Question about Mitsubishi WS-65869 65" Rear Projection Television
Connecting DELL Laptop to Mitsubishi WS-65869 Projection HDTV purchased in 2001
Not sure if this service still works but I am trying to connect my DELL Inspiron 6000 laptop to my Big Screen TV. I have a blue VGA port in the back of my laptop and I think I can connect it to my TV through the component video cable area in the back. But, I am unsure what cable I need to get the best picture from my laptop to my TV. Also, I am about to get a PS3 and bought an Altona component switch so I could get the most out of my PS3. However, I am a bit confused on what cable I need in order to plug the switch into the TV once the PS3 is plugged into the switch. Needless to say, I am very electronic ignorant and need some advice from guys who know their stuff. Any help would be greatly appreciated!!
Chris
Washington DC
chris7748@gmail.com
  • ALFinDC Aug 11, 2008
    Actually, it is a bit more involved. I did buy the cable but needed to buy a switch so I could plug in the PS3 with the component cable as well as my HDTV cable box, and then run the component cable from the switch to the DTV outlet in order to get 1080i for my PS3. That gives me 1080i HDTV for my channels, Blu Ray DVD's, and my PS3 games all plugged into the switch and all connected to the Mits in the DTV input, which is the only 1080i input on the TV. I found a tech guy who solved this for me. Thanks.
For the ps3 just buy a component cable for it and match up the colors
Posted on Aug 11, 2008
Video games projection on a Mitsubishi WS-65869
1,2 error code means NO ERROR FOUND. The set is older and may not be compatible with this set---what type of connection is being used and to which rear input?
Dec 16, 2012 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi 65" WS-65869 Blinking Green Light 3-2 pattern,
two ideas:
Make sure you tested the pico fuses inside the unit with the caps==two or three of them.
Also from front of set behind speaker grill unplug both plugs that go up to front keyboard--set will still work with remote===if set functions now then the reset micro switch is bad/damaged.
Mar 12, 2012 | Mitsubishi WS-65869 65" Rear Projection...
Not work ws-65869
The DM capacitors need to be replaced. Heres a link to the DM kit for your model which contains the replacement capacitors and instructions with pictures that show how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Jun 13, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Color is going weird
Chroma IC is to blame, but before you go replacing it, be sure that the power supply voltages are correct....accordianman
Jun 05, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869
This set will require that the power supply voltage problem be fixed...accordianman
Jan 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi ws 65869 green led turns on for 2 sec then turns off
Your problem is not shown on schematic, C9A60 (470 pf @ 1000 v) capacitor and check and see if F9A04 & 05 are open. If so then its off to a whole different area. Do you have an email to send Sch.?
Jan 15, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitshibishi 65 " HDTV
Check 5A micro fuses F9A04 and F9A05 - If one or both are open,change the single convergence IC part# STK393-110.
Aug 22, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869
On the input section on the back of the tv it should say what formats it uses also make sure that you have in on a hd channel and make sure your using component cables and not the yellow white and red
Jul 11, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
266 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
