Question about Motorola Mobility RAZR V3
Broken screen The phone was dropped and the screen on the flip part is cracked and a piece is missing. Can this be replaced, and how can I find where to get it fixed?
  • 1,586 Answers
Probably your only bet is going to be to buy another RAZR on eBay - one that's broken - and use parts from it. But with how phones are made to be throwaways anymore, you're probably better off just getting a new one unfortunately.
Posted on Jul 31, 2008
My phone was dropped and now I can't see anything on the screen.
If the screen of your phone is not crack, the problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying. But if the screen is crack, you will need to get a brand new screen to solve the problem.
Take care.
Jul 28, 2010 | Motorola Mobility RAZR2 v9 Cell Phone
Broken Language Master Screen
Hello
cracked screens can not be repaired, the screen needs to be replaced to a new one.
check ebay.com for parts.
May be hard to find. You may have to buy a new one. or a broken one that has a working display.
Good luck.
Apr 16, 2010 | Franklin LM-6000 Speaking Language Master
My lens is cracked on my flip cam, how do i fix it?
They aren't too hard to open up and take apart. There's a glass piece the covers the actual lens and I'm guessing that is what broke. Once the flip is in pieces you can remove the glass piece and it will operate fine without it. If you want to replace it, you can either get a broken flip and use it for parts, but there's a pretty sticky, tough ring of tape holding that glass piece in place. You could also try a very clear piece of plexiglass and cut it to size. Haven't tried that one myself, but it may work.
Apr 15, 2010 | Pure Digital Flip Video Ultra Camcorder
Cracked screen, now lines running up and down screen
Its all one piece on the vu. as long as the plastic lens covering the lcd is still intact. Its a fairly easy replacement Ive done a few!
Mar 01, 2010 | LG Vu CU920 Cellular Phone
Cracked screen on outside front of phone
You would probably have to send it back to the manufacturer in order to replace it, and that would probably be costly.
Aug 22, 2009 | Motorola Mobility RAZR V3
Broken screen on Blackberry 8220 Pearl Flip
If you're tech savy you can use a blackberry repair guide that will show you how to disassemble it step by step and replace the screen, the screen is available on Ebay or you can go to the repair service.
Jul 15, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
"Bolt" replacement on Razor Phone
Be very carefull with the phone. The main cable runs through that left side.
Look on Ebay for a Left hinge pin for the V3. Also knows as the left knuckle.
Make sure you look for the V3. Not Razr.
If your speaker goes out, or you lose display before you get the Knuckle, you need to get a keypad flex also.
If not, get the Knuckle, and it just slides in. MAKE SURE before you pop it in that there are no pieces of the old one in there and that you don't pinch that cable.
I can fix it for you if you send it to our business, but if you're careful, you shouldn't have a problem.
Jul 31, 2008 | Motorola Mobility RAZR V3
Help please!!
you can replace yourself rather easily. a new lcd assy runs about 45 dollars on ebay.
Check the links below for directions to replace and where to buy.
replacement of the Sidekick 3 LCD flip screen.
Sidekick 3 LCD
Mar 24, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Did not drop/but screen sticks
It doesn usually happen when dropped. You may be able to fix it by removing the flip screen and rotating spring action fli[p piece.
The following instrutions are for a sidekick 3 lcd screen but it is the same for a sidekick id.
http://repairmysidekick.org/Remove-and-Replace-Sidekick-3-LCD-Flip-Screen
Feb 25, 2008 | T-Mobile Sidekick ID Cellular Phone
Motorola Mobility RAZR V3 Logo
75 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
