Question about E-Machines Computers & Internet
Changed BIOS and now emachine w3052 woulnt boot
I moved the FBS in the BIOS up one notch in a attempt to gain a little more speed... when i tried to save the changes the screen went black and has stayed like that for about 3 hours... and i have turned the computer off and on once but that didnt help any... so i have no idea how to fix it... if nothing else ill just swap a motherboard from a dell that has a 2.66 GHz pentium 4 and 256 MB of RAM but i believe i can use the 512 MB stick from the emachine so there is more RAM... let me know im some what desperte...
  • taylorap Jul 30, 2008
    would i be switching the jumper while the computer is powered on or while its off?
    so while the computer was off since that sounded the safest to me i switched the thing than switched it back... now that i have turned it back on the computer is beeping at me... did i do something wrong or is this normal
  • 781 Answers
Try resetting BIOS
On the motherboard will be written clear cmos or bios this will be a small 2 or 3 pin connector
2 pin remove the jumper which is only on one pin and fit it over both for 15 or 20 seconds remove jumper fit back over 1 pin reboot all things being equal your computer should start
3 pin remove jumper from pins noting which pins it is on fit jumper over middle pin and the one it was not on before leave for 15 or 20 seconds replace jumper over original pins and reboot
Posted on Jul 30, 2008
I wanted to reinstall windows i put my emachine disk in and the next thing my computer woulnt start up at all and it says registry files are missing or corrept
Boot the computer and press the key or key sequence that allows you to enter the BIOS configuration utility. Explore the tabs to find the BOOT order. It should be under the TAB called BOOT.
Change the boot order so that the computer boots from the CD-Drive before any other drive. Usually you select the drive and press the UP arrow to move the entry Up. Save the changes.
Open the CD-drive and insert the Windows Installation disk. Reboot.
The computer should reboot from the Cd-Drive and invite you to install the OS. Follow instructions.
Feb 07, 2014 | Gateway Computers & Internet
How do i access recovery mode on eMachines W3052
Not sure that this is what you need, but should work. If you have Windows OS, try pressing F8 when booting. A menu will be given on the screen. Will have to choose SAFE MODE and when windows loads go to START MENU-PROGRAMS-ACCESSORIES-SYSTEM TOOLS and choose SYSTEM RESTORE
Jul 28, 2010 | E-Machines W3052 PC Desktop
I changed the fsb from 166mhz to 200mhz on my computer
SHOW YOUR MOTHERBOARD TO ANY GOOD COMPUTER HARDWARE THEY WILL HELP YOU
Oct 21, 2009 | E-Machines W3052 PC Desktop
Emachines W3052 Gets stuck on logo screen when starting up.
My computer does a similar thing, the issue with mine is the mother board which requires everything to be at a certain temperature. Let it run on the start screen for a couple minutes and hit the reset button. If it doesn't boot up you're going to have to get more involved with your PC. Turn off the power, unplug the cord from your power supply, open the case, look for the battery and the JP8 (CLRTC) jumper. Move the jumper from pins 1-2 over to 2-3, wait 30 seconds, and move the jumper back. Close the case, plug in the power cord, turn on your machine, and boot it up. If it still fails to boot check that all cables are securely attached (inside and out), check that the RAM is securely seated, and check the CMOS battery to be sure it is not dead. Beyond this you're looking at a component failure and should contact a repair tech.
P.S. if you feel up to it and can't wait for service, pull the hard drive out of the first computer and use it in a different computer. Be sure to unplug the hard drive from the second computer.
May 16, 2009 | E-Machines W3052 PC Desktop
Bike will not idle
Remove and clean the carb. Reassemble then adjust the pilot screw. This screw is on the bottom outside of the carb centered L & R and forward of the main jet. The screw is nearly recessed in the carb. Turn the screw out 1/2 turn to richen the mixture if the cleaning alone doesn't do the trick. Also, move the clip on the jet needle down one notch for better low speed response. Reset the idle speed as needed.
Please rate this answer. Thanks dtpenn!
Apr 19, 2009 | 2005 Suzuki RM-Z 450
I have corrupted files in Windows XP and EMachines provides "Restore CDs" But with my NEW LG widescreen monitor the instructions on how to startup the CDs is actually cut off. So when I attempt to load the...
hi there! if you can configure your bios set up and go there, priority yout cd rom as first on the list,2nd your hard drive, in able to start and configure your windows set up promptly.How to open your bios set up,after switching on your pc, press F2 or delete depend on your start up windows appear on left bottom of screen if cmos/bios appear on blue screen select the boot sequence and arange the list of booting up your windows.In your screen resolution this will be adjusted after you finished the windows set up to new xp,you can adjust your scrren resolution, by left clicking on your windows xp on screen,click proreties, on properties box there adjustment of screen resolution there slide function key to 1680 X 1200.then click apply,click ok then restart your pc for effetivity or sometime it was auto restart after you change your screen resolution...,regards
Mar 27, 2009 | E-Machines W3052 PC Desktop
Disabled video driver. Now unable to reboot emachines T5246
reset your bios settings put cmos cell for 15 minutes. also u can reset bios with jumper settings.
then remove meory card then check beep.
then connect allconnection then try.u can do it man.
Jan 05, 2009 | E-Machines eMachines Desktop PC
Computer bios seting
Try restarting the computer. As soon as it shuts down start tapping the "Del" key continuously. It has to be before the beep if you get a beep, and before any boot up screen appears.
If this doesn't work try in the same manner tapping F2,F8 or F12.
Try going on the web to Emachine site and do a search for that question.
Good-Luck
Jul 26, 2008 | E-Machines eMachines Desktop PC
1333 FSB processor only runs with fsb set to 1066 in bios
RIArchangel, you're board is not able to run 1333fsb; it can only run at 1066fsb. Though setting the bios to auto should not cause the system to lock up, unless you are over-clocking other settings in the system bios.
Changing you're memory to the faster dual channel 667 will increase the systems over all performance but it will not change the fact that the board can only run at 1066fsb.
If you have the time, take a read over this link. 1333fsb over 1066fsb. http://www.tomshardware.com/forum/230788-30-1333-1066
Feeling spunky? You can test you're CPU with this free software. Scroll down a bit until you see, CPU Stability Test
http://www.pcworld.com/downloads/file/fid,7146-order,1-page,1-c,alldownloads/description.html
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 20, 2008 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Computers & Internet Logo
330 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
