Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Grinder will not turn off!!
When I try to pull a shot, the machine makes a muffled noise, as compared to the distinct "smack, smack, smack", I have heard thousands of times over the past 5 years. The grinder starts and grinds and grinds and grinds...  it eventually stops but can't continue with the process as the machine is now full of grounds. I have disassembled the hopper and cleaned the teeth of the grinder. All looks good inside. ANY IDEAS? Should I just buy a new brew group?
  • 515 Answers
It can be the micro switch in the machine you have to replace.
If you take off the top you will see it where the hole for the beans are.
Posted on Jul 30, 2008
The grinder on my DeLonghi seems to be stuck. It makes only a noise but not s bean is ground and one can hear it is not turning. Any solutions? Thank you
Likely a foreign object is blocking up the grinder. Remove all beans and run at coarsest grind to try to clear it, chase it through with more beans if necessary. If this does not clear it then the top burr of the grinder assembly can be removed after disassembling the machine. Mark the grinder coarseness cogs before moving them to assist reassembly. Moderately difficult procedure.
Aug 11, 2011 | DeLonghi Magnifica 3300 Espresso Machine
I cant get the grinder to work its making a loud noise
1, Turn power off at Machine 2, Pull plug out of wall 3, Check and clean out coffee bean dispenser (Checking for jammed bean/object's) 4, Re-assemble coffee dispenser and turn machine on. 5, Try using machine now after yo9u have cleaned and checked for jam's ect..
These machines are tricky and may require returning to Manufacture/Repair shop..
Goodluck
Aug 05, 2011 | Breville BES860XL
The machine makes a very loud noise when grinding the coffee beans. * Magnifica Espresson Machine *
Even a properly operating super automatic DeLonghi espresso machine makes enough coffee grinder noise to scare your pets and wake you next door neighbors. It's LOUD, no doubt about it. Only if your grinder makes more noise than that do you have a problem.
Jun 23, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Machine has major problem with grinding beans.
Try removing all beans from bean holder - then use a vacumn machine to remove the bits down amongst the grinder "teeth'. You may have had a small stone in your coffee and if so it may have jammed the grinder.
Once it looks clean, try making a cup of coffee without the beans in the hopper - you should be able to see and hear the grinder revolving and also hear the brew unit moving between the grinder outlet and the water inlet. If it all seems ok now, then add a small amount of beans back into the beans hopper and try making a coffee. If it still will not work, get it serviced. There's not much the average person can do inside these units other than to do more serious damage or kill themselves with an electric shock.
Nov 05, 2009 | Saeco Magic De Luxe Espresso Machine
Hello. grinder won't grind
HI
Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. This will be above where the brew unit was. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute.
Once that is cleared go to the bean hopper. There are 2 knobs in the bean hopper. Turn the large knob to the largest number. You can turn the knob to a larger number any time but it has to be grinding to turn to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can turn the knob back to a number that was higher than the one you had it on, but only when the grinder is running.
Jul 24, 2009 | Gaggia Syncrony Espresso Machine
Heater making angry noise!
Your heater fan bearing is shot,,time to replace Fan now before you really need it.
Jan 19, 2009 | 2004 Mazda 3
Constant loud muffled noise coming from the sub and speakers.
Try playing with the connection, sounds to me maybe the jack is going bad or has a shorted connection. Plug it in and out slowly to see if that's the issue.
Sep 25, 2008 | Logitech Z-5300 Computer Speakers
Saeco magic deluxe machine is making crunching noises when makes coffee and when returning to start position. Sometimes does not make the coffee grinds coffee but not letting water through almost seems...
There is a lever inside the door on the right. It is at the top in the center. Pull it back one click and try again. The crunching noise does it sound like a clicking noise?
Aug 31, 2008 | Saeco Magic De Luxe Espresso Machine
Noise while zooming with sb-600
sb-600/800 make a distinct motor-spinning noise when zooming, this is normal. Any grinding/clicking noises are not normal.
Jan 25, 2008 | Nikon Speedlight SB-600 TTL Flash
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
42 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
