Laptop Wireless Connection Problem
My acer laptop computer wont let my AT&T GSM wireless devise connect...I believe the problem is Acer's system manager.
Is there a way to get around it or shut it down?
    Novelist:
    Scholar:
  • 125 Answers
I have previous experience with this wireless connections. I'm not familiar with AT T GSM device. In my experience I found that the manager can play up, but you can switch to windows manager depending on what windows you have. In Windows XP go to your control panel. Click on network connections, then select the wireless network connection. On the screen a window with the network connections should appear. Then on the left hand side down the bottom it will have Change advanced settings, and click on that. Then another screen appears with Wireless Network Connection Properties. Click on Tab Wireless Networks. On that page click on "Use Windows to Configure my wireless network". Once done, click okay or apply if appears. Restart computer and see if windows picks up you wireless connection provided you have WIFI on your laptop! Try that, let me know if you need more help!
Posted on Aug 01, 2008
Acer wont connect to internet with either ethernet or wireless.
There is a possibility that there is a fault with the drivers, you may want to contact your local Acer office as the site drivers are not always the correct one, other than being able to look at it personally you may also want to a good local repair/service centre to test the lan and the wifi card, good luck.
May 13, 2015 | Acer Aspire 5736z 4460 Laptop
Cannot connect to the internet.
If your using wireless, make sure your wireless adapter is on. Look on the F1, F2, F3, (etc.) keys. Find a little icon that looks like a cell tower. Press FN and that key and your wireless adapter will be activated and you should be able to connect to wifi. Other advice, make sure your LAN is active, too. I'm not specifically sure how to do this, it depends on the operating system, and I just plainly don't know. Anyway, if none of this works, go to Acer's website and download the Wireless LAN drivers. You can install them and restart the computer, it should work. Good Luck!
Jun 11, 2013 | Acer Extensa 5620-4020 Notebook
532h wireless
The Acer Aspire One is an inexpensive laptop computer that runs the Windows operating system. The computer does come with a built in Wi-Fi receiver, giving you the ability to connect to a wireless Internet network, when available.
However, if you are having trouble connecting to a wireless network, you must troubleshoot the network connection to determine exactly what is causing the problem with the Internet.
Check the wireless router and high-speed modem.
If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
Activate the wireless Internet connection on the laptop computer.
Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu.
Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
Select the appropriate network you wish to connect to.
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire.
Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
Restart the computer.
The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
also
Turn on your computer and locate the Wi-Fi icon.
This could be located on the upper row on a laptop it will have the radiation look (((·)))
Make sure its pressed on.
The internet connection is located in the system tray in the bottom-right corner of the screen.
The icon looks like a series of rectangles that increase in size from left to right.
Right-click the Wi-Fi icon and select "Connect to a network."
You will see a list of available wireless networks.
Wireless Acer laptop can be a massive boon to your productivity when it is working properly and a massive headache when it is not.
When your laptop card begins to exhibit undesirable symptoms, such as signal dropping, you can avoid a hefty repair bill by performing at-home troubleshooting.
The best solution is to merely reinstall the software driver, which refers to the program that the operating system uses to speak the wireless card's language.
Open your operating manual and look up the model name and number for your laptop.
Navigate to the Acer Support web page (see Below) and click on the "Downloads" link.
http://support.acer.com/
Input the model number of your laptop, click on the "Search" button, download the wireless driver file for your laptop model and save the file to your desktop.
Open the "Start" menu, click on "Control Panel" and open "Device Manager."
Open the "Network Adapters" menu, double-click on your wireless card, select the "Drivers" tab, click on the "Update Drivers" button and choose the desktop as the location to search for new drivers.
Click "Next" to reinstall the driver, fixing your wireless woes.
Apr 27, 2013 | Acer Aspire One PC Notebook
No enternet access
hope this helps
Sep 26, 2012 | Linksys Wirless Router Wrt54gs V7 Router...
Acer Aspire 5733 Wireless connection lost
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
hope this helps
Sep 13, 2012 | Acer Aspire 5733 Laptop
How to connect the wifi to a acer aspire 5733z - 4851 laptop
Check the wireless router and high-speed modem. If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
  • 2 Activate the wireless Internet connection on the laptop computer. Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu. Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
  • 3 Select the appropriate network you wish to connect to. Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
  • 4 Restart the computer. The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
  • Oct 09, 2011 | Computers & Internet
    Acer laptop with vista no internet connectiom
    check the pc propperty if netork adapter are installed for direct contackt with lan
    also check the wireles adapter are installed
    for donload from this devises (drivers) go to acer.nl and go to suprort and dowloding
    http://www.acer.nl/acer/service.do?LanguageISOCtxParam=nl&miu10einu24.current.attN2B2F2EEF=3744&sp=page15e&ctx2.c2att1=3&miu10ekcond13.attN2B2F2EEF=3744&CountryISOCtxParam=NL&ctx1.att21k=1&CRC=2939325947
    ben.pluijm@viveole.com
    Aug 19, 2009 | Acer Computers & Internet
    Acer Notebook Wireless Assistant Accidentally Deleted
    goto acer.com goto support thendrivers and downloads select model and make and it will give you a list of all drivers for your laptop
    Feb 15, 2009 | Acer Aspire 4720 Notebook
    Cannot enable wireless on my Acer Aspire 5612WLMi
    First, does the modem show up in the device manager (without an exclamation mark or an "x". In other words, does the computer see the card and is it not reporting any problems.
    Second, do you see the wireless connection when you go into My Network Places and Network Connections?
    Third, does the wireless connection icon appear in the system tray?
    Art
    Jan 15, 2009 | Acer Computers & Internet
    Wireless connection to my laptop
    you can't partially wipe your system
    do you want to format
    open control panel network connections see if network shows then right click then enable if you don't see enable then click repair
    check devices see if your wireless still shows maybe needs updated
    let me know if you are connected you may need to reinstall driver
    i can help
    Dec 27, 2008 | Acer Aspire 6930-6771 Laptop
    Computers & Internet Logo
    154 people viewed this question
    David Payne
    David Payne
