Question about Canon CanoScan 4200F Flatbed Scanner
Canoscan 4200f clicking noise when turned on
My scanner was working fine until- after trying to scan a page of a book it refused to scan and makes a continuous clicking noise - rather like a gear box out of sync. I would like to strip it down as I think something has stuck and needs freeing. Am not sure how to get the cover off - alternatively I need to know where the nearest service department is - I live in Sheffield South Yorkshire
thanks for your advice - in anticipation
  • iiiioooorrrr Sep 07, 2008
    yes, my scanner is making this loud clicking noise after the preview is complete. I hope to scan slides and pictures into a powerpoint, but the scanner stopped working correctly after 9 slides.
Cool. I bought the scanner 2-3 years ago and i had the same problem. I gave it back, received a new one ... exactly the same noise ... on 3 different computers. **** product!
Posted on Oct 03, 2008
My scanner is not work!! the error code is # 2,178,0!!! canner model is 4200f. pls help
Make sure if your scanning documents that the white plastic shield is on and if your scanning film this need to be removed. Make sure you also selected the proper item that you are scanning.
Mar 28, 2011 | Canon CanoScan 4200F Flatbed Scanner
Film scaning options are missed in Select Source
I had the same problem. My solution is: "Just go to settings on Canoscan Toolbox. Then go to copy button, drop down and select scan2. This comes "Copy" as default setting. Change it to scan2. Click ok. On Canoscan toolbox main interface click scan2 and bingo, you'll see film option on select source . Hope this works
Jan 30, 2011 | Canon CanoScan 4200F Flatbed Scanner
I have a 4200F scanner. I am scanning a scrap book page, which use to take a couple of minutes now is ten minutes or more before a picture appears on the screen. A tech earlier today said to plug the USB...
I had a similar problem - I fixed it by connecting direct to a USB 2.0 port rather than going through an old hub, which is maybe what the tech meant. I take it you haven't accidentally set the res too high?
Jan 21, 2011 | Canon CanoScan 4200F Flatbed Scanner
I have a Canon Cano Scan 4200f. It worked in the
First, try unplugging and re-seating the USB cable in your computer. I am assuming your scanner is not making any noise when you first turn on the computer. If that is not the case, respond back with more information. This is the most common solution to this problem with these scanners though.
Dec 21, 2009 | Canon CanoScan 4200F Flatbed Scanner
Pictures scanned with Canon 4200f show streaks
when scanning photos and especially magazines, don't go to low on the dpi (at least 300) and select DESCREEN as well as grain correction: HIGH
Dec 31, 2008 | Canon CanoScan 4200F Flatbed Scanner
Lost software
You can get the software with on the Canon Home page
click on support or drivers then search your model
Jul 12, 2008 | Canon CanoScan 4200F Flatbed Scanner
Canoscan 4200f Problem with Vista 32 bit
Apr 19, 2008 | Office Equipment & Supplies
CanoScan 4200F Stuck
Unless you're scanning heavy items such as books that would put enough pressure down to prevent the scanning head from unit, then I think you need service.
Feb 23, 2008 | Canon CanoScan 4200F Flatbed Scanner
I got mine working after experiencing the same problem.
I had mine hooked up to a USB hub, after I hooked it directly to the USB ports in the back of my computer, everything just worked fine.
Weird that it worked on the USB hub on XP and not vista though.
Dec 31, 2007 | Canon CanoScan 4200F Flatbed Scanner
Cannon scan 4200f light stays on
There is a lamp shut-off time adjustment in ScanGear. Go into ScanGear's Advance Mode and click Preferences. One of the four tabs will have an option for Lamp Shut-Off time. Set it as desired.
Dec 02, 2007 | Canon CanoScan 4200F Flatbed Scanner
Canon CanoScan 4200F Flatbed Scanner Logo
340 people viewed this question
old marine
old marine
