Question about Dryers
Kenmore 80 Series - No Heat - Model #110.74842400
Hi Jsrock,
I've been reading your replies to other people's problems regarding no heat in their dryer. I have the same problem. I cleaned the air duct, which had some significant amount of lint built up right at the base connection of the duct.
I wanted to see if I can service the dryer myself. I build computers for a living and do light electrical work, so I figured I would give this a shot before calling for servicing.
I kindly thank you for any information in advance jsrock.
Regards,
-eb
  • 1 more comment
  • Erik bouy Jul 31, 2008
    I apologize for lack of clarity jsrock...it is a Gas dryer, but it's also plugged in as well. I assume plugging it in for timer/heat sensor functionality, but I'm not sure, but it's definitely gas.
    Thanks for your promptness in this matter.
    Regards,
    -eb
  • lullbill Feb 25, 2009
    I am not getting any voltage to the two prong connector for the igniter when I push the start button. Where is it fed from?
    Bill B.
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Okay...the model number you provided is for a GAS dryer? Is this correct? If so, the heating portion of the dryer is different than that of an ELECTRIC dryer. A gas dryer uses a burner assembly with an ignitor. An electric dryer uses an electric coil type element. Can you please verify WHICH dryer type you have, so I'm not giving you improper advice?
    PS To answer your question...If you are technically inclined and can understand the basic concepts of electricity, you can service a dryer.
  • 5,911 Answers
Okay...just wanted to make sure. With a gas dryer, the most common failure is the ignitor. Its a glow bar type ignitor that comes on when you push the start button. Once the ignitor reaches a certain current potential, the gas safety valve opens and you'll hear gas begin to flow - followed by ignition. To check, you need to access the inside of the dryer to see if the ignitor glows. If the ignitor isn't glowing, you may assume the ignitor coil is open. If the ignitor begins to glow, but you still have no ignition, you may have an ignitor that is weak and isn't drawing enough current to open the gas safety valve. You can read the following link about glow bar type igniters:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
I know the link is for replacing an ignitor in a gas range, but theory behind the operation is the same. In particular, you need to look at the ignitor and determine if it is a Carborundum or a Norton. The current values differ.
If you can take a current reading and it is normal, and you still have no ignition, the remaining common fail item are the gas coils. There are two of them on your dryer. One is the Main and one is the Pilot Position. It is recommended that you replace BOTH at the same time (commonly sold as a set).
Go to searspartsdirect.com and type in your model number as you have it listed. Look under the "Burner Assembly" heading on the next page. The ignitor is listed as item number 4 (part #279311) and the coils are listed as items 13 and 14 respectively (part #'s 694540 & 694539). You can choose to order from this site if you like, but repairclinic.com may have these parts at a cheaper price. Do some comparative shopping to save money. Sears is great for component identification, however. I hope this helps you.
Posted on Jul 31, 2008
Kenmore Electric Dryer model #11060812990, 80 Series - dryer is working but only blowing cool air.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 15, 2011 | Kenmore 659 Electric Dryer
Kenmore series 80--no heat, replaced heating element, thermostat and fuse, what is left? thermal cut off?
Hi and welcome to FixYa I am Kelly. I can help you but... after reading all of the above it makes me wonder if just one of the 2 CB's for input power are partially tripped or... there may be a terminal problem where the power connects to the dryer on the terminal block.
DO this:
Go to the main CB box and push HARD the dryer CB to OFF then back to ON.
Test dryer
Inspect the terminal block on the back of the dryer for any signs of damage.
I can provide more help but PLEASE provide me with your model number (not Kenmore 80) so I can get you and myself the right manuals and figure out what is causing your problem.
Thanks Kelly
Mar 26, 2011 | Kenmore Dryers
Kenmore 80 series model #110.72822101 dryer ignites and is getting heat but then goes out after 15-20 seconds
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Dryers
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
Dryer not producing heat
Check thermostat/ Element....See also if has scut out @ back casing reset
Oct 08, 2009 | Dryers
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
Kenmore series 80 gas dryer will not heat up
Hi. this dryer has a set of coils that sit on top of the actual gas valve assembly. these coils activate the main and secondary gas valves and if the coil assembly is malfunctioning or, the wires and clips are corroded, the coils will not activate the gas valves to open and close. this malfunction will affect the heating process within this dryer unit.
I recommend inspecting the dryer coil assembly. use a mulitimeter to test for Resistance. you should get a reading of some type of current flow through the wires and, if this is the case, the coils are bad and they will need to be replaced.
This test is actually not needed. the non existing heat is a red flag on its own and, it greatly confirms a major failure within the coil assembly. replacing the coils will fix your dryer.
PLease rate and god bless:)
Apr 20, 2009 | Kenmore Dryers
Kenmore 80 Series Model #110.74842400 Series MR5112733
There's a few things on this dryer that can stop it
from heating. 1st thing your going to need is an ohm meter, your testing simply for continuity. The main items that cause no heat at all on this gas dryer is the igniter on the gas valve, the thermal fuse located on the blower wheel housing the thermal cut out located on the burner box or the flame sensor on the burner funnel and lastly the coils on the gas valve. the sequence is from most too least common. Of course unplug it and shut the gas off.
Jul 30, 2008 | Dryers
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Dryers Logo
783 people viewed this question
Top Dryers Experts
