Lexmark Z640 InkJet Printer Logo
Posted on Jul 30, 2008
Can't remove existing printer
I have Lexmark 640 series printer and I have lost the disk. Also, I can't delete or otherwise get the existing driver to remove. It just keeps reading that I can't remove it because it's currently in use and it isn't. If I could get it removed I think I could download another driver from the internet. Any suggestions?
A
Anonymous
Power port connection
2helpful
2answers
Where i can get the software for lexmark 640 series?
Here're the lists of available download for Lexmark 640 Series Printer Drivers and softwares from Lexmark Official Website (click here) Open the link and select the link (link name) to download the software.
Good luck.
Thanks for using FixYa.
2helpful
I have also lost a software dist for Lexmark 2500 series
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
If instead you want to purchase the replacement disk,
Contact Lexmark here, to see if the disk for your printer is available.
2answers
Broken Lexmark 640 installation disc
Lexmark does not distribute replacement install disk for all models, but many models are available.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
4helpful
Lost install cd for lexmark 1300 series printer
Lexmark does not distribute replacement install disk for all models.
2answers
I lost my disc that installs the printer lexmars 6300 series and now i can install my printer in my new computer
1helpful
Z640 printer
Here's a link where you can download the driver/software for you Lexmark Z 640 printer.
Lexmark Z 640 Inkjet Printer driver downloads
13helpful
How to install lexmark 3500=4500 series printer without setup disk
To all Lexmark owners with the lost disk problem.
If you instead want to purchase a new disk, bear in mind that Lexmark does not distribute replacement install disk for all models.
2helpful
Lost disk to install
Afterdownloading, find thefile,double click on the file, then if you get introubles, follow the instructions below to reset and reinstall drivers:
  • Download driver from website and run the file.
Note:some printer does not work on Vista
I lost my start up disk to lexmark x73
ok..go here for some new drivers..find the lexmark icon, enter your model number and then operating system..and you might be good to go.
remove the existing printer from control panel before installing new drivers.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
