Question about Blitzz Technology BWA711 Router (b000220deo)
Power input I have multiple AC adapters that fit my router all of which supply different amounts of electricity. I would like to know the output volts and mA so I can figure out which adapter is supposed to go to it. Thanks
I have one of these sitting in my attic dead. The power cord that is sitting with it has a DC19V 200mA output. Not 100% sure that is the right one but why else would it be there? :-)
Posted on Aug 12, 2008
  • ody1313 Aug 15, 2008
    I lied!!! it isn't the 19V 200mA... it is a 15V 500mA. For sure... I plugged it in and tried it and everything.
I HAVE AN AC ADAPTOR,… CLASS 2 TRANFORMER FOR OUTDOOR USE THAT NEEDS TO BE REPLACED.. MODEL: KMUA - 240 - 05000- 66UL INPUT: 120V - 60Hz 570mA OUTUT: 24V - 50VA
Amazon has it.
AC Power Adapter 120V input 24V 50W (50VA) output, UL listed
www.amazon.com › ... › AC Adapters
Mobile-friendly - AC 24V Power Adapter; 50W Output (50VA); 120V AC Input; UL Listed; Ivory Color item in OEM box ... 24V20AC 24V AC 20VA Transformer Input: AC 110V / 120V 60Hz Output: AC 24V 880mA
Dec 09, 2015 | Computers & Internet
How can I get a replacement power supply?
What you are after is an AC adapter this model I found on ebay has 120 volts to 240 volts to 12 volts make sure the DC voltage output matches the Voltage of your hard drive. The current output has to be the same amount or larger in value. So if your drive needs 2A a 2A or larger value means it can handle the current load put on it by the Hard drive.
http://www.ebay.com.au/itm/AC-DC-Adapter-For-SimpleTech-96300-40001-001-SimpleDrive-HD-Power-Supply-Cord-/400716519670?pt=US_Monitor_Power_Supplies&hash=item5d4c90d8f6
or
http://www.ebay.com.au/itm/12V-AC-Adapter-For-SimpleTech-Simpledrive-External-Hard-Drive-HD-Power-Supply-/281311386852?pt=Laptop_Adapters_Chargers&hash=item417f771ce4
this one below matches the exact model number of your hard drive
http://www.ebay.com.au/itm/AC-Adapter-For-SIMPLETECH-BOM-No-96300-41001-133-96300-41001-045-96300-41001-073-/400705526395?pt=US_MP3_Player_Chargers_Cradles&hash=item5d4be91a7b
Jun 04, 2014 | Simple Technology 96300-41001-073 1tb...
Motor tripping out power supply
The input to your treadmill is about 120 volts Ac. The output from the board will be about 30 Ac. Almost nothing on there will be measured in DC. Your particular issue is your motor controller. It needs to be replaced.
Jul 27, 2017 | Reebok treadmill i-run s
THERE IS A LONG TIME AGO SINCE I DONT WORK WITH MY MICROTEST PENTASCANNER AND I DO NOT KNOW IF THE AC ADAPTER HAS AN OUPUT OF 9.VOLTS I AMP AC OR 9 VOLTS 1AMP DC PLEASE TELL ME WHICH IS THE RIGHT AC...
An AC adapter should output DC. The device should say next to the power plug what voltage input it requires. Also, check the AC adapter, it may say something like "Input 110-120VAC Output 9VDC".
Apr 26, 2011 | Microtest PentaScanner 350 (8180-00R)...
Hi im just wondering which connector to put my power supply to and would a 240v to 12v inverter supply the right amount of power
Check the input voltage number on the power supply. Many cameras take 110 - 240 volts. If that is the case you do not need an inverter ... if the input specifies a voltage such as 110 OR 220 then that is the voltage you must have from your inverter. If you are stepping all the way down to 12 volts then the output voltagefrom the inverter must match the input voltage for the camera. It is best to use a recepticle adapter for your power supply and make sure the power supply input and the external electrical supply match or the external supply is within the range specified on the power supply..
Mar 15, 2011 | Cameras
I recently got this laptop from someone who did not have the power supply with it. Can anyone tell me what the required power supply must output? I really don't want to fry this computer, so I want to make...
You need a charger with this features: 90W Laptop AC Adapter / Charger for HP Pavilion DV5-1125NR / DV5-1127CL Replacement
Diameter : 5.0 mm x 7.4 mm
Input Volt Type : AC
Input Volt: 110-220V (Worldwide Use)
Output Ampere : 4.74A
Output Power : 90 Watt
Output Volt : 19V
You can buy one at:
http://www.buy.com/prod/90w-laptop-ac-adapter-charger-for-hp-pavilion-dv5-1125nr-dv5-1127cl/q/loc/101/215845345.html
for $19.89 including shipping.
If this was helpful, please rate me.
Thank you
Jan 13, 2011 | HP Pavilion dv5-1125nr Notebook
Describe your Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Problem Do you have a picture of the voltage and amperage adapter for the Western Digital 250GB MyBook External HD ?
I don't have a photo of the AC adapter, but if you look on it the Voltage and Amperage specifications are;
Input: 100-240VAC / 50~60Hz
Output: 12VDC / 2A
This means the Input power can be from 100 volts to 240 Volts AC, and at 50 to 60 Hertz
The Output power is 12 Volts DC at no more than 2 Amp's. (Amperes)
Asian Power Devices Inc. has a model DA-24B12 that fits these specs.
Also a Wattac AC adapter model number - BAO362Zl-8-A01 will work.
Otherwise just use a 12 Volt, 2 Amp power pack, with a positive on center contact, and a 2mm pin hole
Nov 23, 2010 | Western Digital 250GB MyBook External USB...
I lost my GE Ultrasonic 2.1 Speaker power adapter and i need need ones but i dont know what to buy, the voltage it requires..6 or 9 volts?
at most electrical stores you can buy a universal power adaptors with a selection of socents to fit most connections. and which has a selector on it for various voltages settings.
take one of the little connectors and see which one fits. then checking the polarity on your device set the polarity the same when plugging the connector into the power supply cable. adjust voltage as needed.
Warning: when connecting a variable power adaptor alway connect on the lowest voltage setting and work up as too high voltage can distroy your appliance.
Nov 13, 2009 | GE Ultrasonic 2.1 Speaker
Adapter to connect to electricity
It is also important not only Voltage of the adapter but also Current in mA
Dec 07, 2008 | Edimax BR-6104KP Router (BR6104KP)
Cpqusbfw usb hub
i have one of those hubs the ac adapter is output +5V, and current 0.2 - 2.5A, inside of connector is pos(+), outside is neg(-), input: 100 - 120 Vac and 0.45A Max
Aug 30, 2008 | Micro Innovations Compaq CPQ24USB
Blitzz Technology BWA711 Router (b000220deo) Logo
190 people viewed this question
Top Blitzz Technology Computers & Internet Experts
Michael Galve
Michael Galve
fred capra
fred capra
Are you a Blitzz Technology Computer and Internet Expert? Answer questions, earn points and help others
