Question about Refrigerators
My fridge is not cooling down and there is a thick layer of ice coating on the inside back wall. the motor is constantly running
  • 770 Answers
You have a defrost problem you need to unthaw and it will work again for about a week until it feeezes up again .......check the defrost system
Posted on Jul 30, 2008
Water is collecting at the bottom of the fridge under the salad trays constantly
Whenever that happens on our fridge we find that the drain out the back is blocked. Have a look inside the fridge on the back wall, you may see some guttering that guides the inside moisture to a hole. That hole drains to a pan on top of the motor. Heat from the motor evaporates the water. I have always managed to clear ours by poking a bit of flexible wire down the hole. It's not a frequent occurrence, probably 7 or 8 years between blockages.
Aug 11, 2015 | Refrigerators
LEC L6046W FRIDGE - ICE/FROST INSIDE THE BACK WALL. MOTOR IS RUNNING CONSTANTLY.CLEANED ALL THE ICE OFF BUT WHEN SWITCHING BACK ON, WITHIN 10MINS THE ICE,FROST IS BACK?
1.I think you might have a thermostat problem it is over cooling the system and doesn't shut off when it is suppose to. Replace the thermostat
2.If the door seal is broken or the door is not closed shut with the seal magnet nice and tight against the fridge it will form ice inside the fridge as well. Replace the door seal. (this is very common with old fridges)
Sep 06, 2009 | Refrigerators
Fridge freezer side by side running constantly but not cooling.
Make it a habit to defrost it every week. You see, when ice forms around the evaporator tubes (which runs around the walls of fridge and freezer), heat exchange reduces (that means heat is no longer absorbed from the things inside the refrigerator) and cooling stops. See whether freezer walls or fridge walls are damaged. Do not use knives or any other sharp tools to remove ice. Do not forcefully remove items that are difficult to take out from the freezer. Defrost and remove them.
Aug 12, 2009 | Freezers
Bosch fridge not cooling freezer fine
if back wall of freezer has ice or thick build up you may have a defrost problem or if not the evaporator fan motor could be bad, not moving cold air from freezer to refrigerator.
Mar 14, 2009 | Bosch Refrigerators
Ice build up in bottom of freezer
Check the ice maker. sometimes they get cracked a will leak water into the freezer compartment. Also check the ice maker fill tube for leaks or someone could have spilled something. Although this is tipical of a clogged drain. What happens is when the fridge go into derfost, it will melt all the frost that is on the evaporator, turning it into water. The water drains down to a trough under the evaporator and down a drain hole in the trough ( this trough is behind the evaporator cover ) Removing the melted frost from the freezer. If that drain is clogged, the water cannot leave the freezer. Then when the fridge starts back up ,it will freez the water that was not drained. After repeated defrosting the water will fill this trough and run off into the bottom of the freezer to be frozzen when the fridge starts to cool again.
Nov 16, 2008 | Refrigerators
Whirlpool side by side Refrigerator not cooling, two -- where -18 temp used to be.
the fact the bowl was filled with water and that you said the inside of the freezer was coated with ice, indicates a failure of the defrost system.
now the ice has gone, reset the temps and wait to see what happens
Oct 15, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice build up
Check that the door is closing properly otherwise the freezer will be working overtime to cool and ice will form. If the door seal is good, it is possible that the thermostat needs to be checked.
Oct 02, 2008 | Refrigerators
Indesit BA139 fridge freezer with very thick frosting on back wall, but not very cold fridge section (despite changing the temp control to max) and normal very cold freezer section. When temp control...
One or more of your defrost components(defrost timer or board, defrost heater, defrost thermostat/ bi-metal) are bad. Unless you removed the inside back wall in freezer and completely thawed the evaporator, it will not cool properly.
Aug 25, 2017 | Refrigerators
Refrigerators Logo
99 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
