Question about Refrigerators
My fridge keeps icing up.It has a small crack in the corner caused by me with a knife.Is there special glue I can get toseal this?
  • 770 Answers
You can but it will need to be room temp to do but and epoxie mix (clear) at your harware store mix it and let it set before letting the unit to cool
Posted on Jul 30, 2008
Ice maker leaks water into ice bin
Some things I have seen that causes this issue:
A. Plug not sealing properly in the bottom of the water reservoir
B. An issue dealing with the circulation pump. Maybe splashing water out of the reservoir while running due to crack in pump housing, especially around impeller, or hose that feeds water from recirculation pump to cold plate has a crack/split/loose connection.
Dec 23, 2013 | GE Monogram ZDI15C Automatic Icemaker
I have a GE Profile fridge, top freezer. Ice buildup keeps blocking thew evaporator fan. I've defrosted 2x, checked evap drain for blockage. But ice buildup reoccurs after 2-3 days. Turning up the
You have a defrost problem. Locate your defrost timer while the unit is iced up and turn it until you hear a defined click. At this point open the freezer and listen for ice cracking. If Ice starts cracking then it's your defrost timer bad. If ice doesn't crack, then you have a defrost component bad ( heater and Bi-Metal) Ohm out your heating element and replace if there is no continuity. You can usually find defrost timer either under the front of the box, in the fridge around the light or thermostat or sometimes in the back at the bottom. The dial on the timer can only be turned one way with a large flat head. You will hear the difference in the way the clicks sound for the defined click. Good luck.
Mar 09, 2013 | Refrigerators
There is a small hairline crack on the outer casing of my fridge and a little bit of ice is forming on it on the outside is this dangerous?
The gases circulate at the back of a fridge in the thin metal pipes. If the pipes are ok, it should be ok but is probably costing you a fortune to run as motor will be on trying to keep temp down.
Feb 02, 2013 | Refrigerators
Whirlpool fridge freezer stopped making ice
Make sure the freezer plug cord has power on the outlet. Also check the thermostat control if working, in desired settings especially in low degrees, it should have some freeze. If not, then thermostat is defective.
See to it that the evaporator has no dent, punctured cause by sharp object ( knife, screw driver, etc.) when removing frozen food or drinks. If it has small hole, it will cause refrigerant to evaporate hence freezer will stop making ice.
A defective defrost timer will also cause that same problem. You will know it by dialing the knob, it should smooth and no friction and if it has failed to go back to original position.
Thanks for asking.
Jul 03, 2011 | Whirlpool Refrigerators
Fridge temp goes up and ice forms in fridge
CHECK THE BAFFLE IT MIGHT NO BE OPENING OR CLOSING PROPERLY, THAT`S THE SMALL DOOR LOCATED @ THE LEFT UPPER CORNER OF THE FRIGERATOR
Aug 19, 2009 | Samsung Refrigerators
Icing fridge wall and fine crack inside corner of fridge.
i called a repair man who was advertised in the local newspaper.
Aug 14, 2009 | Nostalgia Electrics Helman Group CCP-509...
Crack on the corner - we have a run on the ceramic
Glass on cooktops are not fixable - due to the chance of electrical shocks the manufacturer strongly suggest replacement of the glass.
Jun 03, 2009 | Cooktops
Sony ericsson p910a cell phone
Hello. There's a special adhesive attached to the back of the touchscreen that allows it to be attached to the LCD screen. You will need to start prying it off the LCD screen very slowly, working from one corner and slowly peeling it back with the use of an x-acto knife, or other sharp-bladed knife. You must be very careful as it's very easy to permanently damage the LCD screen underneath. I suspect your touchscreen stopped working, hence the need to replace it. Good luck.
May 20, 2008 | Sony Ericsson P910a Handheld
Ice in Refrigerator Section
there are 2 possibilities. first the drain is blocked causing water to overflow from the defrost water gulley at the bottom rear of the inside of the fridge. this can form ice as it is close to the division between fridge and freezer. second, the .fault of ice growth can be caused by breakdown of the cabinet insulation. of the two, the first is the moree likely. to test drain is cloear, pour a little water down the drain. if it does'nt flow freely, push something flexible down the drain hole till blockage is clear
Apr 14, 2007 | Sub-Zero 650 / O Bottom Freezer...
Fridge Leaking water from front right hand corner
Most likely you're correct, the defrost cycle produces water that is supposed to be captured in a holding tray, pan, etc. If the pan is cracked it would leak out or if the drip tube (pipe) is not in place it would miss the pan. It may be easier to remove the contents of the small frige and tip it over some to see what you can down there. I assume this small unit doesn't have any water souce to it (no ice maker or water). Check the tubing for damage and see if you can find the holding pan to inspect for crackes, etc.
Oct 19, 2006 | AEG SK78800I Compact Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
