Question about Hotpoint WMA58 Front Load Washer
No Power Washer working fine until my wife put in a load,after about 30 mins she checked and found that there was no lights on the machine and it appeared "dead". I have checked the obvious ie plug,fuse and cable but everything fine.Is there an internal fuse located somewhere or something else which could have caused the washer to have no power. With Thanks Bob
  • bobhope1956 Jul 31, 2008
    Thanks for your help. Will probably buy a new washer, sounds like it may be a bit beyond me.
    Thanks again impressed with the site
    Problem Solver:
  • 8 Answers
HI THIS SOUNDS LIKE A CIRCUIT BOARD FAULT PROBABLY BLOWN 3 SMALL COMPONENTS & A BIT OF TRACK ON THE BOTTOM RIGHT HAND SIDE OF BOARD.IT IS USUALLY ONE OF 2 FAULTS THAT CAUSE THIS EITHER A MOTOR PROBLEM IE CARBON BRUSHES TOO LOW OR FAULTY MOTOR THE OTHER THING THAT USUALLY BLOWS THE BOARD IS THE DOOR INTERLOCK GOING FAULTY. I HAVE REPAIRED LOADS OF THESE BOARDS & 9 TIMES OUT OF 10 ITS ONE OF THEM THAT BLOWS IT HOPE THIS HELPS!
Posted on Jul 30, 2008
Samsung washer reset
sound like module problem try to remove all the conection connecting the module and connect maybe after 30 mins.
Nov 06, 2013 | Samsung WF218AN Front Load Washer
I am working on an LG front load washer model number WM1812CW. It will go all the way through a cycle one time. The next time it will stop between the wash and rinse cycle with an error code of OE....
Hi jerryleigers,
The Drain pump is working intermittently. It is either overheating or a loose wire is present or it could even just be a faulty drain pump. I'd suggest removing it (Found attached to the lower sump hose), testing it by aplying direct power to the 2 pins (either way is fine, it works on an alternating current), run it for 5 to 10 min (turning it on and off every 30 seconds), if it is fine then it is a worst case scenario (PCB). If it is not running well, or it is not even starting - replace it, problem solved.
Hope it helps :-)
* If you found this answer helpfull, please rate with a 4 thumbs up and a testimonial please.
Apr 18, 2011 | LG WM1814CW Front Load Washer
Machine worked fine last night. This morning spin not working. Have tested it empty, put it in spin program, a funny clicking noise and then nothing, then after a while indicator shows 01 - ie. finished!...
n most washers the F01 error indicates an control board problem. It is like an internal program error.
A power glitch can cause the problem.
One of the things to try is to enter and run a diagnostic cycle, or unplug the machine for 30 mins.
Jan 24, 2011 | Bosch Classixx WFO 2866 Front Load Washer
Washer stops in middle of cycle. Comes up with code d5. My wife pushed something on and off 3 times and came up with a code of f71
some machines come with a reset program but not all. Suggest you pull the plug out and wait 20 min untill washer has totally discharged. In the mean time, try and drain the water from the tub. Take note if the drain pump motor is working as well. Retry a wash program..
Sep 06, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My washer fills the tub, but when it goes to next cycle just hums
Your motor has failed.
Remove it from the washer to have it repaired or replaced.
Thanks
:D
Jul 20, 2009 | KitchenAid KAWS850L Top Load Washer
Will not spin, clothes are soaking wet.
Are you sure washer is level? I solved our problem that simple and I had worked on solving it for weeks until I double checked the level and found it a little off. Now it works wonderfully.
May 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Lg frontload wash
I removed the top panel of washer(4 screws and slide). Then found the small 1/4" hose that goes from drum to drain hose to be pluged with goo. I cleaned inside of hose and washer worked fine.
Dec 30, 2008 | LG WM-2277HW Front Load Washer
I need help
un plug your machine for an hour if you can open the door open it and then put the machine plug back in with the door open keep it open till the machine comes on then put the program to what you want and then shut the door it then should be ok its called a reset try it hope this solves your problem
Aug 26, 2007 | LG WM2077CW Laundry XL Front Load...
Haier washer won't start
1. does machine light up on control board? no. check breaker box or try plugging a lamp into the same outlet to see if it works. for this problem you may need a repair man to look at it.
Mar 21, 2007 | Haier HLP21E Top Load Washer
Hotpoint WMA58 Front Load Washer Logo
140 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
