I have a toshiba laptop (VISTA Ultimate) that connects wirelessly to a Linksys router. I try to connect to my office ftp site but always get a timeout. I've tried both the FTP commands (DOS) and the windows explorer address bar ie: ftp://dwrftp.atate.co.us I cannot connect to this ftp site. Can you tell me if I have settings wrong on the linksys router?
  • 3 more comments
  • vbeal Jul 30, 2008
    1) The router has been reset numerous times during the past year.
    2) I have never been able to connect to this FTP site from my Vista laptop.
    So, I don't think resetting the router is the answer.... but thanks.
    I can connect to other websites .... http, https. I don't know any other FTP sites to try directly .... can you give me one and I'll try it?
    battlesmith, I cannot conect to ftp://ftp.thecpl.com . I can ping both ftp://dwrftp.state.co.us and ftp://ftp.thecpl.com and get a reply though ...
  • vbeal Jul 31, 2008
    Battlesmith:
    I don't know how to do a port forward for FTP on the linksys router. Can you help me with that?
  • vbeal Aug 01, 2008
    The link didn't help since I don't have those particular tabs .... I contacted Linksys to get additional help. After talking with Linksys Tech Support, I believe now that my ISP is blocking the FTP ports. I don't think it is related to the router at all.
    So, I guess I'm out 10 bucks but since you did try to help me, I thank you ...
  • 282 Answers
Try to download filezilla here
please try to check if your firewalls are already disabled.
Posted on Jul 30, 2008
  • clark styx valencia
    clark styx valencia Jul 30, 2008
    1. Ensure that Port 21 is open in your Vista Firewall.
    2. Check to see if you can connect to the server using active mode.
      1. Open command prompt
      2. Type ftp and press enter
      3. type open sitename.com and press enter
      4. Enter your name and password as prompted
      5. Type dir and press enter. If you see the directory structure of the FTP server then you know that you can connect.
      6. Type close and press enter
      7. Type quit and press enter
    3. Change settings in IE 7 (I only tested this fix with IE7)
    4. Under the Advanced tab in IE Tools\Options
      1. Uncheck the “Use Passive FTP (for firewall and DSL modem…) checkbox
      2. Check the “Enable FTP folder view (outside of Internet Explorer” checkbox
    Brigadier General:
  • 6,966 Answers
To my knowledge (WRT54G and WRT300N), requires that port forwarding be setup for FTPs. To setup port forwarding on these routers, your Toshiba laptop needs to have a static IP address. Say 192.168.1.11 (SubNet Mask 255.255.255.0 Default Gateway 192.168.1.1).
Access the LinkSys Web Interface (browser to 192.168.1.1, enter User Name and Password). Click on Security tab, un-check "Block Anonymous Internet Requests", Save Settings, Click "Applications & Gaming", click on "Port Range Forward", Enter:
  • Application "FTP1"
  • Start "21"
  • End "21"
  • Protocol "Both"
  • IP Address "192.168.1.11"
  • Enable "Check"
Click on Save Settings.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Jul 30, 2008
    Hi again,
    The above procedure is not usually necessary for most FTP sites, however, since you could not connect to your office's FTP site, the above should resolve your concern.
    Cheers.
  • Louie  Role
    Additionally, you may want to check/reconfigure your Vista firewall and/or antivirus.
    Genius:
  • 1,689 Answers
Do you have ports forwarded and triggered in the linksys router? by default t a linksys router defince FTP on port 21 (which is the default to every router / firewall)
do you have another computer that has the same problem?
perhaps another PC behind the linksys that can access the FTP site?
  • marlon john madrid
    marlon john madrid Jul 30, 2008
    do you have another computer BEHIND the linksys router that can access the FTP site? because if not there is a possibility that you are trying to access an FTP site that is configured for domain log-in, like one that corporate offices use.
    because for some reason i cannot ping the ftp site you gave, nor perform a trace route to it, do you happen to have the IP address of this FTP site?
    linksys' database, well a part of it
    ftp://ftp.linksys.com
    Master:
  • 382 Answers
Well Apart from your office Ftp are you able to connect to other websites???...
Please post back for further assistance...Thank you!!!...
Regards!!!..
  • 3 more comments
  • Natesan Sabesan
    Natesan Sabesan Jul 30, 2008
    Please Try with this Ftp Site and do reply back if you can connect to it or not
    ftp://ftp.thecpl.com/
  • Natesan Sabesan
    Also You can try typing: ftp://username:password@ftp.ddrtoys.com for a delightfully unsecure way to connect to your site.
  • Natesan Sabesan
    Well then if you cannot access any ftp then you can try the method which i have posted!..The possible reason is your behind a Firewall so your restricted and cannot access a ftp..So try to disable the firewall and Then try to "portforwarding option" which should solve your problem!!
    Good luck!!...Regards!!!...
  • Natesan Sabesan
    Natesan Sabesan Jul 31, 2008
    Hello vbeal,
    Please check out the following link which has a detailed,step by step and pictorial representation of how to port forward a linksys router to Ftp...
    http://www.dnsexit.com/support/knowledge...
    Hope this helps you !..Dont forget to rate my solution buddy!!!..Please post back for further assistance..Thank you!!...
  • Natesan Sabesan
    Natesan Sabesan Aug 01, 2008
    Well Even then you can try to access ftp ananmously by the method i told you before..Anyways do rate my solution...Thank you...
    Regards!!..
    Master:
  • 848 Answers
Just try reset in router .......
Toshiba Satellite P10-S429 cannot acquire an IP address. Here's the deal: I'm running Windows XP SP3 on the Toshiba with a Linksys WUSB54GC v.3 wireless adapter. The laptop does not have a wireless...
I would start by downloading all available drivers from Toshiba, just in case some have been updated. If you hard wire the laptop and from the Toshiba web site, follow the prompts to find all drivers for your exact model.
Laptops LCD Televisions Projectors Medical Imaging More Toshiba America Inc
Mar 13, 2017 | Toshiba Satellite Pro L300-EZ1501 Notebook
I can not connect this wireless router to my toshiba satellite laptop x205. I have tried everything I know. Machine is running Windows Vista. There is another laptop in the house (an Acer) that connects...
I fixed the problem. The problem is that Toshiba Satellite Laptops do not like Channel 6, so I moved it to Channel 11 and both laptops were working on it.
Jan 12, 2010 | Linksys WRT160N Wireless Router
I cannot make a wireless connection my new laptop to the linksys router. My homenetwork works and my first laptop is connected to a wireless linksys connection. when adding another laptop I cannot make a...
then it's the second computer's problem, try repairing the connection, turning the wireless switch on and off, rebooting, and if your using vista use windows system file checker
or if xp, put this in either command prompt or run
chkdsk /r
Sep 30, 2009 | Linksys Wireless-G WRT54GS Router...
Empowering technology framework incompatible with vista ultimate
downlaod all Empowering tech software from Acer direct for ur notebook
see link pls rate FIXYA fo rhelp
ftp://ftp.support.acer-euro.com/notebook/aspire_5315/vista/Applications/
Apr 18, 2009 | Acer Aspire 5315 Notebook
Toshiba Satellie P305D Wireless Connection Issue
If you are having an issue with your wireless at home, try changing the security settings on your router i.e changing the password, or encryption type.
Mar 16, 2009 | Computers & Internet
Toshiba WRC 1000 as a Wireless bridge
lets get the picture right. laptop connects to a wireless router. then u want to plug into laptop ethernet wan port of linksys ? you have to set router manual settings to gateway which is ip of toshiba... this is a fun topic. ive connected xbox360 to laptop this way.. never tried router. "fun times ahead!"
Oct 10, 2008 | Toshiba WRC 1000 Wireless...
Wireless connection
try go to www.linksys.com you can check a hundreds of variety routers and advices..
Goodluck!!!
Feb 07, 2008 | Toshiba Satellite A135-S2276 Notebook
Linksys WAP11 Wireless-B (802.11b) Access Point
you have to go into the routers settings, by typing it's ip address (refer to manual) in your internet browser and look for DHCP and make sure that it is enabled to automatically assign both your pcs an ip address. This must be done using a lan RJ45 cable that was supplied; first before going wireless. Next go to each pc and either use the wireless network setup wizard or go to your wireless network connections (in control panel>network connections) and right click on the connection(this is not the lan connection icon, make sure you choose your wireless icon) and select properties, then click the internet protocol line TCP/IP and again click properties. make sure that 'Obtain IP address automatically is ticked and click ok. Your pcs may need a restart and should find the router will be seen in your found connections, click connect and your away
Aug 10, 2007 | Linksys Instant 802.11b Wireless Network...
Computers & Internet Logo
David Payne
David Payne
