Question about Frigidaire FWT449
Front door buzzing Frigidaire front loading washer
Front door buzzing noise when washing. When push door in more buzzing is reduced. I tried cleaning door area and replaced door side latch as the bottom part of latch was broken. Any suggestion would be greatly appreciated.
    Genius:
  • 1,028 Answers
Replace entire door lock assembly ..remove spring holding the door boot in place and roll boot back ..unless you have the one where the seal is glued then carefully slide knife under edge to cut through glue take the screws from lock and pull through opening remove wires and install new lock ..if noise is only issue use till it blows then replace
Posted on Jul 31, 2008
Why does my fridgaire front loading washer will not start?
Good Afternoon Friend, this is Z. Thank you for allowing me to assist you!
Based on the symptoms you are describing, you may either have a communication error from the main control board or the timer itself may not be operating correctly. If you noticed a humming noise, it could either be a clogged drainage hose or pump that needs to be cleaned, or it could possibly have another issue with the door lock assembly. I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts.
Jul 21, 2014 | Frigidaire Latest ATF6000FS ATF6000FS...
Frigidaire GLT2940S1 front load washer
Hello Friend, this is Z. Thank you for your inquiry!
I see that your Frigidaire washer, GLTF2940FS1 will not start. First, let's try resetting your appliance. This can be done by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes, and then turn on your washer. If the issue persists, you may have a communication error from the main control board or timer itself may not be operating correctly. If you noticed minimum blinking or a buzzing noise before shutting off, it could be a faulty power supply or it could possibly have another issue with the door lock assembly. I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts.
Jun 03, 2014 | Frigidaire Washing Machines
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
Makes a loud buzzing noise when attempting to start cycle
The lock solenoid on the door latch assembly may be hanging up or just noisey. If washer starts and runs then all is ok. If washer wont start, just buzzes, then door latch assembly may have to be changed.
Feb 01, 2010 | Frigidaire Affinity ATF7000E Front Load...
I have a Figidaire Affinity front load washer. The problem that I am having is I close the door select wash and then push start and dr is on the screen. Can you tell me what is happening?
dr means the door switch is not closed. Thus meaning the door lock assembly is bad and needs to be replaced.part number is 131763245 and price is $48.99
Nov 01, 2009 | Frigidaire ATF6000ES Front Load Washer
FWT449GFS1 front door buzzing Frigidaire front loading washer
Could be rubber door boot needs replacing. I am in the midst of replacing mine because door won't stay closed and buzzer sounds till I hold in door.
scott
newcastle on.
Jul 30, 2008 | Washing Machines
Washing Machines Logo
518 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
