009
  • 102 Answers
SOURCE: 642s Temp Setting Does Not Work
Possibly, but check your condensor before calling for service.
Posted on Aug 05, 2009
Miele KFN8993SDN Freezer temperature to high
Temperature displays
During normal operation, the temperature display shows the temperature in the middle of the refrigerator section and the temperature in the warmest part of the freezer section.
Aug 20, 2015 | Miele KFN12923 SD-2 Stainless Steel 369 l...
I have got miele fridge freezer but the fridge keep freezing what can I do
Usually a faulty temp sensor on the fridge evaporator, not an easy repair for most, I would personally recommend Miele's fix priced repairs
Service Repair Miele Support Miele UK
Sep 19, 2014 | Miele KFN12923 SD-2 Fridge Freezer, A...
Can a Miele fridge freezer with both sections warm, fans working, be repaired?
You mean it's not an auto-defrost model? It should be, no older than it is.
Sep 05, 2014 | Refrigerators
Can a Miele Fridge Freezer, warm in both sections, fan working - be repaired
All too often it IS the fan, but not always the way you think. the impeller on the fan is simple plastic an clips on the motor shaft. and can come off very easily. Since there are not two compressors in many refrigerator/freezer combos due to both production and operation costs, the refrigerator "borrows" some of the cold from the freezer so the fan on the freezer side not operating properly will allow the coils to ice up internally, on those that only have the fan on the refrigerator side this is multiplied by the galley way icing up, blocking the cold air from reaching the refrigerator side
Fridge light bulb
Not sure how the light socket only has 6V supply? The bulb for this fridge is a pretty standard 15 Watt/230V SES lamp. If you are sure the current lamp is OK I would suggest the door lamp switch has issues. Try pressing and releasing the door switch manually and check that it functions ok without getting stuck or any sluggish movement. This action in itself may fix the problem.
Jan 18, 2014 | Miele KFN8462S Bottom Freezer Refrigerator
Ice buildup Model 795-78402-802 Kenmore SN:
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 29, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Miele bottom freezer / fridge. Main control panel
Electronic is about 150 pounds plus vat
Ring Miele in UK on phone number below.
01235 233133
Jan 10, 2010 | Miele KF7642S Bottom Freezer Refrigerator
Fridge Freezer will not maintain fridge temp, but freezer fine
My miele fridge freezer has just come up with a fault code F4 where the temp is... what does this mean and how can we fix it???
Dec 30, 2009 | Miele KFN8762SDED Bottom Freezer...
Miele KFN8462S fridge freezer is displaying an F2 fault code.
F2 Is fridge evaporator sensor faulty it will require new sensor part no.7323301
Apr 01, 2009 | Miele KFN8462S Bottom Freezer Refrigerator
MIELE KFN8762SDED (SS/fridge/freezer)
No problem just use the + and - buttons when you have chosen the temp. you want just let go and that is the temp the fridge or freezer will set at.
Aug 19, 2008 | Miele KFN8762SDED Bottom Freezer...
Refrigerators Logo
291 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
