Question about GE Refrigerators
I have a side by side refirgerator, model # GSH25JFXBCC. the refrigerator has too much humidity. the food in the refrigerator is wet and moist. the food (fruit/vegs) in the bins is wet with moisture. food is deteriorating quickly. I have today reset the frig to 6 from 5. the freezer is still at 5. any suggestions? P.Pratcher
  • 770 Answers
Please check your door seal this the the number 1 cause of high humidity in refrigerators. make sure the door closes completely as well
Posted on Jul 30, 2008
Thin layer of ice on food in ge side by side
ice on food means door was left open for extended period of time and then closed. When door is left open humidity forms on food. when door is closed again the humidity freezes and becomes thin ice
Apr 21, 2014 | GE GSH25JFR Side by Side Refrigerator
Ice dispenser door open. Ice freezes at bottom of bin, rendering the dispenser useless
If the ice door is open that will need to be repaired first before solving the ice melting and stopping the ice auger from moving. What may be happing is the ice door stuck open causing warm moist air from outside the refrigerator to be drawn in covering everything with frost and possibly locking down auger and causing the refrigerator to run continuous. What is the model number found around the fresh food section? Thanks Sea Breeze
Nov 16, 2012 | KitchenAid Architect Series II KSSO42QTX...
My jenn air model # jrsi225 is VERY HOT between the side by side doors how can i fix this ?
Its only natural to feel hot on side doors of the refrigerator. There are heating element that responsible for heating the side doors. Without such heaters, side doors will get moist, wet to touch and then rust will eventually develop causing it to destroy or weaken the refrigerator body, if rust is not treated. You shouldn't worry about that cause that is not a problem.
Thanks for asking.
Sep 01, 2011 | Jenn-Air JSD2789GES Side by Side...
How can I defrost a Kenmore Compact 91601 refirgerator without pulling the unit out??
to do that remove food from top shelf,place a towel there,turn off refrigerator,use a hair blow dryer and melt frost
Aug 07, 2011 | Kenmore 91601 Compact Refrigerator
Do I want low or high humidity to keep vegetables crisp. Neither seems to make much difference.
The humidity switch does not control the humidity inside the fridge, but rather is used to control moisture that can form on the edges of the fridge and on the divider between the fridge & freezer compartments.
In areas that experience humid conditions, this is a common occurrence. The relative cold of the freezer & fridge in certain areas of the fridge case causes moist air to condense on contact. This condensation is prevented by a heater that is behind the metal case of the fridge. The moist air can't condense because the metal surface is warmer than the room air.
If you don't have a humid time of year, leave the switch set to "off", as the heater uses electricity and lowers the efficiency of the fridge and freezer - resulting in increased cost of operation. Not using the heater when it is humid will eventually cause the moisture to cause rust on the wet areas of the fridge case.
Please rate this reply - thanks!
Dec 01, 2010 | Sub-Zero Refrigerators
Food freezes in refrigerator
Ge side by side Fridges are gaining bad press for their bad thermostats. they simply just dont last in moist environments, and this is what you will need to replace.
In your case it will be called the Temperature sensor.
Mar 13, 2010 | GE Profile Performance 25.2 cu. ft....
Samsung refirgerator freezing food.
your damper door is freezing fully open between the freezer and refrige compartment defrost it,then adjust the cold control to make sure its controlling the door position,itsound as if your door seals may be letting in warm air that condenses and freezes on things check this too
Jan 16, 2010 | Refrigerators
Build up of a lot of water in side the bottom of my fridge the goods are still being kept cool. Fridge is a bauknecht IRU 1433 EN 153 Service no. 01/7875 66
I have had this problem. Although I have not been able to pinpoint the exact reason, I suspect that it is due to an old door gasket that is not providing a good enough seal all around the door. In especially humid weather, moist air outside the refrigerator gets in and the moisture condenses, much like on a glass of ice water on a humid day. If it bothers you enough, I'd say replace the door gasket.
Jul 23, 2008 | Refrigerators
Refrigerators Logo
99 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
