Question about Compaq Computers & Internet
Brought a used Compaq nc6220 with windows 2000 installed. I installed Window XP Pro and some seatures do not work, i.e. wireless mode. what do I have to do to make it work, win2000 does work, but I would like to use XP Pro. I'm ready to uninstall win xp.
  • dannyg08 Aug 07, 2008
    Contacted HP, all I need is a Recovery disk, which they are forwarding one to me. All the drives are available for what I trying to do, thanks for all the help, but after coping the drives, you could not download to the system.
    Thank you all for the help and input
    Yes, without it I wouldn't have gotten to the solution. Thank you
    Genius:
  • 1,226 Answers
same if you use winxp then you should install the drivers to work all hardwares,
You should install the wireless drivers, you can find it here:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=447348&taskId=135&prodTypeId=321957&prodSeriesId=447371&submit.y=6&submit.x=10&lang=en&cc=us
however if this still not work you recommended to use win2000 for smooth operation.
melnavz
Posted on Aug 07, 2008
    Sergeant:
    Champion:
  • 246 Answers
IF you can format the machine and reinstall the New Windows XP Service pack 2.
You can work as windows 2000
Good luck
  • 6,487 Answers
Using the recovery Disk will really be halpful on this concern...
Good luck just contact us back if you still need help.....
    Genius:
  • 1,689 Answers
No need for you to uninstall XP and go back to 2000, all you have to do is install the XP drivers for the components that are not working.
for you to be able to know what are the components inside your computer, go to system information, look for the devices that are not working so that you will be abel to download the drivers for each specific device in your computer. because once you have the specific models and brands of the components in your computer, it will be easier to get the XP drivers online.
to go to system information, click start, accesories, system tool then syste, information.
good luck, hope this helps.
Posted on Jul 30, 2008
    Brigadier General:
  • 6,966 Answers
For your Compaq NC6220, Win XP drivers are here. Alternately, if you are reverting back to Win2K, then there should be no issues as most other drivers for other OS are here.
On the WiFi, you need to determine which hardware the NC6220 is using. To my understanding, depending on the regional version, they could be IntelPro or Broadcom.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
    Genius:
  • 2,028 Answers
You will need to download the drivers for the devices that aren't working. You can find the drivers at the link bellow.
http://h18000.www1.hp.com/cpq_support.html
  • 2 more comments
  • Ryan Rogers
    Ryan Rogers Jul 31, 2008
    Open the device manager, any devices that need driver will have a yellow question mark on them. You can find a complete set of drivers for your machine running XP, plus updates, and patches, at the link I posted in my previous response.
  • Ryan Rogers
    Ryan Rogers Aug 02, 2008
    Did you find the drivers?
  • Ryan Rogers
    Ryan Rogers Aug 06, 2008
    Just wondering if you found the problem?
  • Ryan Rogers
    Ryan Rogers Aug 07, 2008
    Good to hear.
I want to format compaq nc6220 but i dont know the command to give
the best way is you wil to recovery software coming with your computer go to resinstall software to the factory setup. or when you restart hold the f11 key and go to the reinstall and proceed witht the step. the same software will ask you permission for to format the HD.God bless you
Apr 02, 2013 | HP Compaq nc6220 Notebook
Sound driver for compaq nc6220
You can download the drivers from the Compaq/HPWEB support/download page. Make sure you select your model laptop and the XP orVista Windows version of the drivers you require and install them. Click onthis link to download the drivers: -
www.compaq.com/country/cpq_support.html
Nov 05, 2010 | HP Compaq nc6220 Notebook
Wireless driver could not be installed
Did you try to update to SP3 this may have the correct driver for it......Try and hook up the computer to the router with an ethernet wire to download SP3......If this does not work remove the wireless card and read the numbers off and go to driversguide.com and look for the driver
Mar 24, 2009 | HP Compaq nc6220 Notebook
I have pbl with my sound . no sound here after new window
Go to
http://www.hp.com
and click on a Support Link
Download Sound Driver for HP Compaq nc6220.
Then Install the Software/Driver.
Usually this will fix the problem unless you have problem with sound card itself.
Jan 29, 2009 | HP Compaq nc6220 Notebook
Cannot find hard drive while installing MS XP on a hp nc6220 laptop.
hi
It used to happen like this during the new installation.
goto BIOS setup and check that the HDD is correctely detected. check the size it reported. If its correct, give one more try. else the HDD firmware is corrupted and can be repaired.
thank you
Aug 15, 2008 | Microsoft Windows XP Professional for PC
Problems with compaq F739AU
Sometimes, the Vsta drivers that came with your unit also works with XP. try to run the vista drivers you have and update us.
May 21, 2008 | Compaq Presario 700 470024-192 Notebook
Drivers not found.
Your Compaq came with Vista installed. Finding drivers for XP Pro with SP2 seem to be very troublesome. Somewhere HP Compaq has these drivers for you laptop. If you call them & they find out you bought XP Pro they will not support you in finding the proper drivers for XP Pro. How ever you can call & ask what it will cost for a recovery CD for XP Pro w/SP2.
Click the link to Compaq & listed is your laptop & what software & drivers are listed. If you need other drivers that are not listed, post what you want I'll try & find them for you. Please be as detailed as possible.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=3641194&lang=en
You may find some here.
http://search.hp.com/query.html?sh=1&charset=UTF-8&la=en&qt=drivers%20for%20XP%20A902TU%20Notebook
Feb 19, 2008 | Computers & Internet
STUCK IN WINDOWS XP INSTALLATION
you need restart your installation using your winxp cd. you can also go to your DOS mode by using your 3.5 floppy win2000 start up disk.
Jan 13, 2008 | Compaq Deskpro EN PC Desktop
Can't reinstall xp pro on my hp compaq nc6320
Stephane, I ran into the same problem after wiping out my Compaq nc6320 and trying to install XP Pro. The fix is to disable SATA Native mode. To do this: Enter F10 Setup then System Configuration>Device Configurations>SATA Native Mode and disable it, save the changes and now you should be able to install XP Pro. Remember, when I did this the drive was blank, I don't know if that makes a difference or not. Best of luck! Bryan P.S. If you want to enable SATA native mode after you have installed XP Pro check out this link: http://forums1.itrc.hp.com/service/forums/questionanswer.do?threadId=1042050&admit=-682735245+1161793137260+28353475
Oct 04, 2006 | HP Compaq nc6320 Notebook
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
