Question about Kenmore 24032\24036 Top Load Washer
Need the belt routing for my washing machine
I have a kenmore 70 series heavy duty .the belt is broken bought new cant figure how to install or route it.
  • carparts444 Jul 31, 2008
    I have the old belt in my hand and have it apart but need to know how to route it now...Thank you
    Genius:
  • 1,028 Answers
Unless you washer was bought prior to 1988 there is no belt ..washer is direct drive with coupling between motor and gearcase
Posted on Jul 31, 2008
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore Dryer it works but will not tumble i'ts a heavy dudy super capacity 70 series modle 110-64742400 you may need this to dwjr-ele-2406028-fm54
When the drum won't turn and the dryer is otherwise working it's usually due to a broken belt. Open the front of the machine to inspect the belt.
  1. Under the lint door remove 2 screws
  2. Use flathead screwdriver to pry up the top lid
  3. In the middle of the drum should appear a belt, if you see it, pull on it. If it is loose it's fallen off the belt tensioner. If there's no belt of if the belt breaks in your hands, you need a new belt.
A sample of the typical belt routing for your machine is available at the link below:
Kenmore Dryer Belt routing
Sep 08, 2011 | 2007 Toyota Camry
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Feb 27, 2010 | Kenmore Washing Machines
Kenmore Heavy Duty 70 Series Leaking in the back
If you bought a new washer and you still have a leak, i guess it was not the washer but where it drains into. Sink or stand pipe has a leak. unless you are useing the old drain hose from your old washer. Dry up everything and look for the sorse of water with a bright light when the washer drains .
Nov 22, 2009 | Washing Machines
I have an old Kenmore Heavy Duty 70 series washer.
its a filter inside the water hose thats still blocked or the relay inside the washer for the cold feed is not opening up fully it could just need a clean or maybe a new one fitted
Nov 05, 2009 | Kenmore 22422 Top Load Washer
Help with Kenmore washer 70 Series
I called a repair man. The machine, it turns out is gear driven, and all the gears were shot.
May 27, 2009 | Kenmore Washing Machines
Kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Feb 25, 2009 | Kenmore Washing Machines
Belt replacement on kenmore 70 series heavy duty plus
No belt on this, its a direct drive with a motor coupler..There is a tutorial for this at www.shop.washermd.com Dave
Jan 12, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
373 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
