Question about Maytag Washing Machines
I had a washer for 7 years .Last 2 month it get noise louder when it wash and rinse.Please help me how to fix it.Thank you. an
    Problem Solver:
  • 8 Answers
HI THIS SOUND LIKE THE DRUM BEARINGS AN EASY WAY TO CHECK THIS IS TO SPIN THE DRUM USING YOUR HAND & WITH THE DRUM EMPTY IF IT SOUNDS/FEELS GRUMBLY ITS YOUR BEARINGS BE AWARE THOUGH THAT IF THE BEARINGS ARE GOING YOU CAN ONLY DO MORE DAMAGE BY CONTINUING TO USE THE MACHINE YOU RISK DOING DAMAGE TO THE HEATER AND EVEN THE OUTER DRUM IF THE BEARINGS COLLAPSE WHICH THEY USUALLY DO WHEN YOU CARRY ON USING THE MACHINE HOPE THIS HELPS!
Posted on Jul 30, 2008
Have ge model WCVH6800J1MV Will be 1 year old in Nov. it bangs and walks across the floor. it also vibrates and makes loud "clicking" noises have had five service repair visits all to no...
had the same problem but 7 or 8 months it started had it replaced and 7 or 8 months on new again same problem, a speed wash which is 36 mins takes 1.5 to 2 hrs
Oct 27, 2010 | GE WBVH6240F Front Load Washer
Washing machine began squealing like a bad bearing
my first thought is belts, but maybe pump
need more info for proper dianosis
Apr 24, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Extremely loud noise during spin cycle of my Neptune dryer--just started happening in the last month. The dryer is probably 7-8 years old, so it's not the newer Neptune model.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
hgd76
Jun 26, 2009 | Maytag Neptune Washer
Grinding noise from hell - no spin, no agitation (except my own!).
Please see the following link for all possible troubleshooting tips:
http://www.repairclinic.com/0088_11_1.asp#Level1_3
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 04, 2008 | Washing Machines
Will not spin to rinse and makes a churning noise/clogged drain for softener?
When my washer did that, they came out and put in a new pump etc, and it did it again within a few months. What fixes mine, at least for the 2 years I had only that problem, was to unplug and replug the wires that go into the motor board (that'sthe one under the wash tub, not the one behind the dials. Then it would be fixed for a month or two. The wire harness (and I never pinpointed exactly which one, just did them all) would come a little lose. I took the front part off the washer so that I have constant access to that part. This last time when it did it, tho, this did not fix the problem. Instead, it seems that my wax motor for the door lock had failed, and I cooked R11. As a temporary fix, I cut the R11 out of the control board (the one behind the dials), and inserted a popsicle stick into the microswitch further from the wax motor, so the door thinks it is locked and it will spin. This results in the washer not shutting down at the end of the cycle on its own (thinks the door is still locked) so you have to manually turn it off. Since I already had the front off the machine, I just had to undo the screws to the left and right at the top to raise the top of the machine to insert my popsicle stick. It is a lovely machine, isn't it? I have the MAH3000 also.
Jul 29, 2008 | Maytag Neptune MAH6500A Front Load Washer
Kenmore washer 80 series 4 years old
my washing machine is not rinsing and spinning
Jan 20, 2008 | Kenmore 24032\24036 Top Load Washer
Amana Top Load Washer model# LW3502W Washer leaks water somewhere between wash & rinse cycle best I can tell...drain hose checks out fine. At beginning of wash cycle the first minute or two of agitation...
Sounds like the water seal is damaged and the leaking water has damaged the top bearing which is just below the water seal. You will need to have the hub & seal kit replaced.
Oct 30, 2007 | Amana ALW480DA Top Load Washer
Loud noise thourghout the cycle
I would have the counter-balancing system checked for proper motion.
Jun 07, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
