Question about Miele 24 in. G646SC Plus Free-Standing Dishwasher
Inlet/drain light remains on
Have followed the intruction ooklet, turned the dial to stop turned the machine off and then on again. Checked the flow of water intake, is normal.Cleaned the filter and beneath that taken the non return valve out and washed out, no kink in the hose. I feel that it might be something to do with the inlet hose, after opening the casing on the filter it appears to be full a dark green molded colour (it maybe it is suppose to be like this). The pump sounds to let the water out of hte machine, so I don't think there os a blockage. If there are any ideas please let me know, otherwise will have to scrap it, which is a shame.
I have the same problem on a Miele G647 SC Plus. It starts and completes the wash cycle, might skip a final rinse - not sure, but it drains the water. Pump then continues to run for extended period then inlet/outlet light comes on. The dishwasher never moves to the drying cycle.
I cleaned all filters, checked supply/drain hoses + the non return valve. All seemed servicable. But no real improvement in fault.
Any way I can fix this?
Posted on Aug 13, 2008
My G647SC PLUS has had the same symptoms with several week intervals. Now finally solved. Unplug the machine. Take off the metal front plate at the bottom of the machine - first remove the plastic cover under the door near bottom, two size 2 Pozidrives, then you get at the steel cover, again two size 2 Pozidrives, a bit harder to get at, you may have to lower the door. After removing the screws, gently lift the cover from low edge and it will come off. If the well under the machinery is dry, check the float sensor which is the white round flat-bottomed device near the front by removing the plug cover, the plug itself and finally the float sensor itself. Open it by releasing the two catches and check that the microswitch is not permanently activated by the styrox floating device. In my case it was, probably the styrox had lost some of its form but I managed to reinstalled it in such a way that it released the switch. I checked that by lifting the styrox the microswitch activates. Re-installed and run the machine, works fine now.
If the well is wet, then you have a leak in the draining system and need to replace the gaskets and/or the pump itself.
Posted on Mar 03, 2010
    Problem Solver:
  • 6 Answers
I have a G647 SC plus. Fantastic dishwasher. Very quiet. If you have an inlet/drain fault, the fault I had was a faulty Non return valve. You remove it when checking the impeller by taking out the bottom strainer, fliping the wire catch and lifting the non-return valve housing off.
If you can blow into the pipe easily, the valve is faulty. In my case the rubber boot had rotted. You can temporarily fix this by twisting the valve apart, getting the rubber boot out, and trimming away all the rubber (put the modified rubber back in) so that the metal ball seals on the bottom of the plastic housing instead. It makes a bit more noise, but it will get you out of trouble until get a new check valve delivered. Part number 5269111 for G647 SC. inlet/drain light remains on - 19b5168c-06e2-4eaa-b5c8-4cd44e1f6b16.png 8bd22d47-7004-4aca-a997-980a516ca883.png
Posted on Sep 14, 2014
    Problem Solver:
  • 5 Answers
I had the same problem with a different model with a persistent inlet drain light flash and a continuous running pump.
Checked the pump in the bottom had blades and wasn't blocked or obstructed (on mine take out the bottom strainer, flip the catch and lift the non-return valve housing off). Checked the drains were clear by putting a hose in where the non-return valve outlet goes (teh hose was a good sealign fit - standard garden hose) and running a decent flow down the drain. It all worked, no flood or other nasty. Put the machine back together and put a few cups of water in and turned it on - it drained. OK the drain pump was working.
Checked the water supply had pressure and flow. Descaled the inlet filter in the feed head on the tap (soaked it in vinegar for a while then rinsed and blew it clear). Still the flashing light.
Turned off and disconnected the electricity supply. Opened the front bottom plate of the machine. There was water standing in the drip tray at the very bottom of the machine. Dried the tray with a handful of paper towels. Put it back together. it ran fine.
I conclude that I need to replace the pump seals.
good luck with yours. rupertvdP
Posted on Aug 11, 2009
How can I clear the intake/drain light on a Miele G2182?
Your pump motor has siezed, it can be removed then spray some penetrating oil abd rotate by hand until the fan spins free and reassemble. Be sure to turn breaker for your dishwasher
May 12, 2014 | Miele Dishwashers
No power after blocked drain dishwasher
Reset it by turning power off to it or unplugging it for a minute. If it still wont work then you need to take the kick panel off and see if there is leak under the machine.
Feb 08, 2014 | Smeg Dishwashers
My dish washer has started to flash Err 7 on the screen and will not work. I ahve cleaned everyhting out, put drainO down the drain, turned it off for 1 week then back on again, checked that the hoses
F7--7 Flashes--Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked
make sure water is getting to your machine, its possible that the hose is kinked and not feeding water sufficiently to the machine.
alternatively, Unplug the appliance.
Take it out of it's position.
Take the left side panel off.
In the large plastic tank on the left side of the machine is the flow meter.
It's a small pcb with a 2 wire plug on it.
Pull the plug off and push it on again.
Do this several times to clean up the connection.
Ensure the connection is dry and tight.
Try the machine again.
If it still doesn't work, you'll need to obtain and fit a new flow meter to try and cure the problem.
Apr 03, 2013 | Dishwashers
I have a misled g843scvi dishwasher. The intake/ drain light is flashing, machine start then fails. Any ideas
Hi
Thanks for using FixYa. The first thing that should be checked is if its draining properly as it could be that the drain hose is clogged and needs to be cleaned. The drain pump also should not be clogged. Also the stopcock should be opened fully and the water inlet valve should be checked for any clogs. Also the metal filter, impeller cover and the air gap unit should be checked. After checking this you can reset the error as follows: turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again. Please revert back for further assistance.
Thanks
Rylee
Dec 23, 2011 | Miele Dishwashers
Whirlpool ADP8540 IX dishwasher - dishwasher starts then stop shortly afterward Error light flashing 4 times. I can restart by holding the start button but shuts down again shortly afterwards - Any Ideas??
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
Need to check the inlet valve, the pressure pump as it seems to trip the controller unit.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
Thank You for using Fixya
Aug 18, 2011 | Whirlpool Dishwashers
Thankyou, model is SB 925 Sensorwash machine runs for a few minutes then stops and starts "beeping".If I turn it off at the power point it will run for a few minutes and repeat the same process....
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor .
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water .
For spares click On:
http://www.espares.co.uk/search/dishwashers/p/1083
Jul 25, 2011 | Westinghouse Dishwashers
I have a haier dishwasher but the water wont drain out of it. the power light remains on but turning the settings dial has no effect - looks like the pump may be blocked. how can i carry out a factory...
you maybe right but before doing machine reset button, you need to clean the machine be sure there's no jam in mechanical parts. also not all machine have reset button outside, some are hide and inside the power supply module so look for it and be careful.
Feb 04, 2011 | Haier HDP18PA Stainless Steel...
Inlet/drain, salt and rinse aid light flashing also water left in base of machine after it stops
Hi
Thanks for using FixYa. The first thing that should be checked is if its draining properly as it could be that the drain hose is clogged and needs to be cleaned. The drain pump also should not be clogged. Also the stopcock should be opened fully and the water inlet valve should be checked for any clogs. Also the metal filter, impeller cover and the air gap unit should be checked. After checking this you can reset the error as follows: turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 06, 2010 | Miele 24 in. Novotronic G641 Plus Built-In...
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Miele 24 in. G646SC Plus Free-Standing Dishwasher Logo
1,813 people viewed this question
Top Miele Dishwashers Experts
icatci
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
