Question about Electronics - Others
My windows 98 dell dimension 7500cx will not recognize my verbatim 256 mb memory stick
I need to get information off the above memory stick and my computer does not even recognize it
  • 208 Answers
Windows 98 need special driver from usb memory stick manufacturer.
if they dont have it then its not a compatible model for win 9x.
what i have done in prior is if high speed internet is saving it to online drive storage free website like if u have aim account youre ready to use it or others like yahoo mail yourself the files then retrieve in other pc.
Posted on Aug 04, 2008
What memory (does) it use?
Jokodi Haynes,
The Dimension 8200 memory specs are listed below.
Architecture RDRAM
Memory connectors four
Memory capacities 64-, 128-, 256-, and 512-MB non-ECC RDRAM
Minimum memory 128 MB
Maximum memory 2 GB with Microsoft® Windows® 2000 and Windows XP; 512 MB with Windows Millennium Edition (Me)
Memory type PC800 (non-ECC)
Memory speed 40 ns or faster
BIOS address F8000h
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 29, 2016 | Dell Dimension 8200 PC Desktop
How does this computer compare to a Dimension 5000 with same RAM amount and clock speed?
Below are the specs you requested on these 2 systems.
Optiplex GX280
400 & 533 MHz DDR2 SDRAM
400 & 533 MHzMemory connectors
small form-factor computer: 2small desktop computer: 4desktop computer: 4small mini-tower computer: 4mini-tower computer: 4
Memory capacities
128 MB, 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory
dual-channel: 256 MBsingle-channel: 128 MB
Maximum memory
small form-factor computer: 2 GBsmall desktop computer: 4 GBdesktop computer: 4 GBsmall mini-tower computer: 4 GBmini-tower computer: 4 GB
BIOS address
Dimension 5000
Type 400- and 533-MHz DDR2 unbuffered SDRAM
Memory capacities 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory 256 MB
Maximum memory 4 GB
System clock 800-MHz data rate
Memory speed
Thank You,
Dell-Jesse L
Jul 15, 2015 | Dell OptiPlex GX280 PC Desktop
Physical Memory is limited to 256 MB" in dell 2600 poweredge
In the bios there is an option to install OS, make sure this is flaged as off, when you reboot you will have access to the full amount of onboard ram.
Aug 20, 2009 | Dell PowerEdge 2600 Server
New memory & old
Yes this should be no problem. The windows should recognize it with no problem and every little bit hope this helps have a great night
Jun 17, 2009 | Dell Dimension 2400 PC Desktop
My Dell C600 won't recognize the 2 new 256 mb sticks of RAM
i think you need a same brand of 256 for it to work? and when you buy something for your computer make sure that the one you both is the same brand or code with your 128 for example you have 128 ddr2 sdram so you can only upgrade it with 256 ddr sdran or 512mb,1gb,2gb ddr sdram.
May 01, 2009 | Dell Latitude C600 Notebook
Added 2g to a dell dimension 3000, only 1g recognized
Dell has a really good support site. You log on, enter your service tag number (on the top of side of your PC) and they will tell you exactly how much ram you support, the type of ram needed and how many slots it has. If it was a matching pair then it should be working, unseat it and reseat it, it may not be in all the way. If still don't show then put it back in the old computer and see if it reads it. If not then the RAM stick got damaged during the move. But no doubt you should be able to handle more that 1GB of RAM. Good Luck, let me know if you have any questions.
Please rate this solution.
Apr 13, 2009 | Dell Dimension 3000 PC Desktop
Computer will not work with extra 1gb ram
It sound like you have incompatible memory. Try taking out the original 256 and test with the 1 gig. Keep in mind some PC requires memory to be paired. If you only have one, 1gig memory chip you might need to get another. I would try removing the 256 first. The specification of the motherboard would also tell you the memory usage.
Let me know if this helps!!
Mar 25, 2009 | Dell Dimension 1100 PC Desktop
Dell Demension 4600 motherboard memory
From the Dell specifications page for Dimension 4600:
Dual Channel DDR SDRAM
Memory connectors
Memory capacities
128-, 256-, 512-MB or 1-GB
Minimum memory
NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
Maximum memory
4 GB
Memory type
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
Mar 09, 2009 | Dell (2336V) Motherboard
Added a memory stick to my Dell 2400 Desktop computer and the monitor, mouse, & keyboard won't work
The supported Memory types for Dimension 2400 Series is PC2100 (266-MHz) or PC2700 (333-MHz) DDR SDRAM (non-ECC). Supported Memory capacities are 128, 256, or 512MB and a Max if 1GB (1024MB).
The first obvious question is does the new 512MB Memory module meet the above specification? Some Memory modules are able to steep down speed.
If it does, then first ensure the new memory module is properly installed. Take ESD (ElectroStatic Discharge) precautions or you may damage the new memory module and/or the system board.
To proceed compare the system beeps and diagnostics lights color and sequence to the Advanced Troubleshooting guide.
It is possible that the new memory is DOA (Dead On Arrival). Or there is a new fault on the system. If you have access to another compatible system, you may test the new and old memory modules. You may also swap the new and old memory modules to determine if the memory slot is at fault.
Lastly, if you remove the new memory module, does the system complete POST (Power On Self Test)?. If it does you may indeed have a DOA or incompatible part.
Jul 26, 2008 | Dell Dimension 2400 PC Desktop
Ram memory
press f2 on the initial delll logo on startup
once on the bios num lock, caps lock and scroll lock so that all 3 keys are on
press alt + e
press alt + f
press esc
select save changes and exit
it should wrk
Apr 19, 2008 | Dell Dimension 4600 PC Desktop
Electronics - Others Logo
117 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
